First post, by Xanxi
Hi.
On the Amiga, we have several softwares like HeadCleaner https://aminet.net/package/disk/misc/headcleaner372 which can clean the floppy drive heads in conjunction with a cleaner disk. It makes sures the heads are moved back and forth on the cleaner surface. It comes handy to clean the heads without taking apart the computer and the drive.
I am looking for something similar for MSDOS but can't find any so far.
Any clue.
Thanks in advance.
Reply 1 of 5, by Grzyb
I use DiskDupe...
The attachment diskdupe.png is no longer available
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 5, by wbahnassi
ImageDisk by Dave Dunfield also has a nice disk cleaner routine, regardless of my opinion of this method of cleaning 😁
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 5, by Xanxi
Great, thanks!
I'm going to give a try at these two.
@wbahnassi: what is you opinion about this method?
Reply 4 of 5, by wbahnassi
Oh, it's a dangerous method. There is high risk that the cleaning media gets caught on the heads, pulling them out by the force of the spindle motor, effectively either ripping them out or breaking their springs' tension.
The probability of this disaster happening grows with how much cleaning solution (e.g. alcohol) is sprayed on the cleaning media. The more wet it is, the higher the chance. And if you don't wet it enough, you don't really clean the head..
This happened to me a couple of times, after which I decided to keep this as a last resort if I'm really really lazy to dismantle the drive and clean the head by an ear bud.
Sorry if that sounds scary.. that's why I didn't want to just mention it right in my reply.
Reply 5 of 5, by Cyberdyne
Nothing is better than a good 80% vodka. Those sanitiser are no good, because they include oils for yourb hands to be soft and usuallu some gel agent. If you have industrial spirt, you are golden. Just nice little dab with a q-tip. Never done bad with that approach.
