Reply 28440 of 30564, by Karbist
I was checking a box full of salvaged Geforce FX 5500 cards and saw these 2 fake cards:
The attachment front.jpg is no longer available
The attachment back.jpg is no longer available
some kid back in Geforce FX days was wondering why his game runs like crap. 🤣
Reply 28441 of 30564, by PD2JK
Wow. And this works? It looks more expensive than a 'real' card.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 28442 of 30564, by BitWrangler
Karbist wrote on 2024-09-30, 11:26:
I was checking a box full of salvaged Geforce FX 5500 cards and saw these 2 fake cards: […]
I'd say "looks" like crap, because 9000 could maybe get as good or better frame rates in DX8 as the FX 5500 got in DX9... on a pure DX8 game though an FX 5500 should be faster.
I would never have thunk they would have tried to get away with that though, it's gotta be a bit obvious when things report radeon when you think you bought a geforce.
Reply 28443 of 30564, by Karbist
BitWrangler wrote on 2024-09-30, 11:44:
These fake cards came with driver cds with modified device name, for example Redeon mobility 9000 renamed to Geforce FX 5500.
Reply 28444 of 30564, by BitWrangler
I realise they would superficially reskin the drivers and all, but what happens if you run 3DMark?
Reply 28445 of 30564, by Thermalwrong
That's cool, I bet those chips came from early lead-free solder laptops like the IBM Thinkpad T42 and probably Dell Latitude D600. They probably went to china as e-waste in droves since the lead-free solder didn't last too well, but the chips on them still had 'some' value 😀
Reply 28446 of 30564, by thp
GemCookie wrote on 2024-09-27, 15:50:
A month ago, my K6-2 system suddenly stopped POSTing,
—————8<—————
Sigh. And they say Linux breathes new life into old hardware...
Funny thing, the last few days I ended up building Linux 6.11 for i586/K6-2, booting it with loadlin from within DOS into a busybox initrd and from there initialized partition which now contains a rootfs built by buildroot (again, i586, as the K6 is missing i686 instructions like CMOV that were only added on the Athlon, but the Pentium Pro and Pentium 2 had). I also added qemu user-space emulation binaries to run armhf and x86_64 Linux binaries, but haven’t tested that yet.
Long story short, K6 is kind of a pain in the sense that it‘s not a full i686, which would mean one could use more mainstream 32-bit x86 distros (not counting SSE, which appeared on the PIII Katmai and Athlon XP).
Reply 28447 of 30564, by thp
ratfink wrote on 2024-09-28, 23:58:
Completed my hardware downsizing exercise so that what I've got left makes more sense and might actually be used one day (or is reasonable spares and alernatives).
[So, off to ebay to buy some more then....]
Congratulations! Did you manage to sell most stuff or just trash stuff that nobody is interested in? For low-value items, seems like it‘s not worth the hassle, but trashing stuff that would otherwise work feels wasteful, but at least it wouldn’t take up mental (and physical) space.
Reply 28448 of 30564, by PcBytes
That wouldn't be their first feat. Their Radeon 9600 cards used Mobility 9700 cores. (which would basically land you a cheaper-than-retail 9600XT 🤣. Good luck having it not break with artefacts due to poor build quality doe.)
Reply 28449 of 30564, by BitWrangler
thp wrote on 2024-09-30, 17:16:
—————8<—————
That's odd, I think I was running i686 kernels on K6 class in noughts or so, and not having a problem, though I think they could detect and detour around lack of cmove then. Then I guess since then there wasn't the i686 lite option or something, or some meathead intel fanboi excommunicated AMD on purpose, because he only deemed tualatin up worthy of still running that code or something.
Reply 28450 of 30564, by ratfink
thp wrote on 2024-09-30, 17:20:
Sold some bits on amibay, some on ebay, gave some things away on freecycle and amibay... I haven't thrown anything out this time round but what I wanted was "less" and there was a bunch of stuff I didn't need any more so some went and I've kept what didn't go.
