Reply 500 of 1148, by kotel
- Oldbie
PC@LIVE wrote on 2024-10-03, 15:09:This morning I repaired the audio cable of the POST CARD, not having one in reserve, I managed and fixed it, I hope it lasts a f […]
This morning I repaired the audio cable of the POST CARD, not having one in reserve, I managed and fixed it, I hope it lasts a few years, even if it is not indispensable, sometimes it is useful for the beeps of the MBs on trial.
Staying at the M550, so I didn't remember well, the card starts, but it doesn't display anything, no beep, you can see some POST codes, the last ones displayed are:
D4 d3
What does it mean??? Or what does it mean???
Surely there is a problem, we will see later if it can be solved or not!
Let's start by saying that the BIOS is AMI, so the meaning changes, from BIOS to BIOS, to understand it they are not universal, if for AWARD means one thing, for AMI it can mean another, if we are practical of BIOS or specifically of BIOS AMI, we will also be able to know what problem there may be, unfortunately it is not my case, and I just have to interpret what is written in the POST CARD manual, and translate it, I believe that the first code displayed in all MBs is d0, the following ones I do not know if they follow a numerical order, or a visually causal order (i.e. You move on to other codes by skipping several).
Here the sequence of the new codes, is quite short, one second two, maybe three, however after d4 nothing happens anymore, but I haven't tried to leave it on for a long time ⏱, so I don't think it will go on at some point (waiting).
According to what I read, and understand by translating, the d3 disables the cache before detecting the memory. Performs memory sizing. And if the sizing is not performed, activate a boot lock code. I think this is the important point, but maybe this step is performed, and therefore no problem
For d4, the info is quite little, it starts with, tests the 512 KB base memory, runs something that stores in the first 8MB (cache???), finally sets up the stack. Well, I didn't understand much, apart from the 512 KB memory, I think they are valid concepts, for X86 PCs from XT up, but that most ignore because they run at startup.
The thing that could be interesting, however, is the d5, in which we talk about BIOS that is copied from ROM to RAM, here this could be the problem, if the ROM is not readable, it will not copy anything, for this problem, we have a possible solution, download a BIOS and rewrite the chip, with a programmer, maybe if we have the possibility, we can write to a new BIOS chip, and we can load into the corrupted BIOS chip, a different version, if it can be useful to us.
If it was an Nforce board I'd say its dead, but this isn't the case. Maybe try different ram/cpu?
Always has the weirdest issues happen, and always is all alone with them
