Reply 1040 of 1290, by appiah4
At this point I can only hope Marmes and Keropi don't sell the guy a card on grounds of being American.
Reply 1041 of 1290, by Steage
I got mine installed in my Win98 PC and I've been having a lot of fun figuring out what it can... haven't even played any games yet.
I skimmed the thread, so apologies if this has already been covered: what's everyone's favorite 2nd (more modern) soundcard to pair with the Orpheus II?
Reply 1042 of 1290, by Shponglefan
Steage wrote on 2024-08-20, 20:43:
I suppose this depends on what you mean by 'more modern'.
For DOS gaming, it pairs nicely with a Creative Labs AWE64. This adds native SB16 and AWE32 support, in addition to everything else the Orpheus II supports.
Beyond that, it could be paired with anything. I'm currently revising my Pentium 4 setup to incorporate four sound cards: Orpheus II, AWE64 Gold, Diamond Monster Sound MX300 (Vortex2), and an Audigy 2 ZS.
The goal is to cover all the audio options for both DOS and Windows 9x.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1043 of 1290, by Socket5Alive
Shponglefan wrote on 2024-08-20, 21:10:
Are there a lot of situations where the AWE32 and/or SB16 make a huge/any difference compared to what the Orpheus cards do? I’m fairly new to sound cards in general.
Reply 1044 of 1290, by Shponglefan
Socket5Alive wrote on 2024-08-21, 00:35:
There are a number of games that use 16-bit samples. Some of them are listed in this thread, but I believe there are others: A List of DOS Games with 16-Bit Sound
For myself, I specifically installed the AWE64 for Crusader: No Remorse. The sound is noticeably better with 16-bit and I ran into sound issues with the FMV sequences using the Orpheus II. The FMV sequences in Crusader are very picky when it comes to sound cards.
Reply 1045 of 1290, by Intel486dx33
USA Seller on eBay.
Reply 1046 of 1290, by Socket5Alive
That same seller sells 32mb (16mb x2) for like $12 of the same RAM with tin plates like the Orpheus as mentioned early in this thread.
Reply 1047 of 1290, by Stormer47
I am so happy to have an Orpheus 2LT with a DreamBlaster. I decided to skip the "regular" 2 with the integrated GUS because I was afraid of all of the complexities with the GUS drivers.
This thing is AWESOME. The DreamBlaster sounds absolutely stunning with General Midi games. The Adlib OPL3 mode is spot on, and I can even hear the same FM-synth artifacts I remember from play games like Silpheed as a kid.
And of course... the MT-32 support. OH... MY ... GOD. It's fantastic. Connected to my modern box running MUNT, it sent shivers down my spine. Games that I only ever heard once or twice in person on my friend's MT-32 in 1988 or in YouTube videos come to life with amazing, vibrant sound. No hum, no background noise, just pure beautiful sound.
I did almost nothing to configure this thing other than run the supplied "Orphinit" tool.
I'm very, very happy with this purchase!
Reply 1048 of 1290, by keropi
glad you enjoy the card Stormer47 😀 thanks for the support!
Reply 1049 of 1290, by igna78
Question for the Orpheus team: I have a Fractal Focus-G case with a microphone and headphone jack on the top; the cable to power these jacks has a plug labeled AudioHQ, but the exposed pinout seems to be compatible with the Orpheus II AC97 header. Big question, can I plug the plug into the Orpheus II AC97 header, hopefully that will work without damaging the board? 😄
Reply 1050 of 1290, by Marmes
If those cables in that case are ac97 compatible, you will have no trouble.
Reply 1051 of 1290, by igna78
Marmes wrote on 2024-08-25, 20:25:
Ok, Thank you very much 😉
Reply 1052 of 1290, by CHA0SHACKER
I suppose this depends on what you mean by 'more modern'. […]
Thats sounds like a resource nightmare. I already had issues getting the Orpheus II alone to work.
AMD K6-III+ 400 ATZ @ 550 MHz 1.8V | Gigabyte GA-5AX Rev 5.2 | 256MB 100MHz SDRAM CL2 | 32GB SSD (SSD370S) | 3DFX Voodoo 4 4500 32MB @ 183MHz | Orpheus II LT with X2GS-SE Wavetable | Gravis UltraSound PnP (clone) with 16MB SIMM
Reply 1053 of 1290, by Shponglefan
CHA0SHACKER wrote on 2024-08-27, 17:40:
Resource management isn't so bad. It's just a matter of reserving the right IRQ and DMA settings in the BIOS for the ISA sound cards.
The bigger issue I'm running into is juggling a pair of optical drives and figuring out how to route CD-audio connections internally. CD audio connections were never designed for multiple optical drives and sound cards.
Reply 1054 of 1290, by x73rmin8r
Shponglefan wrote on 2024-08-27, 19:14:
I got a "Y" cable that was meant to connect two optical drives to a single sound card and hooked it up backwards to connect one optical drive to two sound cards. Seemed to work ok.
Reply 1055 of 1290, by Retromafioso
Really wish i was able to preorder before they sold out, this looks amazing! Will we see an orpheus 3 sometime in the future?
Reply 1056 of 1290, by Socket5Alive
Retromafioso wrote on 2024-09-01, 01:43:
Here’s one available now on eBay. The card is amazing, if you’re on the fence.
REMOVED
Reply 1057 of 1290, by 640K!enough
Nothing I have heard or seen says that any such thing is in the works. I think they finally want to give the little old CS4237 a rest. Of course, I could be completely wrong; they don't report to me. 😉
Reply 1058 of 1290, by keropi
because of min. order quantities (that are a round number) we have a few extra boards so you can still get on it
OrpheusIII will happen in the future - but it will take some time as it needs to be something good 😉
Reply 1059 of 1290, by Kahenraz
A shorter board with onboard memory, please. The Orpheus II is too large to fit into the case I would like to use it in.
