First post, by Dualy
Hey,
I am wondering what is the best way to back up the hard drive of an old 486 laptop with dead floppy drive?
I used Norton Commander 5 and parallel cable to transfer files to new computer, but I would like to do a Ghost image, however I can only boot to internal HD - it has DOS 6.22 and Windows 3.11 installed.
Opening the laptop and taking the hard drive is out of question, at least for now.
Thanks!
Reply 1 of 6, by Harry Potter
I used to have a 486DX4/DOS laptop. I still do, but it's at my mother's house, and it's currently disassembled. 🙁 Worse yet, it doesn't have a hard drive. 🙁 However, it has an external Parallel Iomega Zip100 drive, and it helps. I also have a network to another computer with another Zip100 drive, and both computers have a large RAM drive. I recommend that you buy a Parallel Zip drive off of eBay. Two problems, though: 1. you need to find a way to get the necessary drivers to your computer, and 2. its disks aren't 100% reliable. They usually come with a Guest driver, but it's kind of large. You can look at https://dosprograms.info.tt/indexall.htm#utils for palmsys. It is very small. I had problems where it didn't always work, but another person here said it was reliable. Try it out.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 2 of 6, by Dualy
I have a parallel ZIP drive, but it is only 100MB. The data on HD is about 220MB....
Anyways I put a Norton Ghost 2003 with paralink and it seems to be working. It will now just take almost 2 hours to clone the drive 😁
Reply 3 of 6, by ldeveraux
Why are you opposed to opening a laptop in 2024?
Reply 4 of 6, by Harry Potter
You're right. It would not be enough to clone a 220MB hard drive. It should be enough if you're just backing up the hard drive and compressing the backup. I tried. 😀
Reply 5 of 6, by Dualy
ldeveraux wrote on 2024-09-18, 13:20:
It is a Toshiba T1950CT, which has hard drive buried in the case. So it takes at least 2 hours to get it out and back together.
They put the hard drive first in the bottom case, after that they put everything else on top.
I had disassembled it one or two times in the past (replacing defective capacitors), so if possible, I would not be doing it again 😀
Also, the floppy drive belt failed that I would need to replace, and LCD started to develop vinegar syndrome - luckily it is an active matrix, so it is still very visible and polarizers are cheap to get.
So when I get some time, I will do a full restoration on it, but for now, I just backed up the HDD.
At that point I would also replace the HDD with a CF.
And yeah, Ghost 2003 can image the drive that is being booted from
Reply 6 of 6, by ldeveraux
Dualy wrote on 2024-09-19, 11:37:
It is a Toshiba T1950CT, which has hard drive buried in the case. So it takes at least 2 hours to get it out and back together. […]
That's nuts, I think you're doing it wrong haha
