Reply 20 of 27, by Falcosoft
- l33t
Cloudschatze wrote on 2024-10-28, 17:58:...
lb2.SF2 will get automatically loaded when using an SB Live! or Audigy if the game and SoundFont MIDI Router have been properly configured beforehand.For an SB Live!, that configuration is as follows:
Maybe it depends on the Liveware driver version but for my SB LIve! 5.1 (SB0100) no such router is installed:
Apart from this loading custom SF2 files to user banks through SFMAN32 API calls works perfectly (FSMP uses this method to automatically load SF2 files for corresponding Midi files and it works).
Yet I had to load lb2.SF2 manually to Bank 1 in order to get proper vocals.
