Reply 40 of 120, by nizmow
sander wrote on 2024-09-28, 07:04:Thank you! So there is no bracket to attach the cache module to? It looks like the module will fit, but I would like to be sure if the protruding edge will fit. Can you measure how much room you have from the top of the cache socket?
No, no bracket like the desktops. It’s just under 5.5cm from the top of the connector to the bottom of the PSU (so just over 2 inches).
