Reply 54700 of 59764, by ratfink
zuldan wrote on 2024-10-11, 11:59:
I found the card! It’s a Videologic SonicVortex 2.
Nice, thanks, always confused me about what was or wasn't a Superquad so it's good to get to the bottom of it.
When I used the card it worked fine, drivers installed, 3D audio worked. Think I switched from a Santa Cruz to this and then stopped using it when I got an MX300 but I didn't notice any change in quality or anything.
Pretty sure mine didn't support EAX (would that be a driver thing?) although I would have been mainly on Diablo2 at that time - the Santa Cruz gives both the 3D and EAX options though. (And I seem to recall the Sonic Fury is a Santa Cruz with a different firmware?)
Reply 54701 of 59764, by Tiido
AGP4LIfe? wrote on 2024-10-10, 15:12:
Are you speaking of the Blower Fan on the X850 type or the 9800XT/X800 Style.
Mostly the latter but I do have a X850XTP from many years ago I daily drivered with and it was never what one could refer to as quiet...
The attachment PA110244.jpg is no longer available
Pino wrote on 2024-10-10, 15:44:
I bought this for my 9800XT (same fan as a lot of those x8xx) and it works perfectly:
https://www.ebay.com/itm/171092853419?_skw=at … ABk9SR7qxxfHOZA
Just one warning, it has a blue LED on it, so it's not for the purists 😀
I will investigate, thank you ~
momaka wrote on 2024-10-11, 08:25:
They are most likely ball bearing fans then.
Oil is good for restoring sleeve bearings, but won't be any good at all on ball bearings. In fact, there's almost nothing that can restore severely worn out ball bearings. They just have to be replaced. Now, if they are only mildly worn, opening them and repacking them with white lithium grease suitable for bearings (after a through cleaning and de-greasing with brake cleaner) may get them "quiet enough". The good news is that most fans tend to use the same size ball bearings (I forgot the dimensions off top of my head right now), so you can often sacrifice something like a stock Intel LGA775 fan to get an odd-ball fan going again.
The blower I think has a ball bearing indeed, the rest I don't remember but they're definitely worn out with the spindle being all wobbly.
And yeah, those heatsinks are too small, at least on that X850XTP. The X800 on my photo have much more metal there but still probably not quite enough without undervolt and/or underclock...
Reply 54702 of 59764, by dormcat
Wes1262 wrote on 2024-10-11, 10:52:
This card is Powercolor something, made in China? It doesn't have the usual Ati heatsink. the caps are a bit chewed up, like dinged. I am not sure though, it also says copyright Ati 2001
I don't think the card was dropped. Seems in perfect condition but I will check the SMDs. I still need to buy a microscope... if you folks have any suggestions....
I am really not good at all at GPU stabbing. Or electronics. Or anything. But I own a good multimeter.
It's a Radeon 8500 with PCB manufactured in the 43rd week of 2001.
I'm more curious about the two stickers with text removed by photo-editing software. Was it you or the seller?
Reply 54703 of 59764, by AGP4LIfe?
This card is Powercolor something, made in China? It doesn't have the usual Ati heatsink. the caps are a bit chewed up, like din […]
Nah, ATI cards from back then pretty much never had issues with bad caps, because ATI always used good quality Japanese manufact […]
Nah, ATI cards from back then pretty much never had issues with bad caps, because ATI always used good quality Japanese manufacturers. Only exception are some of the 3rd party builders, like Sapphire, which almost always used shitty caps on the lower and mid-range cards. But even then, chances are slim.
I think the key here is that DVI port works and VGA doesn't. This suggests signal lines from the GPU chip are likely damaged. Radeon 8500/9100 is old type (wire-bond / non-flip chip) design, though, so it should be pretty robust unless it was allowed to overheat severely.
The only other thing I can think of is physical damage - i.e. maybe the GPU was dropped really hard before (shipping damage unlikely, if the item was packed OK-ish) or maybe the card was bent between other PC hardware or in the PC case it was in. Or electrostatic damage.
