First post, by PolygonYT
Hi. I'm Polygon. But you can call me Poly.
Recently I have been setting up Windows 1.04 on 86Box, until this screen:
https://imgur.com/a/59nZuHU
I select 6, freezes. I select 5, freezes. I want COLOR. Any help?
Cheers, Poly 😁
Reply 1 of 4, by keenerb
what video card does your 86box VM have installed?
Reply 2 of 4, by PolygonYT
[ISA] EGA, 256KB Enhanced Color. (5154/ECD)
Reply 3 of 4, by Ommex
What machine are you using? Does the setup freeze immediately after you select a graphics mode? Because all the setup does is copy the relevant driver into the Windows folder. This might be a problem with the setup disks.
Reply 4 of 4, by SA1988
This is already solved.
