First post, by naujoks
Here I have a MSI 2116-H board with a 16MHz 286 on board and 4MB RAM that has a memory issue:
It's counting up to a weird number, like 4886kB. Sometimes BIOS reports a CMOS memory mismatch, but usually it doesn't throw any errors.
When running programs, often they work, but sometimes they hang. For example I was not able to install Win 3.11.
I tested the RAM sticks and the individual 44256 and 21256 RAM ICs, and they're all fine.
Any idea what could be wrong?
Board info:
https://theretroweb.com/motherboards/s/msi-2116-h
Reply 1 of 14, by ux-3
Battery status?
Retro PC warning: The things you own end up owning you.
Reply 2 of 14, by naujoks
Fixed and working
Reply 3 of 14, by naujoks
The battery is working, I mean.
Reply 4 of 14, by rasz_pl
what about leaving just simms or just dips plugged, still giving trouble?
Reply 5 of 14, by naujoks
Yes, it needs both to POST at all.
Reply 6 of 14, by rasz_pl
Now that doesnt sound right. It should definitely be able to post with just the DIPs. Maybe has something to do with JP10-15?
Reply 7 of 14, by Horun
I agree, does not sound right.... Those jumpers have Left (simms) and right (dips) "bank o:1". DIPS have bank o and bank 1 printed. SIMMS have banks 0/2 and 1/3 printed.
If jumped left should enable just simms. That era motherboard most likely needs matching 9 chip simms, all my 286 boards do not like the 3 chip types....just some thoughts
Reply 8 of 14, by naujoks
I popped the jumpers to the left and removed the RAM chips. It's booting now, reporting 3840kB, which I think is the right amount?
It still locks up though. I only have 1 stick with 9 chips. I assume I need to populate all 4 slots?
Reply 9 of 14, by rasz_pl
afaik 3840kB means its caching bios by default
16 bit cpu = 2 slots at a time
Reply 10 of 14, by Horun
Look at your simms, if two match exactly use just those for now in bank 0, should report about 1792k. See if it stable....you could also loosen the memory timing by adding wait states in BIOS..
You should not mix simm types if at all possible. If filling all banks they should be same type (all 3 chip or all 8 or 9chip) and same speed.
Reply 11 of 14, by naujoks
I now popped the jumpers on the other side and removed the RAM chips.
Using sticks with 3 ICs, it counted up to 3840kB, but the system froze sooner or later.
I sourced RAM sticks with 9 ICs, and with those the system is stable.
It still only counts up to 3840kB, no idea where the last 256kB have gone...
Reply 13 of 14, by naujoks
Ah yes!
Hmm I wonder what's better on a limited system like this, BIOS + VGA shadowing or the extra 256kB RAM...
Reply 14 of 14, by Horun
Shadowing is better, that 256k will not add much to the 3.84MB (is only 6.7% more). If any app has to get data from one of the BIOS's it will be in ram instead of usually much slower ROM chips.
Glad it works well with the 9-chip simms. Save those 3 chip simms for a 386 motherboard board 😀
