DustyShinigami wrote on 2024-11-01, 13:49:
I see. But I take it a sound module, like the SC-55, would still be a better option?
Not necessarily.
The advantage of internal cards is simplicity. For sound cards with a wavetable header, you just plug in the daughtercard. Sometimes there can be jumper or driver settings required, but IIRC that's not the case with the Yamaha cards. All MIDI signal routing and audio mixing is handled internally by the sound card.
In contrast, external modules you have to do this via physical cables and other devices. This includes connecting a MIDI cable to whatever you're using for a MIDI interface (e.g. sound card). If you're going through a 15-pin joystick port, this also necessitates having a 15-pin-to-MIDI adapter.  You also have to route the audio from the sound module either back into the sound card (if using the sound card for mixing), or to an external mixer.  Plus sound modules take up more desk space and require external power.
For sound quality, any MIDI module or internal card that uses official Roland instrument samples should sound good.
There can be differences in things like polyphony (i.e. number of sounds that can be played at once). For example, the original SC-55 had only 24 voice polyphony. Later models increased that. In comparison, something like a Dreamblaster X16GS has 256-voice polyphony.  Depending on whatever you are listening to, this may or may not be an issue.
For standard General MIDI playback, I mostly use internal cards (either SCC-1 or daughtercards connected to a sound card or internal MIDI interface).
