Reply 160 of 184, by Shponglefan
Did a test fit of various hardware on the IMB200 motherboard:
The attachment IMB200 motherboard test.jpg is no longer available
I'm also thinking of swapping out the Diamond MX300 for a Turtle Beach Montego II. From what I've researched there shouldn't be any practical difference between the two.
The attachment Vortex2 AU8830A2 sound cards.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 161 of 184, by Joseph_Joestar
Shponglefan wrote on 2024-08-11, 18:57:
It may depend on whether your Montego II is a Dell OEM card or a retail one. I have the Dell version, and I encountered some crackling/popping in A3D games when using generic Aureal drivers like 2041 etc. To resolve this, I needed to download a specific driver version from Dell. I think I got it from one of the links in this thread where someone else described the same problem.
After installing the Dell drivers, those crackling/popping issues went away. Thief Gold and Dark Forces 2: Jedi Knight are good test cases for this problem, especially when using headphones.
My retro builds
Reply 162 of 184, by Shponglefan
Joseph_Joestar wrote on 2024-08-12, 05:43:
That's a wrinkle I hadn't anticipated. Do you know if there is a way to tell which cards are Dell OEM versions and which are the retail versions?
The card I have I had bought stand-alone (no retail packaging or anything), so I don't know which version it might be.
Reply 163 of 184, by Joseph_Joestar
Shponglefan wrote on 2024-08-12, 14:44:
I don't know of a sure fire way. Dell cards can have a white sticker with a part number on the back, but sometimes, it falls off due to the age of the card and/or improper storage. There's a picture of the Dell white sticker on this page of TheRetroWeb, though I think that's a Vortex 1. In any case, it's worth testing the card with the aforementioned games using Aureal's generic 2041 drivers. If you get crackling/popping, there's a good chance you have a Dell.
For Thief Gold in particular, this is super easy to check. Turn on Hardware Acceleration in the game's Sound Options, then go back to the main menu and hover the mouse cursor over the different entries there (Start New Game and such). A sound should play each time you hover over an entry. If you hear crackling/popping together with the intended sound, your card is affected. You may need to wear headphones to pick this up more easily.
My retro builds
Reply 164 of 184, by Shponglefan
Joseph_Joestar wrote on 2024-08-12, 14:59:
The card I have does have a couple white stickers on the back. I compared to a few old Ebay listings for retail cards (i.e. ones that include a retail box) and they all have the same stickers. Couldn't tell any differences other than manufacture dates and serial numbers.
Per your advice, I'll have to test it in Windows and see how it goes.
(And I suppose I could always just stick with the Diamond MX300. One advantage that card still has is if I ever wanted to do quad-speaker setup, it has the extra audio jack.)
Reply 165 of 184, by Joseph_Joestar
Shponglefan wrote on 2024-08-13, 01:36:
I think your card might be a Dell. The big white sticker near the bracket has a "DP/N 0005931D" marking which likely stands for "Dell Part Number".
But yeah, testing the card with Thief Gold would confirm it.
My retro builds
Reply 166 of 184, by Shponglefan
Joseph_Joestar wrote on 2024-08-13, 02:09:
This got me curious, so I looked through all the Ebay listings I could and every single card has a sticker with a DP/N on it. Including the ones that come with retail boxes.
Is it possible Turtle Beach just used the same stickers for everything?
Reply 167 of 184, by Joseph_Joestar
Shponglefan wrote on 2024-08-13, 12:20:
No idea, but I have seen the DP/N marking on other Dell branded hardware from the mid to late 90s, such as their Virge and TNT2 cards.
My retro builds
Reply 168 of 184, by Shponglefan
Guess I'll find out when I get around to testing the Montego II card.
In the mean time, I've been some DOS sound card testing with the Orpheus II as I attempt to determine what hardware configuration I want.
One of thing I had hoped to solve was greater compatibility with the Gravis Ultrasound / Interwave component of the Orpheus II. With the previous DFI ITOX G7S620-N motherboard, it worked with Epic Megagames releases and tracker software like Scream Tracker 3 and Impulse Tracker. But other games like Doom, Duke 3D, Descent and Crusader: No Remorse would fail to work with the GUS option.
