First post, by ahyeadude
Having a strange issue with my Diamond SpeedStar 64 in Windows 3.11.
I'm getting random red pixel artifacts and corruption while using the vendor provided driver. I've tried multiple versions of the Diamond and generic Cirrus Logic drivers with the same results. The standard VGA driver looks completely fine. Running in 640x480x256. What's odd is that it isn't corruption on the VGA output, but in Windows? Below are two Alt-Print Screen direct screenshots.
Standard VGA Driver
The attachment VGDRIVER.png is no longer available
GD5434 v1.24
The attachment CLDRIVER.png is no longer available
Reply 1 of 41, by ahyeadude
I did some more digging. It only happens in 256 color mode (even at higher resolutions). Higher color depths don't exhibit the issue. Also don't have this issue in Windows 95A on this machine. So seems driver related and somehow color dithering related at 256 colors?
Reply 2 of 41, by ahyeadude
Tested some more stuff:
- Confirmed my 2.02 VGA BIOS matches copies available online. Same checksum
- Tested all 2mb of vram using X-VESA 1.02 PASSED
- Different waitstates and bus timings. Still have the issue in 256 colors in Win 3.11
- Another driver I found. Still have the issue in 256 colors in Win 3.11
- 86box trying to match this system as closely as possible (ISA SpeedStar 64 2.02 BIOS is available). Does not exhibit the issue with the same drivers I tried on physical hardware
So it has to be some issue with the hardware. But, with the vram testing all good and no other issues using this card outside of the Windows 3.11 256 color issue, I'm at a loss. It appears the corruption is happening during an acceleration function that ends up in the Windows framebuffer since I can capture it directly with a screenshot. But, unsure why it wouldn't show up at 16-bit or 32-bit color modes.
Reply 3 of 41, by BitWrangler
I seem to remember something weird about CL cards and font caching, maybe having to disable it, but details real foggy.
Reply 4 of 41, by Grzyb
Yes, it would be a good idea to experiment with the "Hardware acceleration" setting...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 5 of 41, by clb
I've got two copies of this Diamond Speedstar 64 VGA card. It is a fantastic card. Here's mine:
The attachment Diamond_SpeedStar64-CL-GD5434.jpg is no longer available
The attachment CL_GD5434_BIOS2.01.jpg is no longer available
Here is a snoop scan from the first card that has the v1.01 BIOS:
The attachment SNOOP.png is no longer available
In that scan, a bug about PCI palette snoop register is mentioned. That only relates to use of the Feature Connector port, so that can be safely ignored. (There is a BIOS bug that brings an incompatibility to this card when using it with CRT Terminator, but that can be worked around with a PCI TSR program)
I remember using my card that has the V1.01 BIOS in Windows 3.1 before, and it worked ok.
Reply 6 of 41, by clb
Now set up my V2.01 card in my 486 PC, and set it up with the CL-GD5434 Windows drivers. I have a file "cirrus_logic_gd5434_(win3.1,_nt_3.1_-_3.5_+_utility).rar" that I've downloaded somewhere (probably from vogonsdrivers?):
The attachment CL-GD5434-driver-installation.png is no longer available
Used default settings, except changed monitor brand to "Other brand". I think the only thing that does is it "unlocks" all the options in the other dropdown menus.
The attachment CL-GD5434-driver-settings.png is no longer available
Then set 1280x1024@87iHz:
The attachment Win3.1-1280x1024-87iHz-256c.png is no longer available
In this test, I was unable to observe the red artifact pixels at least.
Also this card does not provide a boost in Minesweeper skills it looks like.
Reply 7 of 41, by mkarcher
ahyeadude wrote on 2024-08-11, 19:32:
I guess you have memory issues that only appear if memory is accessed at top speed. The ISA bus is too slow for top speed memory demands, so the issue only appears when using the built-in accelerator of the CL-GD5434 chip, that is only in windows. Access patterns of the accelerator may depend on the color depth, which is why you might observe the issue only on 256-color mode. I know there are tools to adjust the accelerator/memory clock on CL-GD542x chips, and you might find a tool for the CL-GD5434 as well. Try if the issue disappears at lower memory clocks. Also, if your card is upgraded to 2MB, you might try without the upgrade memory chips to reduce the load on the memory address/control lines.
