Reply 220 of 240, by momaka
- Oldbie
GreenBook wrote on 2024-10-01, 18:09:Thank you for long and valuable message. Do you want say GF4MX video card is worse even then FX 5200 and FX5500?
To be honest, I can't say with 100% confidence which one would be worse over the other. I think with very late 99 and 2000/2001 games (especially any with DX8 support), their performance will be about equal (and by equal, I mean not very good.) Both will be limited to rather low-ish resolutions to get decent framerates. In older DX7 titles, though, the MX440 and 460 will probably beat the FX5200/5500, though.
GreenBook wrote on 2024-10-01, 18:09:GF2MX400 64 is cheap 😀
Yeah, probably for a reason. If it was a 64-bit memory bus version (and I think most are), it would be pretty slow.
I remember a high school buddy of mine with a decent-ish P4 PC back in the day with a GF4MX card, and even Counter-Strike 1.5 (later 1.6) didn't get great FPS on that card. And IIRC, NFS Underground didn't want to work at all.
So yeah, probably pass on that MX400... unless it's dirt cheap. Then get it just to keep around as a spare card or to use for comparing with other cards.
GreenBook wrote on 2024-10-01, 18:09:What do you say about AGP Gainward QUADRO FX5600 256MB DDR 128bit? Does the video card is ok?
You sure that description is right?
If it's an FX5600, it should be a GeForce, not a Quadro. And if that's so, I'd say go for it if the price is decent. GeForce FX5600 will perform quite decently for a late P3 build.
On the other hand, I don't remember what the Quadro-equivalents of the FX line were, and in particular of the FX5600. But if it's the same GPU chip on a Quadro card, that's still a good choice.
GreenBook wrote on 2024-10-01, 18:09:GF3 Ti200/500 and GF4 Ti 4200/4400/4600 are very expensive. The cost is too high to be profitable. In this situation I should choose Radeons.
Indeed they are.
Even here in Eastern Europe, that's become the situation too.
Well, a few months ago, I saw a TI4600 on the flea market for the equivalent of about $12 (the guy wanted 20 LEV.) And it looked in decent condition too. But knowing these cards, it was probably dead and/or artifacting. Moreover, for $12 I can typically get 2 old desktops or 2-5 motherboards... or 10 IDE HDDs... or 15 optical drives - all untested, of course. So I didn't want to throw all of my money into one item that may turn out to not work. Thus, I skipped that card. In retrospect, I probably should have bought it, knowing what the prices are like in the rest of the world (I can probably sell it for the same money on eBay that I bought it for, even if I explicitly mention it's not working.) Then again, I have 4 of these cards already (2 working, 2 dead), so didn't want to add more to the hoard.
CharlieFoxtrot wrote on 2024-10-01, 07:49:I don’t think the GF2 line would be out of place in most of the P3 systems. Different variants were mostly released between spring and autumn 2000 and Ti as late as in autumn 2001. Yes, GF2 line doesn’t have the programmable shaders, but something like GF2 Ultra gives GF3 ti200 a good run for the money and can even beat it in many DX7 benchmarks.
And from here we get to the GF4MX440/460. These cards can beat the fastest GF2 cards, they have much better image quality and there are even passively cooled cards available. NV17/18 cores are essentially tweaked NV15 cores.
Ah, I see. Thank you for the clarification, I always found older nVidia card line up a little confusing (well, so is ATI's to me if I look further back before Radeon 7000.)
Indeed a DX7 card won't be a bad match for a Pentium 3 PC (not to mention be period correct, too). But if the system is a more late P3 build, then it will be capable of playing some early DX 8 / 8.1 titles as well. So I think it's good to have a DX8+ card in there, just in case. I actually remember when we upgraded my cousin's PC (a 933 MHz P3 with 128 MB of RAM, Radeon 7000 64MB, and Windows XP - a PC that I now have in my possession) for the first time - we put an extra stick of 256 MB of RAM in it, bringing the system total to 384 MB. He was able to play Mafia, GTA VC, and quite a few other games that didn't work prior. The Radeon 7000's performance, of course, was quite underwhelming even in DX7 titles. But many years later when I acquired that PC and upgraded the GPU to a Radeon 7200, then to a 9600, I can tell you how many more games I was able to play and that the FPS and frametimes improved quite a bit. What's funny is we even attempted to run Half-Life 2 on that system back in 2005 before he finally decided to retired it and build a new PC. Watching HL2 slowly chug on that system (and with quite poor graphics) was certainly a memorable experience. For some reason, I have not attempted to put HL2 on it, now many years later with the upgraded hardware. But in a different benchmark from Need For Speed Underground from the system as it was back then and the way it is now, it's a significant improvement difference. With the original config, NFS UG would run mostly around 20-30 FPS with the lowest settings on 640x480. The RAM and GPU upgrade now allows the same game to run mostly around 30 FPS (frame-locked by game) with medium-high settings and 800x600 (or perhaps it was 1024x768, I forget now.)
So my point is, it does pay off to have a better GPU in there for a late P3 build.
CharlieFoxtrot wrote on 2024-10-01, 07:49:FX5200 has shaders, but it is not a good performer so I would probably go with something else if DX8 or DX9 is a priority.
Well, if DX9 is a priority, I would skip the entire GeForce FX line and go straight for a 6600 or 6800 at the very least (though worth mentioning here is that the 7600 GT may be a more sensible choice in some cases.) Or in case of Radeon cards, go with at least DX9c supporting cards... so probably x1000 series, and nothing less than the x1600 or x1650. But then we wouldn't be talking about a Pentium 3 build here either, as these are much newer cards that will likely get very bottlenecked even by a high-end P3.
CharlieFoxtrot wrote on 2024-10-01, 07:49:I’d avoid MX420 and cards like MX440LE (latter is practically MX420), which have 64-bit memory bus and are significantly slower compared to regular MX460/440 line.
Interesting you mention this. A few weeks back, I saw an MX420 (or was it an MX400, I can't remember) that specifically had a sticker mentioning a 128-bit memory bus on the back (and the card had 8 memory chips too, so can confirm it was likely a 128-bit card.) Should have bought it to play around with and compare against my two FX5200 cards (one is 128MB 64-bit, and the other is 256MB 128-bit.) Was going for scrap prices ($1-2 if I bargained a little with the seller.)
