DVD drive only plays CDs
First post, by Cursed Derp
Heyyyyyyyyyyyyo,
In my Dell Dimension 4100 I got a cd drive and a DVD drive. The DVD drive works for cd games and music but won't play actual DVD movies and DVD-r discs. The device manager lists it as -NEC DV -5700A
The attachment 20240918_163732.jpg is no longer available
It also lists it as a cd rom drive. I can't find the correct drivers and I don't know what to do.
Any help would be greatly appreciated.
Thanks
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 1 of 9, by Repo Man11
It could be a laser issue as they use a slightly different wavelength for CDs than for DVDs - selective failure could mean that the wavelength for CDs is fine but the one for DVDs isn't. Disassembling the drive and cleaning it is worth a shot; can't hurt and it might help.
Reply 2 of 9, by Tiido
Yeah, the DVD laser is bad or just dirty. Most DVD drives I have seen have two lasers, one for CDs and one for DVDs and I have seen several drives where one works but not the other.
Reply 3 of 9, by bertrammatrix
Repo Man11 wrote on 2024-09-18, 21:17:
Indeed. Not sure how newer stuff but there used to be two separate laser systems. DVD using smaller pits is much more sensitive to a dirty optical system then CD hence it is usually the first to fail. Cleaning may help. If it doesn't- the laser diode output goes down over time, often you can bring a drive back by finding the tiny potentiometer and turning it just a TINY BIT (trial and error may be necessary to find out which direction and which one is CD and which DVD if there is two of them)
Reply 4 of 9, by AlaricD
The drive may just not be designed to read any other DVD than a commercially-pressed DVD-ROM (including DVD movies) and commercially-pressed CDs. CD-Rs may be possible but read below for conjecture based on my '90s/'00s memories.
The warning label describes visible and invisible laser radiation. The wavelength of the invisible laser radiation may go into the ultraviolet, or at the very least be not only a shorter wavelength, like 650nm (still a red) but with greatly reduced intensity to not damage CD-Rs (some early DVD-ROM drives warned to not put a CD-R in, as the laser imparted too much energy and sortof 'reburned' the disk in its attempts to read). If the wavelength is particularly short, it is more easily blocked or scattered by any dust on the lens.
Reply 5 of 9, by ElectroSoldier
Is it region locked?
Reply 7 of 9, by Cursed Derp
Yeh the drive is hella dirty so I'm going to use a drive cleaner disc on it then maybe I'll check the lens
Reply 8 of 9, by Cursed Derp
OK I cleaned it and I think it works now thanks yall
Reply 9 of 9, by Cursed Derp
OK actually it doesn't read anything now I'll have to open it up damn it
