First post, by johnguilfoil
In my many readings, I've found Vogons to be a very supportive network, but feel free to utterly belittle me for this one.
After much searching, I finally found the Dual Slot 1 mainboard that I wanted for my attempt to recreate the Windows 2000 box I had in high school. The board worked perfectly in bench tests. I found the case I wanted, screwed it in, hooked everything up, and POOF. Smoke from the power area--not the ATX but the Aux Power Supply prongs.
It turned out that the chassis I was installing the board in had an extra standoff directly underneath the Aux power. I didn't see it, never removed it, and I believe it shorted on the standoff, because the standoff is blackened.
I want to reiterate that nothing was plugged into the Aux power or touching the prongs from above. A standard 500 watt ATX power supply was being used, and the PSU was brand new, no obvious problems there.
This was a flawless board -- did I just destroy a $500 board that I believe needs to be imported from Germany... by not noticing one standoff or is there anything I can do to have this fixed?
I come, hat in hand, in shame; the latest to smell the magic smoke.
