Reply 28200 of 31620, by Thermalwrong
BitWrangler wrote on 2024-08-26, 00:07:Found an additional ... […]
BitWrangler wrote on 2024-03-03, 23:21:In case anyone was under the impression that I just have to turn around and lay my hand on an awesome piece of hardware, today as part of the investigation into "The Soundcard Situation" I turned around and laid my hand on this... Opti 82C931.. maybe the worst SB clone ever produced according to legend... that's if you discount some versions of the SB16 I guess 🤣 ... can it be alllll that bad? I am getting the feeling it might end up in something anyway as soundcards run away when they see me coming or something.
Is there even an ideal spec to curse with this? 96 card so youdathunk the basics would be getting covered by then, might have to stick it in a Win9x build that doesn't DOS around much.
https://youtu.be/lD_ag67tH3I?si=QR3HKA-1qjDhmfRS
But it is non-identical, just the most no-name, only ID is chip markings and Made in China sticker, 82C931 soundcard that you could imagine.
Stupid question though, are these as bad at Adlib as they are at opl3 type synthesis? .... I haven't done a lot of adlib recently, and back in the day I skipped it, stuck on PC honker for my first few years. So in my mind, basic Adlib is kinda schmaltzy chip tune, not sounding much like real instruments, thus I feel it's simpler and hard to screw up.
If it should be the case that they do well at adlib, then I might stick them in XT or 286 class, since optimum games for those don't tend to need much. Though also thinking of pairing one with the RAP-10 in a better machine, as then I get basic 8 bit and hope I can do GM, MPU401, SC etc on the RAP-10 instead of FM.... which is likely in post 93 or so games.
Personally I think there are far worse OPL clones than the Opti-FM of the 925/931 chips, I like my 931 cards in the systems I've played with them in. Check out PC sound legacy's video on it: https://www.youtube.com/watch?v=BCljlMWbbzQ
It's not quite the same as real OPL3 and checking out another video comparing the 931 to an SB Pro 2 it does sound like there's a heavy low pass filter on the FM sound, but I find that works pretty nicely for later DOS games with FM with a sufficiently bass heavy speaker setup.
Has anyone checked it out for Adlib capability for comparison though? I haven't yet but this video has and again it sounds quite similar but with some high frequency cutoff: https://www.youtube.com/watch?v=poZT12wb9PA
Adlib can sound impressive with the right composition, dune's adlib soundtrack or pretty much everything Stephan Picq made. Haven't tried the 931 with those, that'd be a good test of their adlib sound...
