First post, by demiurge
So I have this rare, weird, graphics card, The Metheus 1104 Ultra Graphics Accelerator.
It has a DB9 connector but I don't think that matters. On a newer 586 the screen is just all green, but on a 486 it looks like this:
JUMPER(1)=2
NAME="J8I - Sync Select 1"
JTYPE=INLINE
REVERSE=YES
This jumper is located near the RGB output connector on
the right side of the board. Horizontal sync is selected
by connecting the two left pins. Composite sync is selected
by connecting the two right pins.
JUMPER(2)=1
NAME="J8J - Sync Select 2"
JTYPE=INLINE
REVERSE=NO
the right side of the board. Vertical sync is selected
by connecting the two pins. Disable by removing this
jumper
JUMPER(3)=2
NAME="J8L - Monitor Sel 1"
JTYPE=INLINE
REVERSE=YES
This jumper is located on the right side of the board.
Non-interlaced is selected by connecting the two left pins.
Interlaced is selcted by connecting the two right pins.
This jumper must also be moved with jumper J8M.
JUMPER(4)=2
NAME="J8M - Monitor Sel 2"
JTYPE=INLINE
REVERSE=YES
This jumper must also be moved with jumper J8L.
JUMPER(5)=5
NAME="J8K - CGA Emulation"
JTYPE=PAIRED
VERTICAL=YES
REVERSE=YES
Connecting these two pins will enable CGA emulation. Remove
this jumper to disable CGA emulation.
The only other information on the web about this is here: https://x.com/TubeTimeUS/status/1052350013840314369
What could be making this green?
