Reply 20 of 24, by DudeFace
Mondodimotori wrote on 2024-09-09, 15:43:
DudeFace wrote on 2024-09-09, 15:28:
i only picked that one up as the shop is reputable and they've sold a lot of that model, if i'd seen it on amazon or ebay i woul […]
i only picked that one up as the shop is reputable and they've sold a lot of that model, if i'd seen it on amazon or ebay i would have passed on it being an unknown brand, i think the one you picked up from a local shop was the best call at least if its not up to the job you can always return it, just becareful buying unknown brands from amazon or ebay, my dad bought one from amazon, an unknown brand which looked nice and had braided cables, turned out to be some cheap shit from china, it was light as a feather like there was nothing inside it, i've had cheap known brand psu's that seemed more solid, anyway i looked up the one he had and someone had tested it to find out it wasnt putting out the wattage that was stated, i told him to throw that shit in the bin.
i did use it once to test a motherboard i flicked the switch on the back, it sparked and cracked and the internals of the switch failed, completely gave out with its first use. absolute joke!, i then threw it straight in the bin and picked one up from the local shop.
as for your enermax they are apparently decent, ive got a modu82+ thats been in my pc since 2015, got it from a place i worked building systems, the client changed their mind and i got it free still new, tho seems they were sold in 2008 so it was probably sat in its box on a shelf for 7 years before i got it, still good after all this time, also i noticed the fan spins after powering it off, didnt know it was a feature just assumed it had good bearings in the fan, also last week i picked up a pc with an enamax ELT620AWT thats got 28A on the 3.3v and 32A on the 5V.
i would say recap your psu if you think its worth keeping, using it as is should be fine and if it does blow it wont cause any damage to you board unless you do what my dad did and plug the floppy power into the onboard fan header. 🤣. he blew the psu and also a trace on the motherboard, it burnt a piece of the copper away to nothing and some of the coating on the motherboard, i bridged the gap with some solder, it worked and he used it for a few more months till i built him a new pc.
Yeah, they're supposed to be between the best brands for Socket A PSUs. I've actually started looking for repair shops around my city, just to get an estimate for the reapirs (if there is something to repair). But they've been asking me for the electrical and circuit diagram of the PSU, so that they can pin point what needs to be fixed, instead of disassembling the whole unit to look for issues, wich would exponentially increase the price of repairs. I may still end up bringing it to them, maybe by actually seeing and hearing the whine, they can pinpoin eventual issues more accurately.
it could be whining coming from the caps or even the transformer which could also be down to the caps, if it was me i'd have a go at replacing them myself should be easy enough even with a cheap soldering iron, since its small you might not be able to pinpoint which caps are at fault so may be easier to just replace all of them, prob wont cost more than 20 euros, a few years back i replaced some caps on a power board in an old lcd as the back light stopped working, for a while the caps were screeching eventually the screen went blank, i couldn't pinpoint which caps were at fault so i took the back off the tv and powered it on and stuck my ear close to it and replaced the caps in that area of the noise.
i think i spent about £10-15 on caps, prob not worth it for most, but as i used to work for a company repairing electronics for a major retailer, and the tv i had was one of the models i used to fix i had some nostalgic attachment to it, most people are wary when it comes to fixing any kind of power supply, should be fine as long as you're careful, i used to shock myself regularly sometimes twice in one day usually while replacing switches on the backs of tvs, forgetting that its still plugged in. 🤣 a quick jolt of 240v isnt so bad, it will wake you up in the morning, the worst one i got was from the back of a transformer, i had a tv plugged and powered on, i leant over my bench and my finger touched 2 points on the back of the transformer and the shock went straight up my arm into my chest, usually it wouln't go past the elbow, that one must have been at least 400v, it burnt two small holes in my finger and 3 under my arm, i'm still here tho.🤣
as long as you dont touch anything inside while its plugged in there s no serious risk to injury, it can still retain a charge after being off for a while so try not to touch the transformer or caps with your bare fingers. when i used to replace power boards in lcds right after turnng them off i'd remove the board by the edges, sometimes i'd get a shock but only a small tingley buzz nothing bad, infact a static shock off a hand rail or a person feels worse, if in doubt look into how to discharge it or wear a pair of thick rubber gloves like some marigolds.
Reply 21 of 24, by momaka
Mondodimotori wrote on 2024-09-08, 15:03:
Under spoiler the video and five of the pictures I've took. If more are needed, I'll provide, the PSU is still outside the sistem and readily available. I've made sure to disconnect it and not touch anything inside. Just looking.
OK, I just took a look at the pictures (and also viewed the video, but I'm on my laptop and couldn't hear the whine all that well over the laptop's fans).
