MartyPC
Reply 340 of 629, by SoftCat
jal wrote on 2024-10-23, 08:23:
Trying to get a higher resolution out of a CGA that only works with an EGA monitor is daft to begin with.
JAL
This is not true. This mode is intended for EGA video card with EGA or CGA (or multisync) monitor.
I like MartyPC and I want it to be better. A good emulator should support everything that the emulated hardware supports. Whether to add it to the emulator or not is up to the author.
Reply 341 of 629, by GloriousCow
SoftCat wrote on 2024-10-23, 12:01:
By that metric, there are no good emulators. It is always possible to construct some program that breaks any given emulator, for all but the simplest of machines.
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 342 of 629, by superfury
GloriousCow wrote on 2024-10-23, 22:20:
I do try to implement all functionality of the emulated hardware, though, in my emulator, as is documented in the chip documentation.
Not counting bugs of course (which it still has).
Right now, my (S)VGA is the most complete one that exists, to my knowledge. Although not an accurate CRT (monitor) itself unlike MartyPC's. It still shows the hidden areas (borders) for example, which aren't visible on real monitors. Those left/right special areas that are monitor specific (making it uncentered in this case).
UniPCemu Git repository
Reply 343 of 629, by GloriousCow
superfury wrote on 2024-10-24, 06:44:
I certainly don't mean to imply we don't try our best. There are just always tradeoffs between accuracy, performance, and convenience of implementation to be made, and in those tradeoffs you can find lots of things lurking that make it possible to, if not outright break an emulator, construct software that doesn't work on an emulator.
There's a cheeky demo for the Amstrad CPC by Logon System I believe that tells you the name of the emulator you're using to watch it. The only way it can know is by detecting some deviance from real hardware.
Reply 344 of 629, by GloriousCow
Ok, to summarize:
I've been thinking more about it, and after taking a look at the readouts shown by my rgb2hdmi running the demo, I think SoftCat is probably correct that this would work. Unfortunately 5154 monitors are obscenely expensive so its unlikely I'll ever be able to test for myself.
To handle the various display modes used by 8088MPH and Area 5150, and to properly emulate the overscan, I adopted an aperture into a fixed display field for CGA. This technique worked very well, and has handled everything I've thrown at it basically.
I tried to expand on that concept to implement EGA by creating two display fields for EGA's 14Mhz and 16Mhz clocks, to support the various modes supported by each.
My naive assumption was that we would be in 15Khz scanline frequency when using the 14Mhz clock, and we'd be in 21Khz scanline frequency when using the 16Mhz clock.
As SoftCat has demonstrated I think these assumptions are bad - you can construct a mode in the 16Mhz clock that creates a 15Khz scanline frequency - so the requisite display field isn't necessarily tied to the clock. It's tied to the scanline frequency.
Now, the simplest thing to do is simply go back to a single display field, set to the largest extents of both clocks. We'll waste some memory, but it will essentially be fine. But what I think I ultimately should do is determine the display field extents based on a vertical and horizontal PLL that syncs to the vsync and hsync signals within a reasonable range, comparable to what a real monitor might tolerate. The advantage of this method is that it should handle VGA much better than trying to handle separate display fields for 350, 400 and 480 lines, as well as if I ever bother to do SVGA where there would be basically infinite display fields possible. Plus we can simulate loss of vhold, display bounce when changing video modes, and other fun stuff. There are a few points during effect setup in Area 5150 where we have very short vsync periods, which if you look closely at a hardware capture, you can see the monitor's vertical PLL reject and they show up as black bars on screen.
I think this is the method that Tom Harte's CLK emulator uses. The thought of doing a PLL scared me a while ago, but after making one to read floppy flux images they're really not so bad, but there is an art to them I have yet to master.
There's another advantage here in that it will eliminate a bit of a hack I implemented for Hercules - the MDA monitor lacked a horizontal PLL which is why you have those warnings about potentially damaging a MDA monitor with bad display modes. Some CGA emulators for Hercules took advantage of this by pushing the display timings just slightly out of spec. This meant that I had to slightly expand the display field for Hercules, in a way that is not really derived from its clock timings.
