First post, by fang64
I'm not sure if this is of any interest to anyone but I've located a copy of Exceed/DOS although requires the use of RSH or DMCP in order to connect it seems. I suspect you'd need a compatible TCP stack probably from beame & whitesides I'd assume. Although not entirely sure I was discouraged a bit once I realized there are no SSH clients for dos with X forwarding and not even sure how anyone would get this work that way since that isn't viable.
For those curious:
https://archive.org/download/exceed-dos
I've uploaded it, it seems some fellow colleagues with old copies did not have anything this old, I found it on some ancient FTP server that hasn't been updated since 1996 that had a copy of it. Surprisingly there are a few apps with it but I'd say not that useful.
Reply 1 of 9, by doshea
Interesting! I imagine the server might listen on a TCP port with no security, so perhaps you could just run something like "DISPLAY=1.2.3.4:0 xterm" on a *nix machine (via a separate connection/console), where 1.2.3.4 is the IP address of the DOS machine, and the xterm will appear on the DOS machine? Obviously this isn't as convenient as having a login prompt from the *nix machine appear on the DOS machine, but it's certainly how I often did things before SSH forwarding came along.
Reply 2 of 9, by Grzyb
Is there anything special in that Xserver?
How does it compare to Xappeal and DesqView/X ?
Nie rzucim ziemi, skąd nasz root!
Reply 3 of 9, by Zup
I worked in a bank that had everything running on a Unix server, and we used Windows NT machines running the hummingbird software to interact with it.
Apart from using it with xterm, we used Uni center to have task control.
I never thought much about it, I assumed that it was the only available X server for Windows.
I'm selling some stuff!
Reply 4 of 9, by doshea
Zup wrote on 2024-08-19, 12:45:
I seem to remember StarNet X-Win32 being pretty popular, maybe because it had a trial or shareware version or something, and I think it was also pretty easy to use. Later I used the X server in Cygwin since it was free and open source, although I think it wasn't quite as friendly as X-Win32.
Reply 5 of 9, by fang64
AFAIK this is the only alternative to Desqview/X that runs natively on DOS, I didn't think about just pointing it directly at the X server via DISPLAY environment variable so I guess you wouldn't need to ssh it over then...
Reply 6 of 9, by fang64
Grzyb wrote on 2024-08-19, 12:26:
I totally wasn't aware of Xappeal, I guess that's a totally different alternative. The only thing I see is possibly different X server features, although Xappeal seems newer...
Reply 7 of 9, by BitWrangler
I suspect you might need xfree86 r6 on a linux box rather than x.org to support it, so might need a pre ~2003ish linux distro to connect to through RSH. I think you might get hints on the oldschool setup with some old howtos, I think there was a "thin client howto", maybe an Xterminal howto that would have a lot of relevant setup info. I am not sure that is the only way to do it, just that it is the easy route to see how it's supposed to work, then you can lift and recompile stuff for a pi or modern distro. Though kernel modules work different than then so might be some rewriting, and then also some kernel archeology to determine what was taken out or broken when and why, wild amount of breakage in the 2005-2015 timeframe, and then 5 years of peace, and the barbarians were back in 2020 wrecking I mean updating things.
Reply 8 of 9, by Gerninator
fang64 wrote on 2024-08-25, 09:21:
Graphic Software Systems (later NCD) PC-Xview was another option. I have PC-Xview 1.1, 1.3 and 2.2 on my shelf. I don't know if the floppies are still readable. PC-Xview 1.X shipped with two server versions. One would run on a 286 in 640k. But would use the EMS page frame or other high memory if it was available. It doesn't appear to support paging into and out of EMS. The ran in protected mode and required 1MB and would only use the lower 640 and any memory above 1MB using the DOS/16M extender. Both supported EGA, VGA and DGIS graphics cards. (I've never seen a DGIS card in the flesh.) It only supported Excelan LAN Workplace for DOS and FTP Software PC/TCP. Version 2.X added 8514/A support and increased the supported networks greatly.
The docs claim a 286+ was necessary. I wonder if the 640K version would run on a V20, or if protected mode was actually required.
Reply 9 of 9, by Grzyb
I have PC-Xview 4.1, from 1992.
