Reply 540 of 1165, by PC@LIVE
- Oldbie
A CF memory card arrived today, the capacity is 4GB, more than enough for an installation of DOS and Windows 9X, if you want you could also use it for XP, but for what I have in mind, that is DOS+W9X, that's fine.
At this point 🧵 I can start installing Windows, the MB I use is the M550, currently it has only 32 MB of RAM, and an AMD K6 233 CPU, I would like to reach 128 MB of RAM and 400 MHz (with a K6-2), I have to add some things, one or two serial ports, and if I can also that PS/2 (mouse), and also an ASUS MIR card for USB ports.
Then I would change the VGA and add a sound card, initially I thought an SB16 ISA with a vibra chip, but alternatively I could use a PCI, for example an SB Live! It seems to me maybe 🤔 a bit excessive, then of course 👌 if there are no big problems with the drivers, all in all it could be there, because a K6-2-400 is not too slower than 🫡 the PII-400.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
