First post, by Postman5
Hi
I tested several dozen Voodoo2 in the 3DMark99, and I always see strange effects.
I don't understand why this is.
It only appears on Voodoo2 of any manufacturer.
Reply 1 of 10, by dominusprog
So you've tested every single brand of the Voodoo2 card in existing? You have to provide more information, also a photo of the card can help.
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 10, by ux-3
Which version of 3Dmark99 did you use?
Frame buffer? Resolution?
I can run my Creative Labs V2 with 3Dmark99 max without problems.
The non-max version does tend to have issues with many older 3d cards.
Retro PC warning: The things you own end up owning you.
Reply 3 of 10, by Postman5
ux-3 wrote on 2024-09-03, 10:46:
3DMark 99 Max Pro - Build 200
Frame Buffer - Triple
Z-Buffer Depth - 16 bit
Resolution -800*600, 16 bit color
CPU Optimization - Intel(r) processor
System: Abit VA6; Pentium II-400; 256MB; S3Trio64V2/DX; Windows98, FastVoodoo 2 4.6
for example
https://www.youtube.com/watch?v=B_69N1G01lk time: 1:11, 1:37
https://www.youtube.com/watch?v=Bur2L80Wljc time: 4:53
These videos are not mine and were posted a long time ago.
Reply 4 of 10, by leileilol
Try using only official 3dfx drivers instead of FastVoodoo
Reply 5 of 10, by Postman5
leileilol wrote on 2024-09-03, 22:05:
3dfx Voodoo2 V3.02.02, latest reference Driver
2 х Voodoo2 12MB SLI
800*600; 1024*768 - no changes compared to the driver FastVoodoo 2 4.6
I tried to speed up it to 100 MHz and slow it down to 85MHz - also unchanged
Reply 6 of 10, by Imperious
What refresh rate are You running at? That's the effect You would get on a crt if It is out of sync. Maybe try setting the monitor driver as LCD not CRT.
Try 60hz if not already at that frequency.
Reply 7 of 10, by Postman5
The image in 3Mark99 is mainly formed by Voodoo, and only when passing the "Synthetic CPU 3D Speed" test is it formed by the 2D video card, Voodoo is inactive. This effect, like "line failure", occurs when switching from the 2D video card to Voodoo, which begins to form the image of the "Fill Rate" test.
But I do not know how to set the frame refresh rate for Voodoo in 3DMark99.
For the 2D video card (S3Trio64V2/DX) I set the refresh rate to 60 Hz. No changes.
Reply 8 of 10, by Nexxen
Postman5 wrote on 2024-09-04, 08:35:
Have you been any further in identifying the reason?
I have this issue on 2 V2, exact same. All games just run fine, I have no problems at all.
With a S3 Virge and single buffer, I get flickering.
https://youtu.be/pfGrxCShbHQ
It's awfully slow w a P1 233 MMX.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 9 of 10, by Postman5
Yes, when testing a large number of Voodoo2, I noticed that this effect occurs only on Voodoo2 with DAC ICS5342-3. On Voodoo2 with DAC TVP3409, this effect does not occur. Probably, these DACs have some differences in the internal architecture.
Nexxen wrote on 2025-02-10, 02:46:
Regarding the image quality in Single/Double/Triple buffer. The worst is "single buffer", the best is "triple buffer". Choose "double buffer" or "triple buffer" - and the picture will become more beautiful.
Reply 10 of 10, by Nexxen
Postman5 wrote on 2025-02-10, 13:22:
Mine are both ICS. This confirms.
Could be that TVP is also a better performer than ICS?
Maybe the ICS needs some extra code lines to operate correctly at "single"? This is a hard one for professionals to dive into. Anyway all the games I've tried work 100%.
For reference:
https://www.alldatasheet.com/datasheet-pdf/vi … TI/TVP3409.html
https://retronn.de/ftp/docs/pc_hardware/DACs/ICS5342.pdf