My suggestion is to look for damaged SMDs first. Ceramic caps can short out and still look OK. Obviously if any are shorted out, it wouldn't be on any of the power lines, otherwise the card wouldn't even boot. But a shorted one on a signal line may allow the card to boot normally while causing other issues. So check the ones connected to thin traces or what appears to be in series with any resistor(s). While at it, also check for chipped resistors. And lastly, check the protection diodes on the VGA connector.
Also, does underclocking (memory or GPU or both) make the card more stable? Very very small chance, but the RAM could be getting marginal at this age.
It looks like a 8500LE with a getto aftermarket cooler slapped on.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54704 of 59764, by mmx_91
Got an original passthrough VGA cable for my Voodoo2 today. Cable gauge is at least thick.
Let's see if image quality improves, as with the typical chinese cable, my Matrox Mystique shows annoying 'waves' on the screen.
S3 Virge that came originally with this system is currently a no-go when passing through Voodoo card 🙁
Reply 54705 of 59764, by GigAHerZ
Got 6x32GB industrial grade SATA SSDs and for payment gave 2x250GB random cheap SSDs.
I can now set up 6 pentium+ grade machines with no worries about too large disks!
For example, i'm currently working on Pentium 2 grade Compaq Deskpro and it just couldn't reliably talk to a 250GB SSD even when i only partitioned the beginning of the SSD in the size of ~100GB of FAT32.
Reply 54706 of 59764, by Wes1262
dormcat wrote on 2024-10-11, 14:16:
Yeah it was me, just on the chance I haven't already given away my location. Internet paranoia, y'now. The cooler is ghetto, yes. The heatsink is stock but the fan is taken from another card.
Can someone suggest a microscope that is cheap and that is good for hot air? I read that you need one that doesnt melt for soldering. The cheap amazon ones might be good enough in terms of zooming and picture quality, but apparently they will die instantly the moment you use hot air near them. So that ended my search.
Reply 54707 of 59764, by myne
Lol hot air isn't a lightsabre
I built:
Reply 54708 of 59764, by Wes1262
Right, but I am sure one of those 30-50$ plastic amazon microscopes break also with a gust of wind. I am really aiming for the super entry level setup. I need a bunch of gear. Hot air, a better iron, automatic suck pump thing, microscope, desk lights...
Reply 54709 of 59764, by myne
US based?
That northridgefix guy sells kit like that and says he only sells stuff he uses
I built:
Reply 54710 of 59764, by Wes1262
they are too expensive. i am looking for a microscope/macro camera that is 100$ max
Reply 54711 of 59764, by BitWrangler
You could heatshield it with a soup can maybe, cut a hole just big enough for it to see through in the bottom.
Reply 54712 of 59764, by momaka
Today was quite the day at the flea market. Made a lot more (and bigger) acquisitions than I normally would. But seeing where the prices of retro PC hardware is going and knowing that all of the stuff I got was headed to the scrappers, I did what I could to save a few pieces. Here they are:
- Acorp 6A815E socket 370 motherboard. No CPU and the NB heatsink was popped off already by the scrapper guy... but luckily I caught it in time before he did more damage to it. I really hate dealing with this guy, because he scraps a lot of good retro hardware and some even new-ish hardware, all for pennies. Yet, any time I look at any of the already scrapped stuff and ask for a little part or something already very damaged, he tried to tell me how valuable this stuff is at the metal recycling places and how much he makes. It's all BS, of course, and I know based on the prices the other "sellers" (poor gypsies) at the flea market give me (as most of them also usually send whatever is not sold that day to the metal scrap yards, so they'll take anything that's more than the metal places give them... which isn't a lot.) Anyways, I felt I should save this socket 370 motherboard, so I did. It was my most expensive purchase of the day - a whooping $8. Yes, I know that's a laughable sum compared to the prices on ebay, but it's a lot compared to what else I can buy in that flea market (and more on that in a bit below.) Usually I can get whole desktop PCs for $6-8 with all of the hardware inside (often HDDs too.) So buying standalone motherboards is almost not worth it. But again, it looked like a good P3 / s370 mobo, so I put my foot down this time. The guy also had a K7S5A, K7SOM, a ceramic Athlon 1200, and another s462 board I forgot already. I was eager to ask about the Athlon 1200 too, but I didn't because I knew he'd give me some astronomical price that would be more than the cash I carried with me... so I didn't even bother. This guy is ruthless - will never give you a good deal on anything, even if he sees that you have the potential to become a regular customer. I guess he just doesn't understand the concept of repeat customers. Ah well. Hope I got a working board. Will test it probably next week or whenever I managed to get it washed and dried first. It has a ton of dust on it. No chipped SMD's or damaged traces, as far as I can see.
