Powergraph C33 and Aztech Sound Galaxy
First post, by Tempest
I found this VGA card in the 486 I'm restoring (4DX2-66V). The BIOS says it's a PowerGraph C33 VLB card. I don't know anything about VLB video cards however. Is this a decent video card for a 486 or should I look for something better?
I also found an Aztech Sound Galaxy (138-MMSN813) sound card in the system. From what I've read it's a pretty average to below average card. I was going to replace it with the AWE32 from my other 486, but I noticed this card had a ribbon cable that went to the CD ROM drive (and a smaller cable as well). The larger cable is labeled CD-ROM Interface and the smaller one is labeled CD Audio In. What are these for and are they needed? I've never seen a Sound card that hooked directly into the CD ROM drive before.
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 1 of 24, by dominusprog
Well, what is written on the graphics chip itself? And for the sound card, it's a good card with a real Yamaha OPL chip.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 24, by Tempest
Not sure which one is the graphics chip, but if it's the WDC one it'sWD90C33-ZZ
Here are some pictures of the cards.
The attachment card_2.jpg is no longer available
The attachment card_1.jpg is no longer available
Reply 3 of 24, by rasz_pl
Graphic almost top performer https://dependency-injection.com/vlb-vga-group-test/
Sound has genuine cloned Yamaha OPL2 on board 😀 either by UMC in Taiwan or maybe even in Korea. In all seriousness Aztech made cheap but ok quality cards back in the day. Sounds like you have Panasonic/Sony CDROM that requires this card to run.
Reply 4 of 24, by Tempest
rasz_pl wrote on 2024-09-12, 05:58:
I was going to swap out the cd drive as it's a little chewed up (looks like someone has been prying it open) unless there's a reason to keep stick a special drive. Plus I'd rather use my Awe32 and MT-32.
Good to know about the video card. Guess I'll keep that as is my only VLB card anyway. I wonder how you put it in the zero wait state like the article talks about?
Reply 5 of 24, by dominusprog
Tempest wrote on 2024-09-11, 19:51:
Not sure which one is the graphics chip, but if it's the WDC one it'sWD90C33-ZZ […]
Graphics card is a Western Digital WD90C33-ZZ which is not a bad card, especially since it's a VLB version.
https://vgamuseum.info/index.php/cpu/item/488 … ital-wd90c33-zz
Reply 6 of 24, by Tempest
dominusprog wrote on 2024-09-12, 12:59:
Any idea how to set the ram to a zero wait state? The review here mentions that it drastically increases the cards performance, but doesn't mention the settings. I assume it's the undocumented JP2 block.
Also the BIOS is listed as 1.0. I know there's at least a 1.3 as I've seen pictures of it. Any idea if those BIOS files are available so I can flash a new EPROM?
Reply 7 of 24, by Grzyb
OPL3, not OPL2.
Anyway, it's "Sound Galaxy Basic Audio 16B", and it's a nice card because of its broad compatibility.
Such cards were advertised as compatible with 6 sound standards:
1. AdLib
2. Sound Blaster 2.0
3. Sound Blaster Pro 2
4. Windows Sound System
5. Covox Speech Thing
6. Disney Sound Source
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 8 of 24, by dominusprog
Tempest wrote on 2024-09-12, 13:31:
Any idea how to set the ram to a zero wait state? The review here mentions that it drastically increases the cards performance, […]
All settings regarding the VLB are in the motherboard BIOS. For the graphics card BIOS, you can use a programmer to flash it.
Reply 9 of 24, by Tempest
dominusprog wrote on 2024-09-12, 13:49:
Are the BIOS files for the Powergraph C33 available anywhere? I haven't seen them.
Reply 10 of 24, by Tempest
Grzyb wrote on 2024-09-12, 13:41:
OPL3, not OPL2.
Nice. I think my Awe32 is compatible with all of those plus having the interface for my Roland MT-32 so I'll use that instead. Still nice to know I have a SB 16 clone now.
Reply 11 of 24, by dominusprog
Tempest wrote on 2024-09-12, 14:24:
For safety reasons, use a different ROM chip.
