First post, by Tempest
I have a nice looking CD-ROM drive with the model number GCE-8160B that I believe is a LG rewriteable drive (looks like this: https://www.ebay.com/itm/204901597970). It appears to be detected by my Gateway 2000 4DX2-66V but it won't actually work. I have it set to Slave with the jumper on the back, but that appears to be the only thing I can change (master, slave, cable select).
When I try to read a CD (in DOS 6.22) I get this error: CDR101: Not Ready Reading Drive E
I'm wondering if the drive being a writable drive isn't making it incompatible with my system. If this is true, would it work in a Pentium MMX based system (I can swap drives then)? Or is the drive maybe dead?
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 2 of 5, by rasz_pl
Tempest wrote on 2024-09-25, 19:44:
dont, stuff that old was very flaky working in pairs. Put it on its own ide controller as lone master.
Reply 3 of 5, by Tempest
rasz_pl wrote on 2024-09-25, 20:12:
I think this motherboard only has one.
Reply 4 of 5, by Tempest
I tried a known working drive and it did eventually work. It took a few seconds (about 7 or 8 ) to spin up, but eventually it worked. Not sure if that's normal in a 486 or not.
I'm guessing that the other drive is bad or something. Shame, it looks nice and clean too.
Reply 5 of 5, by chinny22
When my 2x died I replaced it with what was in the shops at the time a 24x Not sure it was faster though, as you say I was constantly waiting for it to spin up, almost like it the PC was too slow for the CD drive.
I dont really use a CD in my 486's any more but tools exist to slow the drive down which may make it behave better
CD Rom drive speed