In any case, my main focus for 0.3.0 is getting the new disk support in a stable state. Stable, not complete. I'll probably be fixing floppy and disk format issues for the lifetime of MartyPC going forward.
I'll look at the PLL implementation for 0.3.1, which is a good excuse to bundle it with the reintroduction of VGA.
Reply 345 of 629, by superfury
So basically, you're measuring the average scanline time (in nanoseconds for example) and use it to clip a horizontal range for resizing bases on monitor specs? And the same for the frame(vertical) timing, which is the time between vertical retraces?
So basically, for VGA you take the emulated maximum time a scanline ticked between retraces for horizontal, the same for vertical (the literal time between retrace starting) to get the physical time of both fields.
Then use some official monitor specs to translate those two timings back into pixels for a screen to obtain the area the user sees (x1,x2,y1,y2 coordinates) and resize that area to 4:3 on some sane buffer resolution (800x600 for VGA for example)?
Reply 346 of 629, by mkarcher
GloriousCow wrote on 2024-10-24, 16:49:
If you implement that, you might be able to recreate the effect that happens when you connect a 31kHz VGA (or 30-50 kHz SVGA) monitor without IBM-like monitor ID pins to an IBM PS/2 model 30. In that case, the PS/2 model 30 might mis-recognize the monitor as 15kHz monitor (which is a completely undocumented operating mode of that system...) and output CGA/NTSC timings. I had multiple monitors sync to twice the actual horizontal frequency (i.e. 31.2kHz instead of 15.6kHz) if that happened. I don't see any point in skipping every second hsync for VGA monitors, though, even if it works with a couple of monitors at least. I guess it will fail on everything with "digital control".
Reply 347 of 629, by superfury
I've updated UniPCemu's video support a bit:
- The GPU can now display ranges of display rendering buffer as an alternative to the entire video buffer. So it can specify a x1,y1,x2,y2 rectangle to render as an alternative to the old 0,0,x2,y2 rendering system.
- Screen captures are still performing a full display buffer dump, including said areas. They also aren't resized in any way (thus containing the raw video data the video adapter dumps on it's clocks, from retrace to retrace).
- The video card can set this mode when it's rendering Vertical Retrace. It's currently rendering the full frame. So it can either use the legacy method (full frame) or the new partial frame (x1,y1,x2,y2) method for the rendered frame from the display buffer.
- The video card has the horizontal and vertical resolution, as well as the largest (maximum) horizontal scanline time and the total vertical scanlines time (a sum of all rendered scanlines horizontal time).
So it should be able to somehow create a x1,y1,x2,y2 window based on those two timings and the rendered frame size.
The question is, what should those x1,y1,x2,y2 locations be, based on the display adapter used (MDA, CGA, (S)VGA)?
From what I can see on the MDA display adapter's output, it seems to have no borders at all? The active display starts exactly at coordinate 0,0 at least.
Right now, the timing detected on the MDA text mode is roughly:
- Horizontal: 54253.551269531250ns (18431.97314461513Hz)
- Vertical: 20073813.969726562ns (49.81614363409495Hz)
And on CGA text mode it's:
- Horizontal: 63695.238647460938ns (15699.76062943698Hz)
- Vertical: 16688152.525634766ns (59.9227504940343Hz)
On VGA text mode it's (720x400):
- Horizontal: 31777.418518066406ns (31468.88723611927Hz)
- Vertical: 14236248.187850952ns (70.24322608068806Hz)
Although right now the XT isn't displaying much with CGA/MDA (blank display buffer) and nothing but a blank screen with a cursor blinking on the VGA adapter tested.
The ns timings are simply obtained by looking at the accumulated values in the double-typed floating point variables. Conversion to Hz is simply 1000000000/ns formula (although done in Windows' calculator, which is limited in it's digit inputs compared to UniPCemu's raw floating point value entered manually into the calculator).
CGA for example gets a vertical retrace-to-retrace field rate of 59.922750494034275Hz when calculated from the raw values in the timing variables.
Horizontal timing being 15699.760629436980Hz from the raw variable.
Taking rounding into account on the raw timings (nanoseconds) timed by UniPCemu, it matches (after rounding) to the timings mentioned at https://www.minuszerodegrees.net/mda_cga_ega/mda_cga_ega.htm
With EGA I'm getting (when rounded) those mode 2 timings.
