First post, by Major Jackyl
- Member
Hello everyone! Today, I want to pit my MX4000(s) against the MX440. I was thinking about getting opinions about which is better to use, since I've never used a MX440 before, but since I have an open side panel, I'll use my Dell Dimension 4100 for testing. I decided I want to test them in it's companion system, too, specs to follow.
I will be running 3DMark 2001 (1999 doesn't run on the MX4K) and playing Unreal Tournament, Quake 3, and Battlefield 1942. (In windows 98)
Any suggestions for tests to run are appreciated!
The System is spec'd as follows:
Pentium 3 933
256 MB PC133 (2x128)
Sound Blaster Audigy
D-Link TX-530II Rev.F
Single 40GB Hitachi ATA with 2 partitions, dual-booting 98SE and WinXP.
(Other Test system)
Tyan Trinity KT (S2390)
Athlon 1000
384MB PC133 (3x128)
GeForce MX 4000
Yamaha DS-XG
D-Link TX-530II Rev.G
D-Link USB
9GB Quantum (98) 30GB Quantum (XP)
Trinity is currently buried, but has MX4K in it, so I'll be just running that test today. I do have two MX4K that will need to be tested separately. they are both the same, but have differences.
Tomorrow I will run the 4K in the Dell and the 440 in the Trinity (Probably test the other 4K first, so not as much driver-switching). I've found that 45.23 drivers work well with the 440 and 66.94 have been working good for the 4K. 66 drivers work on the 440, but not great. Skipping in Unreal and some glitching is Serious Sam. 66 drivers actually keep 3DMark 1999 from running as well.
My initial impressions of this 440 are good! These systems ran everything about the same, so I feel like the two of them compare well. The 440 is a bit slower in UT running 1280x1024. It skips a beat running Quake 3 in 1280x1024 as well; runs perfect at 1024x768 (same with UT). All settings on high, by the way. BF1942 is unplayable (with bots) at 640x480, 🤣 Better on low settings.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
