First post, by Hamby
- Oldbie
I've been using an SD card to IDE adapter to provide the hard drive for my Toshiba laptop running Win98SE (with a 64gb card divided into 2 32 gb fat32 partitions).
I realized that I have two 2.5 or 1.8 inch (not sure which, atm) SATA hard drives from my old HP laptop (ZD7000? iirc).
So I began wondering if I could use a SATA to IDE adapter to put one of them into the Toshiba laptop?
One of them, iirc, is 60gb, the other 120gb.
Looking on ebay, it seems all the SATA to IDE adapters also have a molex power cable of some kind. So I'm guessing a SATA drive needs more power than IDE can provide.
(I do recall that the SATA to USB adapter I use with the two drives has two usb plugs... one for power...)
Is this possible?
Is there such a thing as an IDE SSD?
I'm looking for a solution without the drawbacks of SD Cards (limited life, read-only bug)