Reply 348 of 629, by GloriousCow
superfury wrote on 2024-10-24, 18:21:
Something like that. I'd calculate a signal clock in Hz based off when the CRTC raises hsync. The monitor PLL will have a clock which is adjusted within a certain window to match the input signal. So maybe the horizontal PLL can lock on to 15Khz +/-15% (i am not sure what the actual tolerance should be). What about 21Khz mode then? Easy, just have two PLLs, have the other try to sync to 21Khz +/- 15%. Whichever PLL is synced determines what mode you're in. I assume a real 5154 would only sync to something close to those two frequencies, as it is oft described as "dual frequency." To remain stable, the PLL has a proportional term which limits how fast it can adjust. So it may take a brief moment to sync to a new video mode, but you'd see a similar thing on a real monitor when changing modes.
If you want a multisync monitor, for VGA and such, just have one horizontal PLL with a wide berth of frequencies and a larger term perhaps.
superfury wrote on 2024-10-24, 20:31:
I've updated UniPCemu's video support a bit: - The GPU can now display ranges of display rendering buffer as an alternative to t […]
Sounds like you're entering the 'aperture' territory I've been dealing with in MartyPC. You're correct that there's no appreciable overscan in MDA timings. I define my "cropped" aperture which is designed to show the traditional resolution of a card (for mda, 720x350) with an x1,y1 of (9,4). But this is dependent on how you handle your horizontal and vertical sync timings, so maybe you won't need any.
Reply 349 of 629, by GloriousCow
mkarcher wrote on 2024-10-24, 19:26:
That's pretty interesting. Allowing you to swap monitor types in and out in the configuration could be fun as well, although I'd have to be careful it doesn't cause another source of confusion if people select an incompatible monitor / card combo.
Reply 350 of 629, by superfury
GloriousCow wrote on 2024-10-24, 20:52:
Something like that. I'd calculate a signal clock in Hz based off when the CRTC raises hsync. The monitor PLL will have a clock […]
Well, the way the timings are handled is pretty simple: during sync, the rendering position is kept at 0 until the sync stops. Then it increases with 1 for every clock/scanline rendered.
So basically if you have 800 horizontal clocks with 80 retrace clocks, the display is filled with 720 pixels.
Though the 8-bit inputting VGA DAC may divide it by 2 or 3 in higher color modes on SVGA adapters (15/16-bit and true color modes for example).
The framebuffer is parsed pretty dumb actually: it's simply resized to the target aspect ratio at various fixed resolutions (for example 800x600 on VGA to obtain 4:3 aspect ratio, larger multiples are possible too: 1024x768, 1440x1080 etc. All at 4:3). Although CGA has a special mode as well (379.83 x 242.5 aspect ratio at 800x600)) as well as a special 4K mode (3840x2160 at an unmodified aspect ratio (the same as the 4K aspect ratio)).
The area to resize to the viewing resolution is either the old x/y resolution (x2,y2), or the full frame size (x1,y1,x2,y2). Everything is simply stretched horizontally and vertically to the configured display resolution and aspect ratio. Most stretch to 4:3 aspect ratio, except the 4K one in this case. Although there's two 4K options: one that stretches to full 4K (getting it's aspect ratio instead) and one that keeps it at 4:3 aspect ratio. All others are always kept at 4:3 aspect ratio (except the CGA display one).
Though I usually have it set simply to 4:3 800x600 (small and fast) or sometimes 1024x768 resolution if I want to get a good look at the output (I'm using a plain 1080p FullHD monitor myself).
Reply 351 of 629, by SoftCat
Ok, to summarize: […]
Ok, to summarize:
GloriousCow, I'm glad you agreed. I looked at the CRTC parameters in the monochrome mode of EGA Fh (640x350). There is the inverse situation: pixel clock 14.31818 MHz, but 350 lines. This is done specifically for compatibility with a monochrome monitor: frequencies ~18 kHz and ~50 Hz. In general, on EGA you can do all the MDA and Hercules modes with 720 columns. And you can even do better than on Hercules, that is, the 720x350 graphics mode, since the video memory on EGA does not need to be divided between 4 banks.