The whine doesn't appear to be anything too abnormal, though. I've had a few ATX PSUs over the years that produce similar whining noise, despite being recapped. All of these are still in service and working fine. So whining from the 5VSB isn't necessarily a bad thing. Nevertheless, I can't say if you should ignore it yet or not. In particular, your Energmax PSU appears to be very similar to an Enermax Liberty ELT400AWT I got some years back for free with its wires cut and a label on the PSU that said "broken". It tuned out the PSU just had a few bad electrolytic capacitors inside, including the 5VSB rail... hence likely why someone labeled it as "broken". All I had to do was replace the bad capacitors and voila, the PSU was working fine once again. What's funny is I didn't even have the right capacitor sizes at the time, so I stuck whatever (reused/old) caps I had on hand that seemed to be "close enough...ish". Nevertheless, this was good enough to get the PSU working. In fact, now I remember I made a post about it on badcaps forums (link here, as I did with many of my other PSUs.)
That being said, it's not a given that the caps in your Enermax PSU haven't drifted (or are starting to drift) out of spec. Generaly, CEC-holdings PCE-TUR and PCE-TUL caps are pretty good about bulging when they go bad, so there's a chance they are indeed OK if they aren't bulged. In any case, you should have a closer look at them when you get a chance. To do that, you'll need more than a multimeter - you need one of those "component/transistor testers" found online (ebay, Ali, Amazon, etc.) They have a function to test capacitance and ESR, which are two of the most important parameters that can tell you if an electrolytic capacitor has failed or not.
Thus, the three simplest options I can suggest to you are as follows:
1) Get a multimeter and some 12V car/auto incandescent or halogen bulbs (preferably rated around 10-20 Watts). Using some wires and/or small jumper cables, connect the 12V bulbs to the 5VSB rail, adding one at a time. Use the multimeter to measure the voltage on the 5VSB rail to see how badly it drops. If the caps on the 5VSB circuit are bad, typically the 5VSB circuit will start to whine even more / louder and the voltage usually will drop a lot (<4.75V.) But if nothing changes and the 5VSB seems stable with good voltage close to 5V, then the whining may be normal for your PSU.
2) Get new caps for the 5VSB circuit specifically and just recap that. As mentioned by CharlieFoxtrot, the 5VSB circuit is the one that is always On when the PSU is plugged in and also the source of the whining noise you hear. If new caps on the 5VSB don't stop the issue, then it's normal for the 5VSB circuit to be doing this. Unfortunately, this is one of the very few cases where I didn't do a complete part breakdown of what caps are installed into this PSU, so I can't tell you exactly the values of the caps for the 5VSB. But going from my post on badcaps, there seem to be only two caps on the 5VSB output (which is actually pretty common in most designs). They are not visible in the pictures you provided, but likely should be "in the back", close to the ventilation holes in the upper-right corner of the PSU when using this picture of yours as a reference.
For the first cap, I used a 1500 uF cap and for the 2nd a 1000 uF cap. If memory serves me right, the 2nd cap actually had a smaller capacitance value, but from experience working on PSUs before, it's usually no problem (if anything, it's GOOD) to actually increase the capacitance a little, if space allows. So for the 5VSB, you can grab something like a United Chemicon KY 10 2200 uF cap (pretty common) or Rubycon ZLH 6.3V 2200 uF or .... something along those lines (just preferably a Japanese capacitor brand and "medium" low impedance / ESR) - that's for the 1st cap. And really the same goes for the 2nd cap: just something in the range of 680-1000 uF and 6.3V or 10V (or even 16V)... again, either Chemicon KY or KYB or KZE... or Nichicon HE or HW... or Rubycon ZLH or ZLQ or ZL or ZLJ... or Panasonic FR or FM or FS. All of these are known reliable brands/series of caps suitable for 5VSB (or any other circuit that uses "flyback" design) use.
3) Just use the PSU and hope for the best. 😁 Either that or not use it.
My personal hunch is that the PSU 5VSB is probably fine with the current caps... at least for now. But without testing anything, we can't know for 100%.
With that said, if getting the equipment and/or caps needed to go with option 1 or 2 above are not too incovinient and you really care about your old hardware, then you should get the PSU checked out and/or recapped.
So... It also may be the case to get protective glasses and a fire extinguisher ready...?
If you ever get into the hobby (if we can call it that) of repairing power supplies, then safety/protective glasses should surely be on your list of items to have. Fire extinguisher - nah, that's over the top.
I remember when I tested my 1st recapped LCD monitor (internal PSU) and was so scared to power it on. I had safety glasses on, two bottles of water (in case of fire... and yes, electrical fire + water = not good... but only if things are plugged in and powered 😀 ), and one hand on the power cord, ready to yank it out at the slightest event (hence the water bottles.) Turns out... nothing wrong happened. My recapped supply worked just as it should... and still does to this day. 😀
Mondodimotori wrote on 2024-09-08, 19:56:
EDIT: Here's an idea that went thorugh my mind recently: What about industrial power supply? Let's ignore the price for now (yikes), and let's look at the datasheet for this one: https://www.bicker.de/files/downloads/datenbl … t/bea-635_e.pdf
Just a waste of time and money to look into these, or there could be something here?
