First post, by StriderTR
- Oldbie
Now that I've had time to really sit down and play around with my DOS 6.22 build, I've ran into a sound issue that's throwing me for a loop. I feel like I've forgotten, or perhaps overlooking, something in terms of configuration.
Build: https://theclassicgeek.blogspot.com/2024/02/a … s-3x-retro.html
Note: Windows 3.11 has been removed and this is now a pure DOS .6.22 build.
For sound, I have two cards, an Opti 82C930 and an AWE64 CT4520. The Opti is installed, but currently not setup, nothing is configured and no drivers are installed. I'm just running the AWE64.
To cut right to the chase, I am finding some games that either have no sound at all, or just freeze when on startup and I am thinking it's the sound causing it. Here are some examples...
I first noticed an issue when selecting Adlib on PETSCii Robots, you simply get no sound. When I select Adlib in other games where that option exists, same result, no sound.
Of course, the DOS4G games all work fine, like Doom and Duke3D.
Wolfenstein 3D just freezes as soon as you launch the exe and you have to reboot. Other games are hit and miss, but almost all have no sound.
The funny thing is I know I had all this working when I initially set up this system and I'm pretty sure I haven't made any changes to the system configuration since that time, other than removing anything pointing to Windows, but that was done after this issue started, and all sounds in Win 3.11 were working fine, I just didn't want Windows anymore. Still, I went through and tried just about every possible configuration on the cards settings and the result is the same as described above. I can post my current autoexec and config if needed. Diagnose says all the hardware is fine, edits made using ctcu.exe.
I'm having one heck of a time figuring out what changed. If it was something I did, or a fault with the card. Before moving to the Opti and seeing what I can get it to do, I wanted to see what help I can get from this very knowledgeable community on the AWE64.
Thanks in advance!
EDIT:
Current autoexec and config, where I left off in my testing.
SET SOUND=C:\SB16SET BLASTER=A240 I5 D1 H5 P300 E640 T6SET MIDI=SYNTH:1 MAP:E MODE:0SET CTCM=C:\SB16C:\SB16\DIAGNOSE /SC:\SB16\AWEUTIL /SC:\SB16\MIXERSET /P /QC:\SB16\CTCU.EXE /SC:\DOS\SMARTDRV.EXE /X@ECHO OFFPROMPT $p$gPATH C:\DOS;C:\COREL\WP62set mouse=C:\MOUSELH C:\MOUSE\mouse.exe /Q
DEVICE=C:\SB16\CTCM.EXEDEVICE=C:\DOS\SETVER.EXEDEVICE=C:\DOS\HIMEM.SYSREM DEVICE=C:\DOS\EMM386.EXE NOEMSDOS=HIGHSTACKS=9,256FILES=40
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
