Reply 20 of 23, by jakethompson1
That blog suggests there are parts of that vi that assume ss=ds in situations where they aren't, so it scribbles randomly in memory.
It's no surprise you're having issues.
Reply 21 of 23, by p.kapica027
I just loaded COMMAND.COM from MS-DOS 6.22 into a hex editor and, aside from the copyright string, I couldn't find a single reference to "MS-DOS" or the version number embedded in the binary. This is in contrast with the MS-DOS 7.1 COMMAND.COM, wherein the string "Windows 98 [Version %1]" appears twice. I wonder how the %1 refers to the string "4.10.2222" (or whichever version of Windows 9x), and if the bug I'm experiencing is a result of Watcom VI just not being able to handle the newer format; possibly historical code not updated or tested with MS-DOS 7.1?
Reply 22 of 23, by Ringding
Very likely, it has absolutely nothing to do with DOS 7.10 or command.com; it’s just that in your particular setup, vi tends to corrupt the specific memory area where the version string happens to reside.
Reply 23 of 23, by AlaricD
Grzyb wrote on 2024-08-30, 22:35:
AlaricD wrote on 2024-08-30, 21:15:
There is, and you may also run into all your MS-DOS externals reporting "Incorrect DOS Version".
Really?
Don't they use INT 21h to obtain DOS version, rather than invoking the VER command?
When I tried it under MS-DOS 2.11.13, none of the externals worked anymore. Had to copy command.com from a boot diskette to fix it. This was in like '91 or so, so I've forgotten some of the details. (I think I used debug to edit the file, not a hex editor. Could've been part of the problem.)
