Reply 54120 of 57048, by AGP4LIfe?
- Member
Ozzuneoj wrote on 2024-08-28, 21:37:Recommended specs back in those days meant "The game will run at 25fps most of the time." […]
AGP4LIfe? wrote on 2024-08-28, 18:08:I didn't even think about it being CPU bound since I was 150Mhz over the recommended specs... […]
Ozzuneoj wrote on 2024-08-28, 17:09:Descent III will run much better on a faster CPU as well. I noticed a pretty huge difference going from a Pentium II to a Pentium III 850, even with a Voodoo 3.
Unfortunately the board only has dip switches up to 500Mhz 🙁 so I can only go up 50Mhz more... unless I try to just jam a 700Mhz PIII in there and see what happens.. hmm..
Graphics settings also have a pretty huge impact on that game, and some scenes are significantly heavier than others.
Also, if you put a PIII with a higher multiplier in there, if it works at all it will run at that multiplier because these CPUs were mostly multiplier locked. So, if the board is set to 500Mhz (5x100), and you drop a 933 (7x133) in there you'll still get a 700Mhz PIII (7x100). If you own a slotket of some kind to use Socket 370 CPUs that would be a big help.
Interesting I'll give it a go!! I also went against my better judgement and went all the way with the GPU and bought a Radeon 9100 PCI 😁 I've heard they are hard to find. Hopefully it works, I'll know next week when it arrives. 😀
Also let me know when you want to sell me that FX-57 ;D any news??
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