Reply 352 of 629, by jal
As for testing on a real EGA monitor, I bet there are collectors out there that have one and don't mind testing some simple mode switch (the likes of Trixter). As for VGA overscan: VGA CRT monitors did have some borders, albeit not as wide as CGA, since they hadn't to deal with the signal being displayed on a tv.
Reply 353 of 629, by GloriousCow
A brief update. I've mostly been working on floppy stuff, which has been going into my fluxfox library, although I've started pulling some of that work, including the visualization widget, back into MartyPC.
MartyPC now has the beginnings of a full web interface which I hope to expand on. I haven't really decided what to do about the ROM situation. I could just say I don't care about 40 year old copyrights but that might get me kicked off VOGONS 😁
I had a thought to prompt you to drag and drop ROMS onto the browser window and store them in localstorage. We can keep a zip filesystem as a base64 blob in there. You wouldn't have to reload them unless you cleared your browser cache.
Got to say, booting a kryoflux image in your web browser is pretty darn cool...
The attachment martypc_web_01.png is no longer available
The attachment martypc_fluxfox_01.png is no longer available
Reply 354 of 629, by jal
So is the entire interface moving to the browser, or will there still be a non-browser solution? And what about the performance? I would think that running in a browser is a lot slower than native?
Reply 355 of 629, by GloriousCow
jal wrote on 2025-01-21, 14:57:
Don't worry, there will still be a desktop version, although it might not make an appearance for a while as I have to rewrite much of the old rendering system.
There are certain things that will never really work on the web, like logging several gigabytes of cycle traces. Joystick support is iffy. Currently shaders don't work either, although I think I can get them back in. Obviously it's harder to work with files as you can't just have a media directory full of stuff and browse through it. Developers can't modify ROMs and reboot and instantly see the changes. And so on.
This is not using emscripten, which the GUI library I am using doesn't support. Instead we're using Rust's native `wasm-unknown-unknown` compile target with a bit of a hack to enable threads via web workers. So all that can be compiled is Rust code - that means my FFI bindings for nuked-opl3 (written in C) won't work, unless I rewrite it in Rust.
As for performance, you'd be very surprised. It can vary a lot depending on what you're doing - if you're a tab hoarder, you may have a poor experience, but with a fresh launch of Chrome and in a foreground tab, Area 5150 plays quite smoothly at 60fps, with plenty of time in our frame budget. Ballpark math here but I'd estimate it is only about 20% slower than native. If you have a modern ARM CPU like an M1-M3, those run it beautifully as well.
A lot of folks have experienced issues running MartyPC on older machines. This new framework also enables a pure OpenGL backend without wgpu that I hope will run better for people. That will be a separate binary. There's still a lot of optimization yet to do in MartyPC's CPU core. I can remove much of the per-cycle logging facilities for the web version as there is nowhere to log to, anyway, and I'm curious what a bare-metal, "fast 8088" core can do. There are several places where SIMD instructions could potentially offer some massive speedups.
The main rationale for a web interface is accessibility and portability - it will work on any platform with a modern web browser, no dealing with different build systems per platform, as there is nothing to install or build. People who may not bother to download and set up MartyPC may be happy to click on a link to check it out and have fun with it. There's a value prospect for retro app developers too - if you've written some software intended for the IBM PC (or Jr or Tandy) , and want people to be able to check it out, why not just give them a link? I'll be distributing a static bundled build of the web version that you can just host anywhere and customize as you like.
Reply 356 of 629, by jal
Cool. Thanks for the extensive reply 😀.
Reply 357 of 629, by GloriousCow
I actually learned there's a new system with decent browser support called the "Origin Private Filesystem" that sounds like exactly what i need. It lets you store a large amount of data in sort of a sandbox, much bigger than what is allowed via localstorage. You could mount all sorts of stuff in there.
Reply 358 of 629, by jal
Mmm. that's cool. Local storage is indeed limited.
Reply 359 of 629, by GloriousCow
Tons of stuff is either janky or outright broken (you can't even reboot - just refresh the page), but it basically works and you can load disk images.
https://martypc.net
Click on the bouncy PC to start. have fun.
