Reply 1020 of 1280, by keropi
- l33t++
thank you all for the kind words - we do appreciate all of your business and we do make an effort for everything to be as good as possible 😀
x73rmin8r wrote on 2024-08-08, 14:25:[...]
I did have one more question, what plating is on the ram connector contacts? I read that you're not supposed to mix metals in a contact point because of some galvanic reaction or something and I figured I might as well make sure I've got it right.
the simm connector is tin plated - so the more common tin plated sticks will work just fine in the long run
