First post, by theelf
Hi, greetings
I buy a AcerNote light 350PC, and i want to change cmos battery, because did not save bios options, but i cant find the battery at all... any ideas? someone have same laptop and found it? thanks a lot
http://www.carletonmacgregor.com/html/acernote_350pc.html
Reply 1 of 4, by dormcat
This page has many more photos with better qualities: https://www.clous.cz/acernote-light-350pc/
Click on the first photo would bring up a floating gallery of 56 photos. I wonder if the small grey box between VGA and PS/2 ports in photo #35 is a customized battery. Photo #41 is the bottom side of the motherboard and no apparent component with a possible shape of a battery.
Reply 2 of 4, by theelf
dormcat wrote on 2024-09-15, 00:48:
man you have a incredible good eye! thanks a lot, i found this website, but did not realize the extra pictures
I need to dissasemble all the acer to locate this grey box, i will do next weekend and came back with news, thanks a lot
Reply 3 of 4, by Thermalwrong
theelf wrote on 2024-09-16, 12:45:
Underneath that grey rubber 'sock' is this battery:
230.55 KiB
That's a non rechargeable battery so it's safe to put a CR2032 in its place. Personally I ran some wires to some free space under the keyboard and put a CR2032 holder there 😀
Oh also it might help you possibly, here's what I've found with the dip switches on the AN350:
22.67 KiB
Reply 4 of 4, by dormcat
Thermalwrong wrote on 2024-09-16, 13:37:
Thanks. To be specific, it's a Panasonic BR-1225/VCN with preinstalled V-type leads and wide temperature tolerance (between -30°C to +85°C). Pricier than common CR2032, of course.
