Deunan wrote on 2024-08-14, 18:55:
Tempest wrote on 2024-08-14, 18:44:
Is there a way to tell if it's a SS (180K) or DS (360K) drive without hooking it up?
Oh that's easy. It has two heads, so it can't be single sided drive. A closer inspection of the head could also tell you if that's a DD/QD or HD drive.
Yes, but just to be more clear what to look for, looking at your drive view from the top. you can see the "upper" head - this is
the head that is spring pressed against the media when it is inserted, on the side away from the motor.
The lower head is the one on the spindle motor side, which does not raise/lower - you photo shows the upper head
as fairly wide (holds a head) with wires going to it.
A single-sided drive does not have an upper head, instead it usually has a much smaller pad which
presses the media against the lower head, and is not wired to anything.
IIRC there were very few "standard" single-sided 1/2 height drives. I did see a few system specific
specialized 1/2 height SS drives, but I don't think I ever saw one with a standard interface - I did see a
few full-height ones.
I don't have any to show you, but I did find a photo online that shows the "upper" side of
Single-sided drive - note the pad instead of the upper head, compared to the size of the actual
head (lower).
https://commons.wikimedia.org/wiki/File:RX50_ … ssembled_03.jpg
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
