Reply 54720 of 59761, by BitWrangler
marxveix wrote on 2024-10-13, 19:36:
Bought this motherboard today for 8.99.- euro. Did not found manual for this, but found bios file with Celeron D support. […]
I hope that 4xAGP and 2xAGP will work.
Canyon CN-9V0MLV4
Maybe this motherboard can crossflashed if the maker of the motherboard is someone else, not Canyon made, have not heard of them much. 😀
This is the warmest I can get.. https://theretroweb.com/motherboards/s/biosta … u8668-d-rev-5-a
edit:
oh there 's a ton of revisions maybe this closer... https://theretroweb.com/motherboards/s/biosta … -rev-7-8-and-up
Reply 54721 of 59761, by marxveix
marxveix wrote on 2024-10-13, 20:13:
P4M266A-8235-6A6LW00HC-00 code is the same so should be perfect fit, thank you. […]
BitWrangler wrote on 2024-10-13, 20:04:
This is the warmest I can get.. https://theretroweb.com/motherboards/s/biosta … u8668-d-rev-5-a […]
Canyon CN-9V0MLV4
edit:
2xagp should also work.
Re: Socket 423/478 Motherboards with Universal AGP Slot
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 54722 of 59761, by Xicor
Found a Midiman for 40€. Its in good condition but lacking the breakout cable, not much of a challenge to make new ones.
The attachment midiman.jpg is no longer available
Reply 54723 of 59761, by vutt
I have been chasing MS 6163 Master Pro with SC1153CSW VRM 8.4support for some time. Previous one I bought was with broken chipset - unrepairable.
This one was combo with Coppermine slotket. Got it from local auction site after some price war...
...was sold as is but it is working. Needs some Caps replacement however...
MB might even support Tualatin with 1.3VCore support although quick googling did not reveal any ready made BIOS with Tualatin microcode and multiplier support.
Reply 54724 of 59761, by PcBytes
Huh, same board as mine 😀
Finished recapping, as well as assessing the Voodoos. Out of them, only the Banshee managed to work and that wasn't until I resoldered two SGRAM chips completely by hand.
Reply 54725 of 59761, by vutt
I have been playing around with it (2 posts above). Did partial recap with spare ones.
I went for usual place for updates https://theretroweb.com/motherboards/s/msi-ms-6163-v2.0-bx13
Well well. I think I need to correct them because it suggests that Coppermine is not supported. My 1.65V SL47S (866/133Mhz) runs just fine although autodetect assigned 100FSB that's why you see 650Mhz on pic.
However with manual configuration it also runs at 866.
I wonder if MSI BIOS-es can be edited manually by inserting microcode for proper CPU support, like with Asus boards? I have Asus P3B-F with modified one, but I downloaded it. Never done it myself.
Reply 54726 of 59761, by PcBytes
My experiences with 6163 and 133FSB weren't pleasant, at least on VER 1.
I'm waiting on a package from a fellow VOGONS user that also has a slotket - I have both a 733 and a 866 chip to test.
Reply 54727 of 59761, by vutt
Well I have been probably spoiled on rock solid Asus P3B-F 133Mhz performance. Kind of thought if it's 440BX platform then no worries regardless of manufacturer. Anyways I will draw my conclusion when I manage to do full recapping. So far with my 6163 v2 I have done only DOS testing..
Reply 54728 of 59761, by bestemor
I almost bought these AT cases, does that count ? 🥹
I mean, just LOOK at them - a totally silly uncomprehensible amount of slots on the back, never mind the endless row of serial cut-outs on the right side !
Though I cannot really see what I will be using them for (I'd much rather have a desktop version), and replacing that monster PSU with a modern one seems like an 'impossible' task.
And I don't see myself putting any ATX board in here (how?!).
But at least they are fun to look at! Even though 1 is missing the front door.
The attachment AT-towers-front.jpg is no longer available
The attachment AT-towers-back.jpg is no longer available
The attachment AT-towers-inside.jpg is no longer available
Reply 54729 of 59761, by luckybob
if you dont go and buy those cases....
this motherboard will fit just fine - https://www.ebay.com/itm/204958712739
Reply 54730 of 59761, by bestemor
luckybob wrote on 2024-10-15, 22:24:
So THIS is what is supposed to go in there, oh - I see ! 😁 Makes more sense, given all those slots!
I assumed it was supposed to be a 486 or early Pentium board, but here we have Pentium II ?😲
The attachment Supermicro P6dgh.jpg is no longer available
PS: + OH! it takes TWO CPUs as well ?!
Heh, must have been a real monster back then (1998? + AT ?? 🤔😱)
Reply 54731 of 59761, by luckybob
The Asus P65up8 is also a prime candidate for that case: Bitchin' dual p-pro setup
Reply 54733 of 59761, by liqmat
A younger me would have snagged those server tower cases lickety-split. I have a thing for frosted doors. The PSU isn't a problem with a little know-how.
bestemor wrote on 2024-10-15, 22:43:
Heh, I sense some strong desires to upgrade that utterly inferior and cramped case of yours ? 🤣
Luckybob has one of the sexiest rolling server cases on the planet from the Pentium Pro Haul of 2018. I've been asking him to post photos of it. It's similar to those above, but I think with even better looks. It's also absolutely unused and in mint shape.
Reply 54734 of 59761, by AGP4LIfe?
Finally got a working Radeon 9800 PRO AIW. After about 3 or 4 having memory issues when tested... 🙁 But that's all in the past now, Whoot!
This was the last one I needed for the AIW AGP collection. Feels good! 😊
The attachment PXL_20241016_015904127.jpg is no longer available
The attachment PXL_20241016_024004951.jpg is no longer available
I wanted to have each AIW card, with it's corresponding best non AIW card, for each gen.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54735 of 59761, by Wes1262
AGP4LIfe? wrote on 2024-10-16, 02:50:
Finally got a working Radeon 9800 PRO AIW. After about 3 or 4 having memory issues when tested... :( But that's all in the past […]
Thats awesome! I am not into AIW a lot but I think for Ati they were their best products. Especially the early ones were game changing. You need a red led strip! And a green one if you have a similar shelf for Nvidias! 😁
And congrats for the 9800!
Coincidentally, I've made photos too. Here's my most recent purchases. From left to right, top to bottom.
- Inno3D Geforce 2 Ti-Ultra with custom heatsink taken from another card... unfortunately that turned out noisy too.
- Gigabyte GTX 295 Dual PCB - Working
- XFX GTX 7800 - Working
- Creative Geforce 2 Mx with Daughter board and DVI - Working
- X1950XT Sapphire - Working
- 9600 Pro Palit - Working
- Leadtek GTX 295 Single PCB - Unsure. The heatsink seems incorrectly installed
- Asus 3870x2 - Unsure, but probably dead. A screw holding the backplate is missing.
- FX5700 POW - Working
- Ti4200 Creative - Working
- Sapphire 3850 AGP - Working
- Powercolor 2900XT 1gb - Not working 🙁
- Sapphire X850 XT - Working
- 2900XTX fan.
- MSI? GF4 MX 440 - Working
- Sapphire 4850x2 - Working
Reply 54738 of 59761, by marxveix
Trashbytes wrote on 2024-10-16, 10:26:
devius wrote on 2024-10-16, 09:39:
Where's the Rage 128 Pro version? 😅
or the Fury MAXX one ...very rare too, so rare one might never see one.
MAXX is not AIW, it is just AWesome.
Reply 54739 of 59761, by Trashbytes
marxveix wrote on 2024-10-16, 10:36:
🤣, I was messing around, and yes its Awesome I have one myself and itll be the one card I keep even if I sell everything else.