Immediate testing with the IMB200 motherboard revealed the same level of compatibility. Epic Megagames releases worked, but not the other games. The Descent setup program in particular complains about not being able to load patches upon startup.
The attachment GUS PnP Descent Setup errors.jpg is no longer available
I confirmed this wasn't a software installation issue. If I transplant the same CF card with the same DOS install and configuration to a Socket 7 system, everything works fine. I also tested this with a regular GUS PnP and had the same issues. I even tried throttling the Pentium 4 system, but to no avail.
After doing some research, I came across this thread where another person ran into incompatibility with a GUS PnP and a Pentium III motherboard which used an ITE8888 bridge chip: [SOLVED, sort of] Doom and doom 2 freeze at "calling DMX_Init" with GUS PnP (ITE 8888 bridge)
It looks like there is some fundamental incompatibility either to do with the ISA bridge chip or some other aspect of these motherboards. On the plus side, it does work with the games I care about and music tracker software. I can live without support in other games, since I have both the Orpheus II's Crystal chip and the AWE64 to provide other sound options.
On another note, during testing I noticed the BIOS of the IMB200 offers slightly more options to reserve IRQs. The DFI motherboard didn't include IRQ3 or 4, whereas the IMB200's BIOS allows them to be reserved.
Still trying to figure out how many IRQ options and DMA channels I want to reserve...
The attachment IMB200 BIOS IRQ resources.jpg is no longer available
Reply 169 of 184, by Shponglefan
Did some testing of optical drives under DOS.
For the first test, I wanted to see if the LG DVD drive could be throttled under DOS. It turns out it doesn't work with CD BeQuiet.
After some research and experimenting, I found this TEAC CD-ROM driver in the Vogons driver library: http://vogonsdrivers.com/getfile.php?fileid=1457&menustate=0
This driver includes a speed control option which worked perfectly. I used the /S:4 parameter to throttle the drive and it was completely silent.
My original plan was to use the LG DVD drive in conjunction with an older CD-ROM drive like a 4x to 8x Mitsumi. Unfortunately I couldn't get either of the Mitsumi drives to work. They didn't work with the TEAC driver, resulting in a system lockup. I tried them with the OAK driver, and while they were detected, they wouldn't read any disks. I'm sure if the drives are at fault or if it's some incompatibility with the IDE controller, cable, or something else.
Instead, I looked for a drive that would also work the TEAC driver. Most of my drives worked with the driver, but not with the speed control parameter. The only one that did work was a Samsung CD-RW SW-248. Thus, I think this will be my drive pairing:
The attachment LG DVD-RW and Samsung CD-RW.jpg is no longer available
I did some further testing of the TEAC driver and discovered it can also be set to use only a single drive at a time. This isn't well documented, but the /P parameter can accept "P-M" for master and "P-S" for slave.
LG DVD (Primary Master):
DEVICE=C:\CDROM\TEAC_CDI.SYS /D:MSCD001 /S:4 /P:P-M
The attachment TEAC Driver - LG DVD-R GSA-4040B.jpg is no longer available
Samsung CD-RW (Primary Slave):
DEVICE=C:\CDROM\TEAC_CDI.SYS /D:MSCD001 /S:4 /P:P-S
The attachment TEAC Driver - Samsung CD-R SW-248F.jpg is no longer available
Since both drives can be nicely throttled, this resolves the issue of needing to use CD audio from only one drive under DOS.
Instead my plan is to configure DOS to pair a sound card with an optical drive. Then using a DOS boot menu, I can just pick which sound card and drive combo I want to use. Using only a single drive at a time will also make game management easier since all games can be configured for the same drive letter.
And since MPU-401 playback from the Orpheus II doesn't depend on the Orpheus driver, I can still get General MIDI support while using either sound card for digital audio.
Reply 170 of 184, by Shponglefan
After thinking I had my optical drives sorted, fate just decided otherwise.
First, the LG DVD drive stopped working. I booted up my system and the drive immediately ejected. Furthermore, it would no longer close either by pressing the button or nudging the tray.
In both cases, the motor kicks in but it's still trying to eject the tray rather than retract it.
I disassembled the drive, but couldn't find any obvious mechanical faults. Nothing seemed broken, no loose bits or anything like that.
