EISA ≠ PISA
First post, by DerBaum
In industrial / professional computer applications you can sometimes find expansion slots that look like an ISA slot but are normally brown an deeper.
The attachment 2023-10-06 20.52.28.jpg is no longer available
(Example picture shows a PISA SBC with a 14 slot backplane : 4 PCI, 2 PISA, 8 ISA)
The connector has two rows, where the upper row is normal ISA.
The connector is shaped that you can insert normal ISA cards in the PISA/EISA connector and it will work. The ISA card will not touch the lower row.
The confusing part is PISA and EISA use the same connector but do not share the same signals on the lower row of contacts.
EISA (Extended ISA) is an extension of the ISA bus. https://old.pinouts.ru/Slots/EISA_pinout.shtml
You can imagine EISA more like a VLB predecessor but combined into one slot and much slower.
EISA slots are normally found on mainboards and not on backplanes and used for add on cards like controller or graphics cards.
The attachment EISA_network_card.jpg is no longer available
(Example EISA Network Card)
Source: https://de.m.wikipedia.org/wiki/Datei:EISA_network_card.jpg
When PISA was introduced in 1996, EISA already was old stuff
PISA is a combination of ISA and PCI in one slot. https://www.kontron.com/download/download?fil … f&product=87006
The Upper row is ISA, the lower row is PCI.
PISA is normally used on single board computers to get ISA and PCI through one connector into the backplane.
This allows the computers to be as short as an ISA slot.
You can also get a combination of ISA and PCI for single board computers that is called PICMG (1.0).
This combination of connectors looks a lot like VLB but it isnt.
The ISA connector and the PCI connector are in one row after each other.
The attachment picmg.jpg is no longer available
(example shows a 12 slot backplane with 2 PICMG, 4 PCI, 6 ISA)
The attachment pca-6029.jpg is no longer available
A PICMG (1.0) single board computer.
FCKGW-RHQQ2
Reply 1 of 9, by Jo22
Cool! PICMG reminds me of the Amiga A2000 with its ISA+Zorro II slot design.
Reply 2 of 9, by Disruptor
Some 486 local bus variants use the EISA connector too:
OPTi local bus
Orchid local bus
Reply 3 of 9, by demiurge
I bought this ABIT AB-PG5 because it is the only system built for an obscure VGA card.
It seems to have a PISA bus in it but pre-dates 1996.
What can I stick in this slot?
Reply 4 of 9, by kingcake
Packard bell uses the EISA connector on their ISA/PCI combo riser cards. One row of the EISA does ISA the other row does PCI.
Reply 5 of 9, by dionb
kingcake wrote on 2024-01-23, 03:07:
That's PISA.
Reply 6 of 9, by Omarkoman
sorry to hijack this but I saw this system and according to specs it states it has PISA connector:
https://i.postimg.cc/Jn36SLJR/s-l1600-3.webp
however, I am bit confused as if I wanted to use this PISA riser:
https://i.postimg.cc/6QrfphQ0/s-l1600-2.webp
the deep notch on the card would mean that the connectors are facing to the right, not left meaning I couldnt use it in the computer in question.
and I cant find any PISA risers that have different orientation.
in saying that, there is also this one:
https://i.postimg.cc/Y98N1qYL/s-l1600-1.webp
that has the notch on the right way but, is that an EISA riser ?
very confusing
Reply 7 of 9, by mkarcher
Omarkoman wrote on 2024-10-09, 03:58:
That's clearly not an EISA riser: The slots on that riser are PCI slots, not EISA slots. EISA slots would look like the PISA slot on your mainboard, and most likely be brown. This card is very likely a PISA riser that ignores the ISA part of PISA but allows two PCI cards to be installed.
Reply 8 of 9, by Omarkoman
Thanks, I will purchase that riser and give it a try. Hopefully I wont fry anything.
Reply 9 of 9, by soggi
Thanks for the initial post, @DerBaum!
dionb wrote on 2024-01-23, 08:19:
That's PISA.
pure satire 🤣
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
