Reply 54640 of 59751, by Wes1262
weedeewee wrote on 2024-10-08, 19:34:
I haven't bought it but found it for sale pretty cheap and would like to inquire others opinions about this possible purchase. […]
Asus Z8NA-D6 rev 1.01G
2x Intel Xeon E5520
2x 4GB DDR3-1066
for €35
It's a good deal. It has a PCIe slot, so good for games. A 4870X2 or 295 GPU would be era appropriate and fit the dual-things theme!
Reply 54641 of 59751, by Kahenraz
Server motherboards for use as desktops or workstations often come with an interesting caveat: a lack of USB ports. So, always budget to spend at least one or two of the PCI/e expansion slots for this purpose.
Reply 54642 of 59751, by rasz_pl
2x Intel Xeon E5520
Server hardware is junk if you are not into playing with useless loud hot power hungry servers, no matter the price. IT will take minutes to boot, fans will go full blast, performance of those Xeons is pathetic at around Thinkpad X220 or $3 Q6600 level.
Reply 54643 of 59751, by Wes1262
Tested another card received yesterday: Geforce 2 Ti with 4ns memories. Which I love to see because it means it can run Ultra frequencies almost for sure. Ran 3dmark 2001 perfectly. Only needs a new fan because this sounds like a velociraptor while being chewed by a t-rex. I wish there were more new replacement retro coolers that didn't cost a fortune. I mean I like this GF2 but I'm not going to spend 20 bucks on a cooler. That's more than what I paid for the card. Best cheap genuine retro cooler I could find is this https://www.aliexpress.com/item/32682508049.html which was used on Canopus cards and seems to be compatible with GF2s. I will try to lubricate the fan before I buy anything though, but not always I have had luck with that.
* edit: small caveat about that aliexpress cooler: it's 5v, which makes it significantly less useful
Reply 54644 of 59751, by DAVE86
Carefully examine those 1000uf smd electrolytic capacitors at the leads. They tend to decay and leak. I've had the exact same card and the bad caps ate the surrounding solder joints and component leads while in storage!
Reply 54645 of 59751, by Wes1262
Ah! Thanks for the heads up. I will check!
Reply 54646 of 59751, by Wes1262
Just got another card I've been looking for ages.
Question: Is the pink pad thing around the bridge chip useful for something? Or is its purpose just that of preventing damage to the chip? Heat dissipation? I want to try to install an heatsink on the bridge chip.
Reply 54647 of 59751, by Wes1262
I was thinking to get a NVME heatsink, drill two holes in it, and install it on the bridge chip using the existing heatsink mounts and maybe a couple of washers. Thoughts?
Reply 54648 of 59751, by nd22
Today it finally arrived! A big package with 3 motherboards with 3 CPU's and some RAM. All are LGA 1156, something I never had before!
1. I7 875K + Asus maximus III formula + 8gb RAM
2. I7 870 + Asus P7P55D-E premium + 16gb RAM
3. I7 860s + Asus P7P55D-E deluxe + 4gb ram
All for the price of shipping (which was very steep) and no questions asked!
Tonight i will do some testing.
Reply 54649 of 59751, by Munx
nd22 wrote on 2024-10-09, 09:49:
Today it finally arrived! A big package with 3 motherboards with 3 CPU's and some RAM. All are LGA 1156, something I never had b […]
High-end LGA1156 is in that state where it's stuck between retro and modern. Can make a really mean XP machine or a period-correct Vista rig while still being usable for basic tasks today or even some lighter gaming.
My builds!
The Underdog - The budget K6
Reply 54650 of 59751, by Maryoo
InterAct PC GamePad 6
Reply 54651 of 59751, by PcBytes
Bought an ABIT KG7 RAID off the bay 😀. Should arrive from Poland.
do i get a free pierogi with it? 🤣
Reply 54652 of 59751, by Kahenraz
Wes1262 wrote on 2024-10-09, 09:26:
You can use nylon washers instead of steel or zinc too. Maybe put one of those red paper washers between that and the board or a rubber grommet for a bit of extra cushion.
Just be careful that you don't damage any of the ceramic SMD capacitors. They are very susceptible to crushing forces.
Reply 54653 of 59751, by nd22
Munx wrote on 2024-10-09, 09:54:
Sincerely I do not know what to do with it. First of all I collect Abit boards and parts from the "Abit era" - 1998 - 2008. I never had or seen any of my friends with an LGA 1156 system. I am aware that this is the last classic platform from Intel.
At first try Maximus refuses to start and does not show any signs of life.
I7 860 + P7P55D-E DELUXE started right away and is now running memtest.
I7 870 + P7p55d-e premium will be next .
Reply 54654 of 59751, by marxveix
Sapphire AMD Radeon HD7750 1GB GDDR5 (for XP/10 machine)
https://www.techpowerup.com/gpu-specs/sapphir … hd-7750-oc.b652
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 54655 of 59751, by G-X
Wes1262 wrote on 2024-10-09, 09:02:
I have the same card and the p/o ran this card for alot of hours with little airflow in the case. I didn't even know about the bridge chip needing cooling before reading it here. Surprised the card still works.
I contemplated putting one of these on the chip + make sure i have good airflow and calling it a day. If it survived being cooked for so long it will last me long enough with that tiny heatsink on it.
Although in this users case Trying to cool the RIALTO bridge chip... it actually made the chip hotter (probably lack of airflow) so i would only put a hs on it if you have air actually flowing over the card. Or you could get a PCI bracket thing that can hold a fan next to the card and flow air over it that way. With this option you don't have to modify anything on the card. Zalman also used to make these but there are newer options aswell.
Zalman ZM-RHS1
Reply 54656 of 59751, by Wes1262
G-X wrote on 2024-10-09, 18:44:
I have the same card and the p/o ran this card for alot of hours with little airflow in the case. I didn't even know about the […]
Zalman ZM-RHS1
Might do that too! Did you remove the pink pad thingy before installing the heatsink?
Reply 54657 of 59751, by G-X
Wes1262 wrote on 2024-10-09, 18:52:
Zalman ZM-RHS1
I wouldn't ...it's there to protect tiny components on the chip ... they left the die exposed for cooling is my guess. Same thing like you would find on north/southbridge coolers back in the day.
https://pic.clubic.com/v1/images/1444443/raw. … b9ebab90aef7360 this is what it looks like without the protective pad.
I edited my post while you posted a reply so you might want to read it again ... posted a link and some extra options. I would imagine flowing air directly over the back of the card would be enough to not have to put a hs on it.
Reply 54658 of 59751, by AGP4LIfe?
I purchased a Geforce 6800 Ultra AGP, for a descent price ( Read not cheap, but definitely discounted), from a seller with bad pictures....
This silly thing is basically brand new, it doesn't even have AGP Slot indentations on it (Never used) and it came in the Original BOX!! There was no pictures of the box at all 🤣??
So happily confused.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54659 of 59751, by Wes1262
Read that, thanks! I like the idea of a robust solution that isn't permanent, like the nvme heatsink (with no thermal tape, just regular thermal paste) but I am worried that such solution might be too much pressure for the bridge chip to handle. Maybe with some nuts.
It's so overkill though.
