ElectroSoldier wrote on 2024-09-13, 04:10:
Hey guys.
I was hoping somebody with some knowledge or experience of the SHUTTLE XPC SN45G-V2 could help me.
I wonder if you could tell me if an ATi X800 GTO will fit in the case or is that card to long for the slot?
should be do-able tho may need some modification, i've got a similar sized case, mines a morex venus, excuse my crappy camera.
The attachment Case.jpg is no longer available
mine had the PSU in a different spot so i was able to cut some of the case with an angle grinder and drill a couple of holes to fit a full size PSU
The attachment Back.jpg is no longer available
then one night i deceided to cram a 980ti inside, it was too late to use an angle grinder, so i went at it with a pair of tin snips, it was a bit of a hack job but it worked, had to cut a bunch of the inside out as well as the front of the chassis.
The attachment Side.jpg is no longer available
it fits!, well sort of, also had to break some plastic off the front bezel, if it had been the other morex venus with the different face it probably wouldnt have fit.
The attachment Tight Fit.jpg is no longer available
