First post, by TheMobRules
I have an MT-32 which works fine but a couple of the front panel buttons aren't working. I opened it and disassembled the non-working buttons to see if I could fix them. Roland used some Alps membrane-based switches ('SKELAF') and in my case the elastic rubber membrane completely broke on these 2 switches, so there's no simple way they can be fixed. Also, this type of switch is not available to purchase anymore so I'm looking for alternatives.
From what I could find on DigiKey and Mouser it seems 6mmx6mmx9.5mm tactile switches with 2 terminals should work, at least when it comes to footprint and size. Not sure if there's anything special about the original switches that I should consider, though I have noticed that pressing the original buttons (the ones that still work) the pins are not shorted, instead I get between 1 to 5 kohms. Is that because they are worn or am I missing something?
I'd like to hear opinions, especially if someone already had to replace the switches on their own unit.
Reply 1 of 2, by esher
According to MT-32 service manual schematic, there is 1S2473 diodes before every switch, may be you measured with them?
In the schematics it is just a switch, desolder the working one and check it separately. If it measures (desoldered) some kOhms - it's not normal.
Edit: there is video on youtube https://www.youtube.com/watch?v=BzbRcQHq1M8
where the author measures the same resistance. May be it's normal for this type of switch.
P133/Marl/32Mb/CT2930/PicoGUS 2.1/MT-32/SC88 Pro/MU-128
Reply 2 of 2, by TheMobRules
esher wrote on 2024-10-27, 19:05:
According to MT-32 service manual schematic, there is 1S2473 diodes before every switch, may be you measured with them? In the […]
Yeah, I stumbled upon that video before seeing your post... it's strange. I think I will try soldering a regular tactile switch and if it works fine I'll order some with the proper dimensions.