The attachment LG DVD-RW GSA-4040B disassembly.jpg is no longer available
Reassembling the drive, I was able to get it to power up without ejecting. Everything seemed normal, including the ejection process. But once the drive tray was ejected, it again would no longer retract.
I tried troubleshooting this for awhile, but no matter what the motor would never spin in the opposite direction. Pressing the button always causes the motor to eject the tray, even if it's already open.
Putting that aside, I decided to do some more testing with the Samsung CD-RW drive and that's when I ran into another problem. I had previously tested this drive with the TEAC driver for speed throttling. And that works... but only for data. Once I tried testing with CD-audio and the drive would fully spin up, sounding like a vaccuum cleaner in the process. This included mixed media CDs as well as regular audio CDs.
I have no idea why it throttles when reading data, but not with CD audio. Unfortunately that rules out this drive for use, since CD audio is a big reason I want optical drives in the first place.
Now I'm back to square one trying to sort out what optical drives to use with this build. 😒
Reply 171 of 184, by d909
I've had similar eject problems with two different CD drives on an IMB200 motherboard. I think it's the motherboard.
Reply 172 of 184, by Shponglefan
d909 wrote on 2025-03-14, 15:54:
Sorry for the belated reply. I hadn't considered a possible incompatibility with the motherboard itself. I'll have to test drives with other motherboards to confirm whether they work.
Thanks for the tip!
Reply 173 of 184, by Shponglefan
I recently reassembled the original Pentium 4 build with the DFI ITOX G7S620 motherboard. It had been partially disassembled since last year as I was experimenting with a different build using the IMB200 motherboard. I still haven't solved the issues I was having with finding suitable CD-ROM drives with the IMB200 setup, so I'll have to return to that at some point.
The attachment Pentium 4 reassembled.jpg is no longer available
The attachment Pentium 4 reassembled 2.jpg is no longer available
I was a bit concerned with the SSD drives. I have read that SSD drives can potentially lose data integrity if left unpowered for a long period of time. In this case, they had been unpowered for about a year, maybe longer.
After reassembling and booting everything up, it appears everything is still working fine. I tried all the different operating systems installed and they all booted without issues.
The attachment Pentium 4 multi-boot set up.jpg is no longer available
I did make on configuration change to the Orpheus II sound card. One limitation of the card is that in Sound Blaster mode it doesn't support independent mixing or muting of the wavetable header. If I want to use external MIDI modules in conjunction with digital sound from the Orpheus, I can't simply mute the internal wavetable.
The solution is to assign a different MIDI port to the internal wavetable header versus the MIDI out. In this case, I assigned port 300 to the wavetable and 330 for external MIDI. It does mean that any game that defaults to 330 and doesn't allow manual configuration will be forced to use external MIDI. But those would typically be older games that are likely to use the MT-32, which I'd want to use with external MIDI any way.
Reply 174 of 184, by Shponglefan
While I had previously set up and configured most of the operating systems, I hadn't bothered to set up Windows 95 yet. I finally got around to trying to install drivers and get that OS working. I did run into a number of issues in the process.
First issue I ran into was with nVidia drivers. I initially tried installing the 45.23 drivers same as what I used for Windows 98 SE. However this resulted in an error when attempting to access the nVidia tab in the display properties.
The attachment Win95 display error.png is no longer available
I then downgraded to the 30.82 drivers and this appears to have corrected the issue.
The attachment Win95 nVidia properties.png is no longer available
I then ran into a second issue trying to install chipset drivers. It appears that the Intel 865 chipset does not have compatible drivers for Windows 95. All versions of the Intel chipset drivers that support the 865 chipset all require Windows 98SE or better.
Web sites like Retroweb and Phil's Computer Lab listi the chipset drivers as being for "Win 9x", but that is misleading. It looks like Windows 95 specific compatibility stopped at the Intel 845 chipset. Not sure if there is a workaround for this or if it's just a case where the 865 chipset is flat out incompatible.
I also haven't tried installing the Audigy 2ZS drivers, so I've still got a list of unknown hardware in the device manager.
The attachment Win95 uninstalled devices.png is no longer available
On the upside, I did get drivers installed and working for the Orpheus II, Diamond MX300 and Voodoo 2 cards. The MX300 did require DirectX installation first. I installed DirectX 6.1 just because.
