First post, by peter_shaw
I have this mainboard: https://theretroweb.com/motherboards/s/gigabyte-ga-686blx
When I try to install an ISA soundcard (Terratec Maestro 32/96), i get stuck at this screen:
The keyboard does not react - I cannot go into the BIOS at this point.
To get into the BIOS, the card needs to be removed again.
Things I tried:
- changing the ISA slots
- changing the GPU
- resetting the IRQ settings
- loading BIOS defaults
Here is what the pnp bios screen looks like, I tried
- Changing the PnP Settings between Legay ISA and PNP ISA / PCI
- Changing the IRQ settings from Auto to Manual
- Changing from Plug-And-Play OS to non-Plug-and-play OS
The card works in another Pentium 1 system.
Any hints?
My humble vintage PC collection: https://www.peter-shaw.de/2023/10/vintage-pcs/
Reply 1 of 11, by wierd_w
Likely IRQ conflict, or Bus conflict.
This card uses PnP to initialize, but panasonic cdrom interface uses port 340 by default. Ensure no network cards or other devices are trying to live there.
It could also be a symptom of a physical issue with your motherboard's ISA bus; eg, a bad slot. Try moving the card to another slot.
Suggested diagnostic process:
Remove all other cards, and disconnect the IDE ribbon.
Move the card to another slot.
Turn plug and play OS to ON, then use unisound to configure it.
Reply 2 of 11, by PC@LIVE
Let me try to make a hypothesis, if you use an ATX power supply, and it doesn't have the -5V wire, could this cause the block?
If, however, you have -5V, because you use an AT power supply, it is obviously something else, to clear your doubts, you should try the ISA Audio card, in another PC, and see what happens, if the same problem happens, there could be something else defective, in that card.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 3 of 11, by wierd_w
PC@LIVE wrote on 2024-10-02, 10:28:
It was reported in the initial post that this soundcard works correctly in a different pentium 1 system. It seems implausible that there is an issue with the card itself in this set of circumstances.
-5v rail may be worth investigating. I'll google if this card needs it.
Nope, I see nothing on this. Typically, only very vintage cards need -5v. This card seems geared toward early pentium systems, which would be ATX, and thus, not have -5v rail.
It may be an issue with the bios plug and play. Vogon's wiki says it consumes a large number of resources once configured. (3 irqs, several DMAs, and 6 IO ranges!)
It also conveniently links to drivers for it.
https://www.vogonswiki.com/index.php/Maestro_32/96
Reply 4 of 11, by ratfink
Are confident that this motherboard works otherwise?
Boots into Windows if you remove this card?
Does another card work in that slot?
Insert and remove the card a few times in case the slot (in the slot, as you say the card works elsewhere) contacts need rejuvenating?
Reply 5 of 11, by peter_shaw
Yes, the mainboard works fine with a PCI sound card.
I tried everything you suggested, with no success.
I assume something is wrong with the BIOS or with the slot itself phyiscally..
I don't have another ISA card sadly to rule out an hardware defect of the slot.
When booting into Windows ME, it shows this error, maybe it's somehow related? Can't figure out what it means.
In english, it reads:
"this device driver could not be loaded, because two ISA PNP .VXD Bustypes are present.
Request an updated BIOS from the vendor."
I tried 2 different BIOS already. I have installed the latest (beta) one (v 2.2b), only this one let's me use my IDE-to-SATA-adapter. With the earlier one (v 2.1), the HDD doesn't get recognized in BIOS. So it's a no-go for me.
Even so with the earlier BIOS, the system also gets stuck at post when installing the ISA card.
Reply 7 of 11, by Shponglefan
I have the same card. I tested it on a Pentium MMX 233 and while it does boot up, it will cause the system to lock up when attempting a soft reboot.
Apparently the issue can be corrected by replacing a capacitor (C58) with a 1uf, 16V capacitor. Haven't fixed mine yet, but I plan to try that at some point.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 8 of 11, by peter_shaw
http://terratec.ultron.info/Audio/Maestro/3296/Helpfiles/
Found the documentation on the fix here.
Going to try it some time
File name for mirror search: M3296_Modifikation_DE.pdf or ..GB.pdf
Reply 9 of 11, by Shponglefan
peter_shaw wrote on 2024-10-29, 16:51:
There's something odd about that documentation. The German version specifies a 3.3uF capacitor, while the English text says a 1uF capacitor.
I wonder which it's really supposed to be?
Reply 10 of 11, by BitWrangler
IF it was an official fix from the 90s, it might have been the difference in TUV testing vs UK GPO RF testing.
Reply 11 of 11, by peter_shaw
Shponglefan wrote on 2024-10-29, 17:18:
I finally found the time to fix this, lo and behold, it totally works!
Running a Maestro 32/96 on a Pentium III 800!