Reply 12 of 24, by Tempest
dominusprog wrote on 2024-09-12, 14:40:
Is that the latest BIOS file? It doesn't say what version it is.
Reply 13 of 24, by dominusprog
Tempest wrote on 2024-09-12, 14:42:
I couldn't find any information about the version but it's from 09/13/93.
The attachment Screenshot_20240912_182301.png is no longer available
Reply 14 of 24, by Grzyb
Tempest wrote on 2024-09-12, 14:26:
No, AWE32 isn't compatible with WSS, Covox, and Disney.
And its SB Pro compatibility is broken - it plays, but without stereo.
Both AWE32 and the Sound Galaxy have MIDI interface, but in case of the SG it isn't compatible with MPU-401 - so pretty much useless for DOS games.
Overall, AWE32 is better, but can't fully replace the SG.
Reply 15 of 24, by Tempest
Grzyb wrote on 2024-09-12, 17:50:
No, AWE32 isn't compatible with WSS, Covox, and Disney. And its SB Pro compatibility is broken - it plays, but without stereo. […]
Can you do Awe32 for the MT-32 interface and Sound Galaxy for the rest of the sound output?
Reply 16 of 24, by Grzyb
Tempest wrote on 2024-09-12, 18:04:
I've never tried it, but I think it is possible - but not a good idea...
MPU-401 interface on Sound Blasters is far from perfect - it lacks the "intelligent mode" (required by some games for MT-32), and many models suffer from the hanging note bug:
Sound Blaster: From best to worst
If I wanted to add MPU-401 to that Sound Galaxy, I would search for some fully-featured and bug-free solution...
HardMPU? PCMIDI? Something else?
I don't know what exactly would be the best, but definitely NOT a Sound Blaster!
Reply 17 of 24, by Tempest
Grzyb wrote on 2024-09-12, 18:46:
I've never tried it, but I think it is possible - but not a good idea... […]
Just checked and my Awe32 is a CT3900. Do you recommend getting a some sort of repro MPU interface and a different soundcard for the MT-32 or just stick with the AWE32?
Reply 18 of 24, by dionb
Tempest wrote on 2024-09-12, 22:53:
CT3900 has a real OPL3, has type 2 hanging note bug (not as bad as type 1), slowdowns when playing high quality digital audio at same time as MIDI music (won't be an issue with MT-32 games...), single-cycle DMA clicking and may or may not be noisy, depending on the version of CT1703 DAC. Pretty par for the course with SB16 variants...
Question is what you want to play on this system? MT-32 stuff is old. Aside from MT-32, games from that period use Ad-Lib, CMS or Covox (or maybe Sound Blaster 1.0 for the newer ones). That 1st gen Aztech card is a good match for that, with OPL3 and Covox - and if the SB doesn't do stereo (iirc a 2nd gen Aztech issue, not 1st gen like this card) it doesn't matter because those games won't do stereo either. Now, that card doesn't have an MPU-401 interface. You could add the CT3900 next to the Aztech card purely as an MPU-401 MIDI interface, but that's overkill and buggy. You'd also need to use SoftMPU TSR to run games that need intelligent mode. But it's better than nothing.
If considering getting something else, the period-correct option would be an MPU-401 or clone (eg MusicQuest) or modern replica (HardMPU). That will cost quite a bit. Alternately, just go for a cheap card with bug-free MIDI (ALS1xx, 3rd/4th gen Aztech, C-Media, Crystal, ESS or OPTi chipsets would do the trick) and use SoftMPU. That will work for most games, just not things like Ultima 7 with exotic memory management.
Now, if you want to run newer games as well as old MT-32 stuff, the CT3900 might (despite its bugs) be more interesting, with its SB16 digital audio and AWE wavetable. Still, an AWE64 would be better - no hanging note bugs, no noise, no single-cycle DMA clicking. And you don't need the real OPL3 on the AWE32 as there's already a 1:1 clone on the Aztech SG Basic Audio.
Reply 19 of 24, by Tempest
dionb wrote on 2024-09-13, 00:03:
Not sure what counts as 'newer games' but I'd probably be running anything that can realistically run well on a 486. The MT-32 is mostly for Sierra games.
