Reply 300 of 401, by GloriousCow
- Member
SoftCat wrote on 2024-10-12, 00:00:EGA card Gemini VC-001. Multisync monitor is not needed here at all. Look: 14318000/114 ~= 16257000/129, 14318000/912 ~= 1625700 […]
14318000/912 ~= 16257000/1032.
And otherwise everything is like CGA.
if you (or anyone else) can show me evidence of this working on an IBM 5154 or other dual-frequency EGA monitor of the era i will consider it a bug, but i'd have to rethink how i handle the display field entirely. I didn't consider a 16Mhz 15KHz mode.
if you look in the screenshot, "Field: 774x364" that is currently the maximum supported resolution with the 16Mhz clock.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
