First post, by kotel
- Oldbie
Hi
A while ago I got this COMPAQ Armanda 4131t. Firstly I've installed 95 OSR2.1 since I thought it would run better than 98se. Sadly I came across many issues (one of which was undetected IRDA), so I decided to stick with 98se. After installing it from HDD (cause no ODD and floppy drive is broken (not ready errors in DOS and windows)) I noticed that IRDA was missing in device manager (or whatever its called). I have found the driver but that only installs to A or B drive and I can't unpack the files using 7zip. I could try to replace the floppy with an MITSUMI D353G and hopefully install the driver without issues, but I don't know if both of them have the same pinout (98se says the unbranded one is GENERIC NEC FLOPPY DISK). Also tried installing the generic IRDA driver 98se had, but that made an unknown device appear (maybe the IRDA itself?). Any ideas if I can replace the floppy with the mitsumi one (connectors look the same) and if there are any drivers that don't use the weird COMPAQ installer?
"All my efforts were in vain...
Let that be my disappointment."
-Kotel