Mostly a waste of money.
A recapped OEM PSU (Delta, LiteOn, HiPro/Chicony, Bestec, AcBel) can provide more good years of service than you'll ever care to put on it.
Also, without seeing internal pictures of that "industrial" PSU, I can't really say how good it is.
In the modern world that we are in today, there's all kinds of companies. Some do really give you what they say they will, and others just slime and sleeze around, hoping to give you just "enough" of a product that you don't notice its inferior. So case in point with the above industrial PSU: it could be a really nice unit or it could be just a hair better than your typical gutless wonder crap PSU, with the company just hoping that nothing would go bad in the warranty that they give it and/or happily replacing it when it does.
Mondodimotori wrote on 2024-09-09, 13:39:
QUESTION: where would I need to look to find the electrical diagram of this PSU?
You probably won't.
Schematic diagrams for ATX PSUs weren't generally released by manufacturers to anyone. The only ones that can commonly be found are for the older half-bridge "generic / gutless wonder" designs, and these were typically dissected / reverse-engineered ones (i.e. someone had this PSU and drew the schematic by looking all of the parts and drawing it on paper / in CAD. I've done this to the 5VSB circuits of many of the cheaper / no-name ATX PSUs that use a 2-transistor design. It is time-consuming, though.
For the new one, I dind't perform hard CPU stress test, like prime 95, but only 3D gaming and benchmark stress test, where the rail would drop to a sensor reported 4.66 (not read with mulitimeter) but the benchmarke kept running without issues for more than an hour. Of course, it may also be bad readings from the sensor, wouldn't be the firt time I encouter this (on the 370 mobo, the CPU temp sensor must be fucked because it always report 51°. No matter if immediately at boot or after hours of intense use. Ant it's a Celeron 700 with a decent cooler in it! With the case remaining nice and cool to the touch).
Yeah, motherboard sensors on old boards, particularly the voltage ones, are to be taken with a grain of salt (or more) usually.
If you didn't measure that voltage drop on the 5V rail with a multimeter, then it's not worth worrying about.
Yeah, unfortunately I went and check even those top of the line 1000+ watt PSUs from reputable brands: All of them don't go over 20 amp on the 5V and 150 watts combined anymore
I keep seeing this here (Vogons) over and over again.
25 Amps or 30 Amps on the 5V rail is not some magic number that is absolutely needed to make a socket A system work. In fact, that's overkill.
In most cases, an honest 15-20 Amp rating ought to be just enough. Well, 15A might be a little low for the late + high-end Athlon XP builds (OK for a low-power Duron or low-end Athlon XP under 60W TDP). Dual socket A (Athlon MP/XP) is where a strong 5V rail really is needed. That or when a high-end socket A CPU is used in combination with these specific video cards: Radeon 9500/9700/9800 (R300-based), as these suck most of their power for the GPU from the 5V rail is well.
With that said, what is needed is a PSU that "prefers" to supply most of its power from the 5V rail rather than the 12V rail - i.e. 12V rail won't go out-of-spec high or 5V rail go out-of-spec low with a heavy 5V load.
Modern PSUs - be it "new" forward-converter -based designs or "old" half-bridge -based designs - are usually tweaked for heavier draw on the 12V rail. Case in point is this gutless wonder from 2019. Yeah, it's "new", alright - as in built recently. But it's based on an old half-bridge design, and group-regulated while at it (as is normally the case... which means the PSU can either be tweaked either for heavier 5V use, heavier 12V use, or somewhere in between with compromises.) In my tests, the PSU did very poorly with any 5V-"heavy" loading - the 12V rail drifted above 12.6V while the 5V rail sagged hard. So much for those "25 Amp" ratings on the label for the 3.3V and 5V rails. Then again, not like those numbers were ever possible, since the 5V and 3.3v rails each only have a 20 Amp rectifier.
On the other hand, this PSU did OK with a heavy 12V load. IIRC, I tested it with up to about 18 Amps on the 12V rail (over 200 Watts) and the 12V rail was happy while the 5V rail didn't climb up too much. So this PSU would do acceptably well for a modern low-ish power PC.
Thus I stand by my argument that I made in another thread here somewhere, that high-current ratings on the 3.3V and 5V rails of modern PSUs are either bullshit or not achievable in any practical scenarios... or at best, just not great for your PSU long-tern (i.e. in cases where the 5V and 3.3V rail are DC-DC based from the 12V rail via buck-regulator modules, as the modules themselves may be prone to over-heating when being loaded down near their rated specs.)