Reply 8 of 41, by ahyeadude
Removed the 2 memory chips in the sockets and the issue persists. So it must be the memory soldered to the board.
I removed the two soldered chips with hot air, no issue.
Can I install memory into the sockets with no memory populated on the board? I want to test my chips before soldering them...
Reply 9 of 41, by wierd_w
Since it does not happen in high or truecolor modes, only in palletted mode, I'd suggest it's not a vram issue, and is likely a pallete register issue.
Reply 10 of 41, by ahyeadude
Soldered on the new memory to the mainboard and still have the same issue.
wierd_w wrote on 2024-08-30, 19:38:
The color modes all look fine in VESA modes. No issue with DOS and 256 color games. Even the SVGA driver in Win 3.11 looks fine at 256 color. It's only the accelerated Cirrus/Diamond drivers in Windows 3.11 that causes the corruption. Is the palette register integrated into the chip for this particular board?
Reply 11 of 41, by clb
I think these are the drivers that I used in my test: https://www.vogonsdrivers.com/getfile.php?fil … 864&menustate=0 . I suppose you gave that driver a try already?
It's hard to imagine that anything else could be the fault than software driver, if all other programs write the palette correctly. But hard to say.
Reply 12 of 41, by clb
ahyeadude wrote on 2024-08-31, 20:27:
Yeah, the palette RAM and RAMDAC are all fully integrated on the Cirrus Logic chip on this graphics card.
Reply 13 of 41, by ahyeadude
This card was made in the 30th week of 1996, A3 revision. Most of the ICs have 96 date codes. Maybe they made some late revision changes that broke compatibility with older OSs? NT 3.51 corruption is similar to Windows 3.11, but worse.
Here's a direct screenshot from NT 3.51. Using the driver from the link clb provided (I've also tried that one in 3.11, same result). I moved the windows left and right a bit, it makes the red corruption worse. Also font corruption is present in NT 3.51.
The attachment nt351.png is no longer available
Reply 14 of 41, by ahyeadude
clb, could you post a dump of that 2.01 bios? I can't find anything but 2.02 out there.
Reply 15 of 41, by clb
Yeah, hold on a moment..
Reply 16 of 41, by clb
Diamond SpeedStar 64 Cirrus Logic CL-GD5434 BIOS v1.01
The attachment SNOOP-strings-SpeedStar64.png is no longer available
BIOS CRC32: E91A421Fh
The attachment Diamond SpeedStar 64 BIOS v1.01 ROM.zip is no longer available
Reply 17 of 41, by clb
Diamond SpeedStar 64 Cirrus Logic CL-GD5434 BIOS v2.01
The attachment SNOOP-strings-SpeedStar64-v2.01.png is no longer available
BIOS CRC32: 8091A10Ch
The attachment Diamond SpeedStar 64 BIOS v2.01 ROM.zip is no longer available
Reply 18 of 41, by clb
I double-checked also my Diamond SpeedStar 64 v1.01 card in Windows 3.1, and I do see that it does not get bad palette data with that card either:
The attachment WIN3.1-800x600@75p-256c.png is no longer available
Really at a loss to think what would be the cause here.. Got any other motherboard that you could try to install that video card into? Or reinstall Windows 3.1 altogether from scratch?
Reply 19 of 41, by ahyeadude
Thanks clb!
I tried to install it into my Socket 7 motherboard (ASUS P/I-P55T2P4) and it wouldn't post. Not sure what the issue was there.
I've got a hunch, there are two different versions of the board, some with the old Diamond logo on the silkscreen, some with the new. I have the old Diamond silkscreen and an older 5434 chip. But, all the examples online show that with a 2.01 bios versus my 2.02. Mine is likely some sort of transition card. Trying 2.01 is a long shot, but it's something to try.
The attachment SS64.jpg is no longer available
Ignore the datecodes on the memory, I soldered newer chips on as mentioned previously.