Reply 28451 of 30564, by PC@LIVE
Yesterday I replaced the gear shift gaiter, now worn (quite a bit), the car is not very old, but the final result makes it a little younger, a fairly simple job which requires dismantling the knob, all quite simple, for me, even if it was the first time I had done such a job.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 28452 of 30564, by jtchip
BitWrangler wrote on 2024-09-30, 17:43:
The K6 was never even partly i686, which is defined as requiring the CMOV instruction (introduced with the Pentium Pro) and sometimes long NOP (which Debian 12 made compulsory, Debian 9-11 only required CMOV). I think it was so named to differentiate it from the K5, given that is was derived from NexGen's Nx686 and re-engineered for Socket 7.
Reply 28453 of 30564, by Dorunkāku
I made a ghetto 'VRM' for a FIC 486-GIO-VT2 out of two jumper caps and a bridge rectifier. The cost in parts is less than 1 Euro and it works surprisingly well with a 5x86 running at 160Mhz.
The parts I used are two open ended jumper caps and a GBU4J bridge rectifier. The two parallel double diode junctions drop the voltage supplied by the powersupply by 1,55 Volt. With the powersupply I use this results in a core voltage of 3,55 Volt. The airflow from the CPU cooler keeps the bridge rectifier cool enough.
Reply 28454 of 30564, by zuldan
Replaced the voltage regulators on all my Roland MT-32’s. It’s really simple, no soldering required.
1) Open the case 2) Unscrew the regulator 3) Unplug 4) Install new regulator.
The attachment 146A4252-EC36-4027-A0A9-70C298D061B0.jpeg is no longer available
The original regulators were running at 4.89v, 5.3v and 5.4v. All the new regulators are running at 5.07v. Perfect! Hopefully these MT32’s will last another 30+ years.
The new regulator has some nice features. Not sure if the old regulators have the same.
Features
• Output current up to 1.5 A
• Output voltage of 5v
• Thermal overload protection
• Short circuit protection
• Output transition SOA protection
• 2 % output voltage tolerance (A version)
• Guaranteed in extended temperature range (A version)
Here is a link to it https://au.mouser.com/ProductDetail/STMicroel … %2F8mWnQg%3D%3D
The attachment 648E684D-7350-4B79-8EAB-ABFD807B6AFC.jpeg is no longer available
Put the original voltage regulators in storage.
The attachment 47666354-4343-417F-8878-36A37EBDD9D6.jpeg is no longer available
Reply 28455 of 30564, by RetroGamer4Ever
If I had the skills, I'd buy up the old synth hardware modules and refurb the electronics/electricals, so that they can keep on ticking and be enjoyed for at least another generation. I know it's sort of a waste, but there's just something about the physical presence of hardware, that box of "stuff" that does what the other boxes don't do.
Reply 28456 of 30564, by PC@LIVE
Dorunkāku wrote on 2024-10-01, 08:33:
This is very interesting, I imagine that the motherboard is 5V and has no provision for a voltage reducer, unfortunately I am not a technician, and I don't really understand how you connected the rectifier bridge, and if it is possible to do it in other MB 486 5V, practically you could upgrade a MB from 66-80 MHz maximum, to 100-120-133 or even even 160 MHz.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 28457 of 30564, by rasz_pl
PC@LIVE wrote on 2024-10-01, 16:07:
He plugged it to a connector called PS3V 😀 very much a socket for optional 3V voltage reg.
Reply 28458 of 30564, by DarthSun
Magical setup Am2+. Win98 3DM01 a little tuning.
Dos and XP tests will come, and I will link to the next result table.
Old optimalize of future machine after next, live!
The attachment PH2X2FCNext_3DM01.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 28459 of 30564, by BitWrangler
Cracked open the EGA monitor I got on Saturday to fix the power cord... I mighta been scammed guys, looks like it was made last month not 1988... just kidding, very clean.... had to quit for now, took wayyyy too long to get the cover off, was hung up on something, but I just wanted to jiggle it gently, old plastic etc etc, so it finally came loose and I still can't tell what it got stuck on, maybe just a cable tie on one of the reinforcement ribs or something. Anyway, that made my shoulders too shaky to risk the wrath of the angry pixies, so just picked at it a bit and will have to finish up tomorrow.