DudeFace wrote on 2024-09-09, 14:07:
Brand: Arctic Blue+
🤣 It's like a name mixup of Arctic Silver and FSP BlueStorm series PSUs. 🤣
Probably build by the same Chinese factory that sells the same PSU to 100's of other "no name" companies, each with their own name/logo/brand slapped on the label.
Not necessarily saying it's a bad PSU, though. How capable it is depends on how much the reseller / company on the label paid to the Chinese factory for its particular configuration.
Of course, even the best builds will be full of cheap electrolytic caps. So past 3-4 years of use (if you are lucky), you may want to pull it out of service and recap it.
Reply 22 of 24, by CharlieFoxtrot
momaka wrote on 2024-09-11, 13:52:
I keep seeing this here (Vogons) over and over again. 25 Amps or 30 Amps on the 5V rail is not some magic number that is absolut […]
This is absolutely correct, 25A or 30A is not a magic number or a requirement. But you also pointed out the problem with ”modern” PSUs that they aren’t generally well suited for heavy 3.3V or 5V loads so their specs doesn’t necessarily tell you that much how they actually perform with these vintage setups. In this sense the claim ”25A is needed” has some validity, although it is of course simplifies the issue a great deal. With something like 25A you can perhaps expect performance and some headroom which is always good to have and you can for example add those Radeon cards to your system without worrying too much. You also always have to take into account the transient spikes during the power on etc., so if PSU is near its limit, you may have situations where you experience instability when rails dip for a short moment because they are simply overloaded.
So yeah, 20A is generally just fine as a raw number, but it just depends on the overall system configuration and even more how the PSU is designed. Latter is something that isn’t often very obvious, because manufacturers don’t usually provide this information. That is the reason why people often recommend the 25A as something that SHOULD at least provide enough power for 5V heavy configurations although as you said, it isn’t a gurantee either. But this makes something like 15A or 20A even more questionable, if PSU is of similar design and just can’t handle the 5V and 3.3V loads very well. And because I personally don’t want to spend my time finding proper ”modern” PSU, I just use recapped vintage ones and they of course often have something like 30A at minimum on these rails even though that kind of amperage isn’t even required. They just work and I can throw pretty much any MB or GPU with those PSUs and not experience any problems.
As I wrote earlier, for socket A systems a good option always is to build the system on a motherboard with 12V CPU VRM and this removes much of this problem and a decent modern PSU should be completely fine.
Reply 23 of 24, by DudeFace
LOL It's like a name mixup of Arctic Silver and FSP BlueStorm series PSUs. LOL Probably build by the same Chinese factory that s […]
Brand: Arctic Blue+
yeah this one is made in china but it seems a good quality "made in china", that psu my dad bought was like the one you mentioned it was gutless, as in nothing inside it, that was cheap shit "made in china" i forget the make, i remember it was black and green, i checked amazon and it could have been a JUSTOP brand, i read a review someone said it kept sparking and not putting out the power that was stated, same problem i found. 🤣
anyway seems even supposed quality psu's can have problems with poor caps, i looked up the enermax i picked up in a pc recently its a Liberty ELT620AWT from 2006, reviews say the early revisions were know for going pop, if OP's is from the same era then he must have bad caps, i wont leave mine unattended, anyway the enermax mdou82+ i have is 16years old, no problems so far.
Reply 24 of 24, by Mondodimotori
Yeah, I ended up using that modern PSU in the socket 370 build. The Pentium III I plan to use pulls very little power compared to the Athlon. Of course, I also should get a multimeter to actually check how much voltage it drops.
I hope that adding a period correct GPU won't also tank the performances on the 5V rail. At that point I'll just set it aside for the next LGA 775 build.
CharlieFoxtrot wrote on 2024-09-12, 08:32:
Sorry for the late update, but I had the flu this past week and couldn't do much.
For now I ended up finding a local small electronic repair company that accepted to take in the PSU and take a look at it. I mentioned them that it could be the 5VSB, they'll take a look and, if figure it out, make an estimate of how much could it cost (they told me that, without schematics, it could be hard to pinpoint the issue, and they would need to disassemble the whole unit, wich would increase labour costs). In the meantime I'll also start tinkering with older electronics that can be "sacrificed" to learn how to solder myself.
Afterall, I don't plan to build another Socket A sistem for Win9x. If this fails (and, like all electronics, it eventually will), I'll just use an Intel based or a more modern Athlon XP with 12v CPU VRM, so I can use any well known modern PSU. And my next build will be a late XP era, but I'll make another thread about it in due time.
But I'll still learn how to solder and recaps so that I can fix any kind of problems I encounter, even with older gaming consoles.