- next up, a Gigabyte GA-EP45-DS3L socket 775 mobo with E5200 CPU. Nothing super retro or super special, but a nice late Core 2 mobo all around. Not bent pins in the CPU socket so I felt worth the gamble. Got it from a scrapper lady for $3 with the CPU. Don't know if I'll build something with it or not... but again, worth it just to save from scrapping. And even if it doesn't work, all of the poly caps on it are worth at least that much.
- ASUS M2N-E SLI socket AM2 motherboard with Athlon 64 X2 6000+ Windsor. This was another no-as-cheap (relatively speaking) purchase at around $5. But I figured at least the CPU is probably working and worth that price, being a top-end AM2 CPU. As for the motherboard itself... it's not in great shape, but nothing terribly damaged either. Normally I skip MBs with nVidia chipsets, because reliability-wise, they are shit (at least anything past nForce 3.) But this board is full of blown TK and United Chemicon KZG caps. So there's a good chance it was discarded because the caps made it unstable rather than because of a chipset failure. As such, I do have some hopes that it will work after a recap. Not sure what I would do with it if it works or after I fix it. It's a full ATX board, and I already have many more boards than I do cases. Not to mention how many complete systems I have already. So maybe I'll try to sell it? It's a SLI board and relatively high-end... so maybe it will find a buyer easier? Then again, it not that retro, so maybe not.
- last but not least, a beige Delux (Deer?) ATX case. Now this one purchase really makes me regret how I went about it. Not because the case is not nice (well, it isn't in great shape, but it's not terrible either... but that's not the reason for it.) Rather, the reason I have regrets is because this was a complete system with motherboard, CPU, RAM, GPU, HDD, optical drive, and PSU... and rather retro components inside. Lady wanted $3 for it, but I only had $2.50 left after all of the above purchases (plus a few more cheap non-PC items). She said she's OK with selling it for that too. Of course me trying to be the nice guy, I said, no, I'll give you $3, just give me a few minutes. I was going to borrow $0.50 from one of the regular sellers that knows me as a regular too (and she would have been fine with that, since I helped her load up her mech to protect it from the rain last week when it started raining unexpectedly.) So I did that and came back, only to see one of the regular electronic scrapper buyers in this place just buy the PC from the lady. When I asked him if I can re-buy it, he said, sure, but the price is going to be different now. Then he went on bragging to me (again.. I know this guy too) how much he makes by just scrapping the old wire-bond chips off of these old mobos and smelting for gold. He claims he's making _at least_ $5 per chip... which I KNOW is complete BS. He said it would only be worth it to him if he sold me the mobo now for at least $10 (of course you would, you slime bastard!)... and honestly, I still would have, just to stick it to his face and save that system from getting scrapped. But I was out of $, as noted earlier. So I asked him about the case only. Well, that at least he didn't care much about and said I can have it for (the equivalent) of $1.50. Only caveat was that he didn't want to pull it apart at that moment. Luckily (or thoughtfully) I always carry screwdrivers with me. I offered to do it for him, so he agreed. And so this is the hardware came out of the computer: a late socket 462 mobo Gigabyte with a 4-pin CPU connector (so not a 5V-heavy system), a BFG GeForce FX5200 128 MB 64-bit AGP (meh, not a big loss I suppose), a cheapo Delux PSU (couldn't care less for this heap of junk), a 120 GB Western Digital IDE HDD, and a beige CD-RW/DVD-ROM. Well, RIP... or should I say rest in pieces (to this hardware.) Right as I gave him the video card, he got out his pocket knife, popped off the cooler, and then popped off the GPU chip from the card and bragged again: see, another $5 from this chip. Annoyed, I asked him about the HDD and if he needs that too or what he intends to do with it. Surprisingly, he didn't care that much about it either. Said I can have it for $2... which is more or less what I get them at from the other seller. Of course, not having any money left, I said I couldn't. But he knows I'm a regular too, so just to pay him another weekend when I'm there. So I guess I managed to also save the HDD from that system too. Still, I'm pissed that I just didn't buy the PC for $2.50 when the lady said she was OK with that. So now it's another cool retro board going to the scrap heaven... and meanwhile I'm paying more for getting less. What bothers me the most is that it wasn't just a late socket 462 motherboard - it was a board with an nForce 2 Ultra, as it had FOUR DDR slots. Ah well, I guess can't save it all. On the plus side, it was less weight to carry as I walk to the place, and it's a 35 minute walk - not exactly pleasant with a heavy PC case.
