First post, by kelmer
My floppy drive was working fine and suddenly it stopped reading any disks? All disk throw the "retry, abort, failure" error on MS-DOS and just "couldnt read from the drive" on Windows.
Is it dead? Can it be fixed?
Reply 1 of 6, by rain
Probably drive isnt bad , try another floppy disk.
Reply 2 of 6, by konc
What have you tried to troubleshoot? Start from the usual stuff: confirm drive declaration in BIOS is correct, reseat the I/O card if any, remove and re-connect the floppy cable, remove and re-connect the power connector, test with another floppy cable no matter how new it looks, test with another drive, test a disk on another computer, remove any new hardware you might have added lately, try to format a disk...
Reply 3 of 6, by kelmer
Ok looks like i have a lot of fiddling to do! I didnt change anything it just straight up stopped working the other day when I put my SQ4 original floppy disk in... then all of a sudden no disks worked. Will try to plug/unplug.
Im using the disks to copy data from another computer so the disks do work fine when writing on them, just reading in this particular drive none of them work.
Reply 4 of 6, by konc
Ah then also check the SQ4 disk for visible/physical problems and try to format one disk on this drive.
Reply 5 of 6, by Joakim
If it stopped working just out of the blue maybe the heads are just dirty. I would take it apart and clean it with IPA very gently.
Reply 6 of 6, by kelmer
Things I've tried:
* Changing the ribbon
* Changing the power cable
* Tried using my (original) prince of persia floppy, it displayed some files for a split second on windows, then threw a blue screen, then never read the floppy again.
* Formatting the floppy from the "damaged" drive, but it says the "size doesnt match the disk" no matter if I choose 1.44Mb or 720kb
I can read these floppies just fine using an external usb floppy drive on my (modern) windows laptop.
