Asrock 775Dual VSTA & Core4Dual thread
Reply 760 of 901, by The Serpent Rider
Adding caps may help with improving voltage ripple, but they are placed very close to the socket.
Reply 761 of 901, by Mamba
The Serpent Rider wrote on 2024-09-21, 08:22:
Thanks, any advice on specs?
Reply 762 of 901, by timsdf
Obijuan1983 wrote on 2024-09-01, 11:58:
1.4vcore mod at back side of motherboard socket […]
E5500 @ 4135 MHz (14*295FSB)
OCZ DDR2 3-3-3-8 1T
Sapphire 9550 @580core/405mem
The attachment 3206105.png is no longer available
Just done 1.5vcore mod to use E5700 @ 4.425MHz 😀
Board can have easier volt mod with a potentiometer than "risky" socket mods. Image is my boards volt mod with 60k ohm pot to ground plane.
The attachment asrock_volt_mod2.jpg is no longer available
resources:
http://www.madshrimps.be/articles/article/670 … System-Part-1/3
http://www.controsensi.it/Mods/4CoreDual-SATA … ontents_Eng.htm
https://web.archive.org/web/20071020012031/ht … t=192571&page=2
Reply 763 of 901, by joco79
Anyone can share with me the comands to flash the bios in dos of the ASROCK 4COREDUAL-sata2? Thanks
Reply 764 of 901, by myne
https://www.asrock.com/support/BIOSIG.asp?cat=DOS
I built:
Reply 765 of 901, by sech1p
Hi there, I have problem with my 4CoreDual-SATA2 mobo. Whenever I try to boot, regardless of whether it's from CD or hard drive, I get the 50AC code in the lower right corner and the whole computer hangs. What could be causing this? Do I need to downgrade the processor or update BIOS as first post said that on newest cpu PC won't boot? (I have two Pentiums on LGA 775 in my collection)
I have Core 2 Duo E8200 installed.
Wind: 8VTAV / GeForce Riva TNT2 Model 64 / AMD Duron 800 / Windows 95
Neptune: 4CoreDual-SATA2 / GeForce 7600 GS / Intel Core 2 Duo E8200
Smol: Amilo Li2727 / Intel Pentium Dual-Core T2370 / Windows Vista & XP
Reply 766 of 901, by sech1p
Okay, i don't know how it's boots but it turns out that my processor is unsupported. I'll try downgrade it to some 775 Pentium's from my collection
Reply 767 of 901, by Mamba
Your processor is supported as soon as you have the latest bios beta.
Reply 768 of 901, by XavierX
Hope someone here can help me. I'm getting desperate at this point and I am about to lose the will to live!
I cannot get the Asrock 775Dual VSTA to output a video signal at all.
I've tried resetting CMOS, new CMOS battery, reseating RAM, reseating GPU, reseating CPU. I've basically tried all the recommended steps when you get no video signal.
Components:
2GB of Kingston 1GB PC2-4200 DDR2-533MHz DIMM (tested on another board as working)
I have tried it with both these chips:
INTEL SLA98 Core 2 Duo E4400 2GHz Socket 775 Processor
INTEL SL9S9 Core 2 Duo 6400 2.13GHz Socket 775 Processor
Both boot fine, no beeps, no warnings, but I cannot get a video signal with either.
I am using this GPU:
Nvidia GeForce 6600 GIGABYTE GV-NX66256DP2 PCB Graphics Card 256MB DDR2 (PCIE)
Tried the VGA output and the DVI output to 2 different monitors.
I have now ordered (out of sheer desperation):
Asus Nvidia GeForce 6200 N6200/TD/128M/A (AGP)
Gigabyte Nvidia GeForce 6200 TC. GV-NX62LTC256T (PCI-E)
Will any of this combination work?
I just need confirmation that what I've put together should work, or if I'm trying to put components together that won't work anyway.
This isn't even the final build, I just need something to boot and give me a way of installing WinXP, so I can make further updates.
Many thanks!
Reply 769 of 901, by Mamba
XavierX wrote on 2024-11-11, 21:07:
Hope someone here can help me. I'm getting desperate at this point and I am about to lose the will to live! […]
Components:
Many thanks!
In theory they should both work.