I also found a bunch of CDs and DVDs, as usual. The creme of the crop from these was a 10-pack cake box with TDK DVD+R, all complete. There also 3 other 25 and 50-pack cake boxes, fetched out of the dumpster. One had roughly 20 blank DVD-R's and 30-40 CD-Rs. I gave half of these away to a random scavenger who was looking at the abandoned piles of stuff (at leftover discs) at the end of the sale, saying he's usually looking for blank CDs and DVDs. While at it, I saw a bunch of old drivers CDs that no one seemed to care about. So I picked those up. And in between those, guess what showed up? - A genuine retail Windows 98 install disc and also a genuine Microsoft Office 2000 Small Business disc - F*** yea! Funny how no one cared at all to take these two either. I suppose the whole retro PC hobby thing is not quite here yet (and maybe won't be, ever?)
BitWrangler wrote on 2024-10-11, 10:41:
I have been trying to think of a protocol to deal with that possibility. A relative is having a tough time with them, thinking they came in with a yard sale appliance, and there might be an epidemic of them in this area, because they can't find roach control products, they are sold out everywhere local
Thoughts are going to something like a large bag around the thing, where you can flood it with CO2 or nitrogen and leave it for a bit, they can't go without oxygen for shorter time than water or food.
CO2 and Nitrogen flooding can get tricky, as it would take a lot of trial and error to figure out how much you need to put in whatever bag / container you intend to use... and even then how would you know all of the oxygen got displaced already and there aren't any 02 bubbles left somewhere. Furthermore, roach eggs take around a month or so to hatch. So the CO2 or Nitrogen treatment won't do anything for them. This is also why most poison control methods aren't actually very effective with treating against roaches, unless you do it at least several times in the course of a year.
Temperature treatment is the most reliable method, and here you have two options: deep freeze or heat-treat.
Heat-treating is what some exterminator companies actually use to treat houses. Usually the way it works is that they pile up all of your (non-heat-sensitive) furniture in the middle of each room, place thermometers in various parts of the home, and then finally bridge the thermostat to heat the home until the temperatures everywhere inside reach at least 50C (which is a temperature roaches cannot withstand and die within minutes.) This temperature is then maintained for at least 24 hours to make sure everything has a chance to soak up the heat. This not only kills the roaches, but also their eggs. Obviously when they do that, they tell you to go and stay somewhere else for a few days, because such temperatures can also be lethal to humans. This method is also used for treating against bed bug infestations too, as those suckers are even more resilient to pesticides and poisons.
As for deep-freezing / cold temperature treating... that isn't too practical to do for entire homes. However, for smaller items, it's an alternative. Roaches can actually survive cold temperatures even to some extent below freezing. However, they can only do that if they slowly acclimatize themselves to it. So again, for smaller items, you can put them in a (well) sealed bag and put them in your freezer. Several hours should do the trick... but leaving it there for a day or two would be even safer. Of course, putting suspicious stuff with roaches in your freezer is kinda gross (not to mention a bit scary if you find out you didn't seal whatever bag or container you put in there.) Perhaps if you have a 2nd/stand-alone "backup" freezer that's not something you care too much for (or the contents inside), then that might be the better.
I see you list your location as Ontario... so I suppose at least your winters are (usually) relatively cold. In that case, and if you have a home with a backyard, you can just place suspicious stuff outside for several days when the temperatures start dropping below freezing not only overnight, but also stay so throughout the day. Just place the items at least a few inches off the ground so that the warmer ground (overnight) won't conduct heat to the item. This will ensure that the item you're treating will get at least as cold as the outside air temperature. Leave for at least a few days to a week to allow any unhatched roach eggs to also possibly hatch and for the small roach larva to die.
