First post, by wolf
Fullscreen has always been fine and all of a sudden its not truly full screen. Has half the windows bar at the top. My settings have been untouched for a very long time!
The attachment Screenshot 2024-08-12 050245.png is no longer available
my settings:
Fullscreen=true
Render=openglnb
Fullscreen res=0x0
aspect=false
Any ideas or anyone else having this issue?
Reply 1 of 4, by feda
You could try changing those settings or starting with a fresh, clean config.
Reply 2 of 4, by wolf
I did try every render, desktop vs 0x0, and a fresh config. did same thing.
I even tried running, with all the different options, through D-Fend Reloaded and DOSBox Launcher. same result.
Does DB have a true FS vs borderless FS?
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
render=opengl is wrong
it should be output
Which OS are you on ?
Water flows down the stream
Reply 4 of 4, by wolf
Sorry I meant to type output.
Windows 11