If possible, test your gpu on another system.
And/or test another video output of your gpu.
Reply 770 of 901, by mihai
These boards are slow to POST, wait 60 - 90 sec.
Reply 771 of 901, by XavierX
Thanks for the info. I'll see if I have another board to test the GeForce 6600. And I'll wait at least a couple of minutes to see if there's any video output.
I'm waiting for the GeForce 6200 to turn up, so can't test that one yet. I'm not going to end up using either GPUs, it's just the one I want to use needs drivers installing first.
Reply 773 of 901, by XavierX
Bruno128 wrote on 2024-11-12, 12:27:
BIOS version? What POST code do you get?
If there's a way to get this information without having a video signal, let me know and I'll post it here.
Reply 774 of 901, by agent_x007
Use Celeron D (FSB = 533MT/s), or Pentium 4/D (FSB = 800MT/s).
Sometimes Core 2 Duo/Quad are finicky on this board.
Alternatively use DDR1, instead of DDR2 (it may affect things if memory slots are the problem, 2.5 or lower CL memory timing is recommended).
Also, this board is NOT made to support 800MT/s RAM.
Make sure your sticks have 533- or 667MT/s JEDEC profile inside SPD.
Reply 775 of 901, by Bruno128
XavierX wrote on 2024-11-12, 15:56:
One way is to pull the ROM chip out of socket and dump/flash it with a programmer but if it’s not an option you can indeed use the oldest components available like Pentium 4 and DDR1. There is a version sticker on the ROM chip so you can assume that one is minimal (if never updated) version number and look at cpu compatibility table.
To know the POST code you need a pci POST card.
SBEMU compatibility reports list | Navigation thread
Reply 776 of 901, by Mamba
Components:
Many thanks!
Actually the first question would be:
Do you ever post with your motherboard with your Core 2 Duo and memory at all?
If yes, it is not an issue related to bios or memory (probably), check gpu.
If not, you should update the bios first and make sure the memory is compatible.
Reply 777 of 901, by Masterchief79
Here are my results with the 775 4Core SATA2 Board. I also have a 775Dual VSTA and a 4Core VSTA and they behave basically identically.
I swapped all capacitors on the board and also changed the MosFets to more efficient ones, because the VRM is getting very hot with high TDP CPUs. On top, the board also has a voltmod for CPU and NB voltage and extra Tantal caps on the back of the CPU socket.
I was using this as my AGP Bench board back in the day but it's now my retro testbench with a QX6700. With regular air cooling (Zalman VF9900) I was able to clock my QX6700 to 3.73GHz for benches. 342.5 FSB is the highest I was able to get through SuperPi.
You can do a lot with these boards with a little bit of work. There's definitely potential, although they lack basic adjustability from factory (CPU vCore for example).
Reply 778 of 901, by XavierX
I'm back after testing with the 2nd GPU - Asus Nvidia GeForce 6200 N6200/TD/128M/A (AGP)
No video signal at all (again) - I left it a good 2-3 minutes and there is no video signal from either the VGA or DVI ports - tested on 2 different monitors.
I have to ask - is there something fundamental I'm missing?
I've only built "modern" PCs in the last 10 years, so maybe there's something I've missed with this older build?
I have the CPU connected, RAM, GPU and that's it - no hard drives, no optical drives, nothing - do I need an HDD to get it to have a video signal?
I have power running to the MB (20 pin) and CPU (4 pin) only - that's the only power connected for my tests - is this right?
I have to question even the most basic things at this point, I have driven myself into a nightmare over this!!
Also, I am putting the RAM into the yellow slots on the board - is that right?
Basically, treat me like I am a 5 year old and make sure there's nothing obvious I've missed here.
Getting very desperate now!!! Many thanks!
Reply 779 of 901, by XavierX
UPDATE - I have a video signal!
I decided to try with only 1 RAM stick connected and (luckily) the one I left connected was working properly and I finally got it to post with a video signal - so my other stick of RAM is faulty (tried it after on its own).
I would have never known this without randomly inserting only one RAM stick.
Does anyone have any recommendations for reliable RAM? I only need 2GB - I could get another one of the sticks I already have (to replace the faulty one), but I am now a bit dubious.
Many thanks.
