TinyLlama 3
Reply 220 of 229, by centurion2024
Well if you had the place, you simple could use 2 sound chips on the bord, 1 for windows and 1 for dos.
Maybe if the cpu got a sound onboard, or to use sound chip on the vodoo/vga card, if you don't have the space for it. Under windows it would not care if it's on a other bus than a ISA bus.
Eivind wrote on 2024-10-19, 20:01:
Been kinda busy these last days, but here's a quick update of my findings: - The TL3.3 board looks alright, it does work (like t […]
- The TL3.3 board looks alright, it does work (like the previous prototypes) and I can play games on it! 😀
- The MXM connector works with sdz's Voodoo4 card, I'm getting VGA and HDMI through MXM and out from the respective connectors on the TL board!
- My Mini-PCIe-to-MXM adapter works fine as well, tested with my SM750-based card.
- I think there's some kind of bug with my power circuit - It takes two pushes of the power button to turn on the board, one to power it down. I tried two different USB-C PD power bricks, identical result. Will investigate this further.
- My CM4 with eMMC works just fine even though the board also has an external SD card slot for the Pi. I guess that means you can use either the eMMC-equipped CM4 or the Lite version - I need to get one of those for testing.
- Haven't gotten to experimenting with the I2C IO expander and diagnostic LEDs yet.
- The SATA connector might not have been the best idea. I kinda forgot that SATA devices also require "SATA power", and there's obviously no ATX power supply with these power connectors at play here. What might be a much smoother solution is using an mSATA or M.2 connector. Problem is, there's no room currently on the board for such a connector. A good quality microSD card works very well though, so not sure it's worth pursuing really.
- I don't like the position of the power- and reset buttons. Will have to think long and hard about those, I do want them to be 90-degree ones, but they all have through-hole pins or stabilizer studs which would interfere with the MXM connector on the bottom side.
- My biggest concern right now, however, is PicoGUS's apparent lack of Win98 support. It works amazingly marvellous in DOS, but I'm really struggling getting either the GUS or SB mode working in Windows. Wish it had a WSS mode... 😁 Any and all suggestions are welcome!
Edit: a little bird told me that a WSS mode might be in the cards...
Reply 221 of 229, by Eivind
centurion2024 wrote on 2024-10-24, 22:20:
The voodoo4 card could (in theory at least) have a PCI sound chip. However, the mini-PCIe cards use PCIe directly without a PCIe-to-PCI converter IC. PCIe is point-to-point, so this solution is not something I'd want to consider unless all other options are exhaused. I'll wait and see what might be possible with the rp2040.
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 222 of 229, by Eivind
Brain-dump update:
- I think I've figured out the cause of the double-press to power on issue, I was asserting/deasserting the PD controller's EN pin, apparently confusing it, instead of just enabling/disabling the main power mosfet.
- To solve both issues with power/reset button positions and SATA, I'll try to make a small riser board to sit above portions of the front area of the main board (above the sd card slots). This riser board will have buttons, probably some of the LEDs and an M.2 SATA connector for a 2230 or 2242-sized card (tbd).
- In order to more easily be able to play with different ISA sound solutions, I'm contemplating moving all the audio logic to a separate slim board, connected using the same Hirose board-to-board connectors the CM4 uses. There should be enough room underneath the MXM card. Mixer, opamp, etc can stay on the main board.
TinyLlama 3
TinyLlama SBC
Reply 223 of 229, by ahmadexp
Eivind wrote on 2024-10-25, 23:10:
Brain-dump update: - I think I've figured out the cause of the double-press to power on issue, I was asserting/deasserting the P […]
Brain-dump update:
I think that would be super awesome to have the sound card to become a card. That way you can update the sound card independently with all kinds of options.
If you choose that route, please consider all kinds of options (with wave table and without) pins so we can come up with all kinds of cool options.
We might be able to even have versions based on transferring ASICS from existing sound cards. This will also be a nice upgrade/evolution for the Llama Blaster project.
Man, this project is evolving... I love it
Reply 224 of 229, by vutt
Just came from dusting off my TinyLlama 3 components laying on the corner of my bench... 😀
I have day job running IT projects and Scope Creep is clear risk.
Have you considered forking base version into some sort of public V1 Limited run stable version? To give vogoners with higher risk appetite possibility to start playing around with wide range of legacy software few dedicated beta testers will not be able to cover.
Reply 225 of 229, by Eivind
ahmadexp wrote on 2024-10-26, 19:46:
What did you have in mind? Whatever MIDI signal is coming out of the sound card is gonna be routed to the CM4 to be synthesized there. Were you talking about also exposing a full-sized wavetable header? Setting aside the issue of finding space on the board for this, I kind of feel it wouldn't be needed seeing how capable and versatile the CM4 is. Do you disagree?
TinyLlama 3
TinyLlama SBC
Reply 226 of 229, by Eivind
vutt wrote on 2024-10-26, 20:18:
How could you have gathered the components needed for the TL3 before I've released any BOMs? 😁
Yes, I won't argue with that! However, seeing as this project only has a single contributor (me), no bosses and nobody I'm beholden to, I'd rather take my time and get it right... 😉
That sounds like way too much hassle, sorry!
TinyLlama 3
TinyLlama SBC
Reply 227 of 229, by ahmadexp
Eivind wrote on 2024-10-29, 19:27:
As usual you are spot one. However, since the board to board connector will have more pins that perhaps going to be unused, we can have the all the wavetable UART, line in/out, ISA etc... pins routed and provisioned. What I have in mind is to have sound cards that we can reuse in other projects that CM4 might not be present. It is always easy to neglect an existing pin and not use it, but its not easy to have the need for a pin that is not routed. I hope it makes sense.
Reply 228 of 229, by Eivind
ahmadexp wrote on 2024-10-30, 00:47:
Ah, yeah I can definitely set aside pins for all the common sound card signals, and just not use them on the TL3 (or the initial PicoGUS card), for future use. 👍
TinyLlama 3
TinyLlama SBC
Reply 229 of 229, by snipe3687
any chance you would be interested in releasing the pre-MXM schematics? I'd love to build one of those as I don't really have a way to build the Voodoo card yet and I'd really like to play with the compact one!
