First post, by voodoodrul
So I have a few Win98SE machines, including a P3 600 Slot 1 440BX and a P3 1ghz Coppermine on an i815EP board (Intel D815EEA). Both of these exhibit the same issue - on a clean install, after installing chipset drivers, when DMA is enabled for the primary hard drive (spinning rust) the shutdown process seems to cut the power a few milliseconds too soon. This means it doesn't always finish flushing caches and doesn't mark the drive as clean. Scandisk runs on the next boot. msconfig->General->Advanced->Disable Fast Shutdown does not by itself help.
I found only one workaround that allows me to keep ACPI and DMA enabled - I marked the primary OS drive as "removable" in device manager. This has some side effects where applications may not allow running on what it thinks is removable media. I think most folks that run into this issue either disable ACPI, DMA, or just ignores/disables scandisk. There's something about marking the drive as removable that changes the cache flushing behavior (even with write behind caches enabled for removable media). Maybe it just changes the order of operations, flushing removable media first, then running the rest of the shutdown process.
Anyone have thoughts on this?
Reply 1 of 7, by wbahnassi
Never seen this behavior before.. so can't help. But your theory on flushing removable media earlier in the shutdown process makes sense to me. Did you try with platters from other vendors?
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 7, by Ringding
There was a hotfix for this back in the day.
Reply 3 of 7, by Ringding
It is called 273017usa8.exe
Reply 5 of 7, by myne
Just go to windowsupdaterestored.com
I built:
Reply 6 of 7, by voodoodrul
Awesome thanks all. I have tried other drives, it seems to be speed related as ridiculously slow drives don’t exhibit the issue, and ssds are fast enough they flush caches almost instantly anyway. Just a weird middle ground of performance where it shows up.
Reply 7 of 7, by chinny22
One of the reasons I partition the drives and only make c:\ 2GB.
Much quicker to let scandisk run on a 2GB drive then 20GB!