The only issue here is that the Ultrasound digital audio playback is bugged under Windows 95. It either results in looping or distorted playback. Ultrasound midi playback works fine though.
The attachment Win95 Audio Video devices.png is no longer available
Reply 175 of 184, by Shponglefan
Ran into an issue a couple days ago where I attempted to power on the system and it gave out a number of beeps and failed to boot. One hard reset later and the system powered up fine.
I did have issues previously where it would occasionally fail to boot which appeared to be the result of dirty memory slots. I had cleaned the slots and thought this issue had been fixed. But perhaps after sitting for a year, some corrosion has reasserted itself. I didn't clean the system when I reassembled it recently.
I also installed Quake II under the Windows 95 install to test out some gaming under Win 95. It appeared to work just fine, especially after patching to v3.20 and updating the 3Dfx miniGL driver to 1.49.
Ran some benchmarks and got the following results (demo1.mp2 map):
The attachment Quake II Benchmarks - Demo1.png is no longer available
I was a bit surprised that the Voodoo2 results weren't higher. I found an old article on Tom's Hardware, where they benchmarked the Voodoo2 at 93 FPS (640x480) and 63 FPS (800x600) with a Pentium II 400. I figured a 3.4 GHz Pentium 4 should be at least on par if not a little bit faster. Though I suppose ~58 FPS at 800x600 is still quite good and definitely playable.
Reply 176 of 184, by Shiftyy
Nice build. It's very similar to mine.I have a couple of questions for you:
Did you ever fix the issue with Orpheus II and GUS PnP not working in games such as Doom? I have the same issue with my two boards, BCM BC875PLG and Advantech AIMB-742, and the MK1869 XTREME rather than a Orpheus II. As a result, I have decided to downgrade to Athlon XP. I believe the GUS PnP is incompatible with all ISA-PCI bridge chips.
Did you manage to successfully install the Audigy 2 ZS drivers in Win95?
Reply 177 of 184, by Shponglefan
Shiftyy wrote on 2025-11-14, 02:56:
No, I didn't. I've tested multiple motherboards and sound cards (including an original GUS PnP) and there does appear to be a fundamental incompatibility with the bridge chip. I suspect it's a driver related issue, because the GUS PnP does work under Windows 3.1 as well as some DOS games and software. Just unfortunately not most.
I haven't tried installing them yet.
Reply 178 of 184, by d909
The workaround seems to be to use a GF1 based gus (the original chip). The PicoGUS is an easy option for this.
Fully functional on IMB200.
Reply 179 of 184, by Shponglefan
I've been testing out a newly released throttling tool aptly named "P4Tool" by OttoPS: [b]p4tool - performance control utility for Pentium 4 / NetBurst[/b]
It has both MSR-based cache disabling and options to enable Debug Store including Branch Trace Collection (BTS) on Netburst CPUs. This significantly reduces processor performance.
One caveat is that this tool doesn't work with EMM386. P4Tool does work with JEMM386, which I used for the second set of benchmarks below.
First I tested a range of throttling combinations (30 total) using 3D Bench 1.0c. Neither EMM386 nor JEMM386 were used in these benchmarks.
The attachment Pentium 4 HT 651 (Cedar Mill) - 3D Bench 1.0c Scores.png is no longer available
These benchmark results show a good range of results varying from Pentium down to 386 levels of performance.
I next tested the Debug Store (DS) option with both 17x and 12x multipliers and compared to actual Pentium 133 and Pentium 90 systems I have.
The attachment Pentium 4 651 (Cedar Mill) vs Pentium 133 vs Pentium 90.png is no longer available
While individual benchmarks varied somewhat, these results indicate the Debug Store option yields performance roughly equivalent to 1995 Pentium era systems.
I further tested the Debug Store option with a couple speed sensitive titles, Descent and Dark Forces. Descent requires throttling or the in-game bobbing effect is far too fast. Dark Forces will freeze if General MIDI music playback is attempted on a system that is too fast.
In both cases, enabling the Debug Store option allowed these games to work perfectly. Descent in-game movement was comfortable and Dark Forces didn't lock up.
I'm impressed with this tool so far. It seems to enable a good range of performance to mimic systems from the early-to-mid 90s, especially when combined with the multiplier options of this Cedar Mill processor.
