First post, by RayeR
- Oldbie
Hi, I got this MB for repair from a scrapper. The condition is not good. Backup battery leaked as usual and made some damage on PCB. As I checked it seems it was only one broken trace from kbd connector - fixed. Worse problem was that someone damaged th CPU socket. I desoldered it with a hot air gun and soldered a replacement (spare used socket) but the MB didn't POST. I checked CPU voltage, clock and BIOS ROM. Address lines was alive but CS# and OE# was still H. I tracked this lines to Opti chipsets. I checked CPU MEM, R/W and beside I found that A3 pin was disconnected because of broken via under the socket. I repaired the via and finally it started posting (Award 4.50 codes): C1, BE, C6 but halted soon at C6 - cache presence test. Maybe some more CPU lines are broken. There are suspicious BREQ and LOCK that seems to be disconnected too but not sure if they have to be. BREQ goes at least to one jumper beside CPU socket.
I was also suggested to try MrBIOS image for the same OPTi chipset that's claimed to have better debugging capabilities (better post codes, more beep codes). I could give a try but I guess I can't avoid checking all CPU pins with DMM anyway...
Next, If I would make it boot, I'd like to add the VRM. This board has absent the components Q1, Q1A, Q1B beside the CPU socket. From public photos I'm unable to identify it. Please if someone still has this MB write me the LDO or transistor marking on your board. And if you have a DMM it would help checking BREQ and LOCK pins with diode test (with CPU removed, + to gnd, - to siganl) to see if it is connected somewhere or floating.