Alternatively, if you want to make a device to treat items throughout the year without having to depend on cold temperatures, then build a "hot box" out of plywood with a baseboard heater (or two) inside. Make sure it's well-sealed and kept at least a few inches off the ground. Add some insulation on the outside so that you use less energy to heat it up. Also, make sure to make the box large enough to fit the biggest item you ever intend to get (I'd say tall and wide enough at least to fit 55-60" TVs and deep enough for at least a microwave or several desktop PCs at once + space for the heater inside. Then do the same as what the roach exterminators do: turn on the heater(s) and allow the box to reach 50C-55C and stay that way for at least a day or two. But just a caution with that - make sure to remove any materials or whatever stuff your items have that can get damaged from this heat... i.e. batteries, pressurized cylinders and cartridges, and similar.)
As for attempting to treat an entire house, like with your relative's case, using the DIY cold/heat methods mentioned above... that can get a little more tricky. In that case, it might be smarter/easier to get some Diatomaceous earth first and put it an as many places inside the house as possible. This should kill a good amount of the roaches.
Reply 54713 of 59764, by Wes1262
BitWrangler wrote on 2024-10-12, 12:33:
Oooof 🤣! I was hoping I could get something OK out of the box for 100$. But that's a good idea actually eheh.
Reply 54714 of 59764, by PcBytes
Quite a haul in those last few days. Be keepin ya updated later today. Also had a bit of help from @Robert B 😀
Reply 54715 of 59764, by BitWrangler
momaka wrote on 2024-10-12, 23:39:
CO2 and Nitrogen flooding can get tricky, as it would take a lot of trial and error to figure out how much you need to put in wh […]
Thanks a lot for all the detail, what some guys do in taking everything apart and putting all the pieces through the dishwasher seems like a decent strategy too, as long as it's a hot cycle. No dishwasher here though. I guess I can rely on freezing temps for 2 or 3 months, and sun fuelled hot box for July/August. I will have to see if a typical computer case fits in my old minifridge, it had seemed to be failing. It's still a well insulated box with a good seal, so could mod it for a hotbox or I could see if it can be fixed with AC rescue type refrigerant in a can or something and stay below freezing if I bridge the thermostat in that.
Reply 54716 of 59764, by CharlieFoxtrot
I finally found and got an EGA card to my collection for a cheap price. It is Genoa SuperEGA HIRES+ Model 4880-9 which supports weird resolutions up to 800x600. It has also support for CGA, Hercules and MDA modes. Unfortunately I have to settle for the CGA compatible resolutions on my CM8833mk2.
It is in clean condition, the DB9 connector was corroded so I swapped a new one there. Tested it today and it works! This is quite nice companion to my Micro 8088.
Reply 54717 of 59764, by pentiumspeed
Today was quite the day at the flea market. Made a lot more (and bigger) acquisitions than I normally would. But seeing where th […]
Snip
Snip
We did on occasional see roach infested game consoles. I bag one console in trash bag and before closing, pour some 99% alcohol (ISO) into bag, about 1/4 cup or so, and wait a day or two, of course you can wait a week. By then they're dead and dried out, crumbling, even the eggs died.
I hate the smell and icky-ness of cleaning up the consoles, which we charge extra for this.
You could scale up and increase amount of alcohol, in a open container instead of applied directly to the wood or paper. Vapors is what gets the bug badly.
Cheers,
Great Northern aka Canada.
Reply 54718 of 59764, by Repo Man11
Speaking of bugs, I'll never forget attempting to repair a dishwasher in a disgusting home - when I removed the panel to get to the control module, cockroaches came boiling out.
Reply 54719 of 59764, by marxveix
Bought this motherboard today for 8.99.- euro. Did not found manual for this, but found bios file with Celeron D support.
I hope that 4xAGP and 2xAGP will work.
Canyon CN-9V0MLV4
Maybe this motherboard can crossflashed if the maker of the motherboard is someone else, not Canyon made, have not heard of them much. 😀
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
