First post, by JF_Sebastian
Hey guys,
today i tested an old P55t2p4 which i got from scrapyard. In general everything is working but the system time runs slower than usual. A second needs almost 4 seconds. Any idea what kind of problem causes that behavior? Bases the systemtime on the RTC module or does is come from an other component on the mainboard?
Greetings!
J.F.
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 1 of 7, by rasz_pl
RTC runs the clock from internal 32KHz crystal when off. When ON and in DOS time is run by system timer (8254 PIT https://wiki.osdev.org/Programmable_Interval_Timer using bus/~14MHz clock). I dont know which one is used on the BIOS screen.
Reply 2 of 7, by weedeewee
broken crystal is a likely culprit. that tiny metal tubes... I forget what frequency it was... 31k or something i think.
edit: https://youtu.be/koL3T5OAlIk?t=406
Do not ask Why !
Reply 3 of 7, by JF_Sebastian
weedeewee wrote on 2024-10-20, 17:18:
Thanks for your replies!
Do you mean the crystal of the RTC?
Boot Up or Shut Up!
Reply 4 of 7, by weedeewee
JF_Sebastian wrote on 2024-10-20, 18:25:
yes. please watch the video.
Do not ask Why !
Reply 5 of 7, by JF_Sebastian
Ok. Thank you for your quick help!
Greetings
JF
Boot Up or Shut Up!
Reply 6 of 7, by rasz_pl
On this board 32KHz crystal is blobbed together with bios battery in the Dallas RTC clock chip, PIT timer is inside Intel 82371SB (PIIX3) southbridge and driven by ~14MHz buffered by ICS9159 clock gen chip.
Reply 7 of 7, by weedeewee
rasz_pl wrote on 2024-10-20, 19:11:
Well, when you're right, you're right.
JF_Sebastian When you go into the bios setup, and watch the time there. Does it count the seconds normally or not ?
Do not ask Why !
