Reply 28640 of 31480, by LoStSOul
Hi everyone...
Today was cleaning and assemble "pentium 2 project", replace vga card from "pentium 1 project"
Small case
Pentium 233mmx, 64mb ram, Diamond stealth 3d 2000, diamond monster 3D (3dfx), SoundBlaster32 PnP (28mb ram), 3com 3c905 10/100, Philips CDD3610 (first cdrw drive 2x2x6x), Toshiba 24X , Win98 SE
Big case
Pentium 2 450, 128Mb ram, Matrox G200, SoundBlaster AWE64 Gold, 3Com 905 10/100, HP cdrw 9500i, maybe install creative infra 1800, Win98 SE
GamingPC: R7 5800x3d, x570s Aorus Elite ax,32gb, radeon 7900 xtx, w10
InternetPC/General use: R7 1800x.64gb, Asus prime x370, quadro p620, Debian12
Reply 28641 of 31480, by Shponglefan
Did some testing of a Terratec Maestro 32/96 sound card.
I wanted to see if it would fit in the first ISA slot, since I need the other two for potentially longer sound cards. It was one of the tightest fits I've seen with the IDE pin header within a half-millimetre of the CPU fan.
I really do like this card. It reminds me of the Guillemot SC8600 with dual MIDI options (one in memory and one via wavetable header).
The attachment Terratec Maestro 3296 testing.jpg is no longer available
The attachment Terratec Maestro 3296 test fit.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 28642 of 31480, by PcBytes
Tested a Gainward Dragon 3000. There's something funny about running a Voodoo 2 12MB alongside a Geforce 2 Pro, of all the things I could pair it up with, but it was fun nonetheless.
Reply 28643 of 31480, by DarthSun
PcBytes wrote on 2024-11-01, 19:38:
Why? It works even in Ryzen 😀
The attachment zen_98_v2sli.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 28644 of 31480, by zuldan
Shponglefan wrote on 2024-11-01, 19:30:
Did some testing of a Terratec Maestro 32/96 sound card. […]
I love this card. Do you like how Doom sounds with FM? It’s just so different. Are you going to pair it with a waveblaster?
Reply 28645 of 31480, by Shponglefan
zuldan wrote on 2024-11-01, 21:07:
I haven't really tried the FM yet. At the moment I've been mainly testing the General MIDI capabilities.
And yes, I've paired it with an NEC XR385 (Yamaha DB60XG clone). It sounds pretty awesome. 😀
Reply 28646 of 31480, by k24a1
Not exactly super-retro but I'm working on my Pavilion ZD8000 and I am struggling with a multiboot setup, namely with the Windows 9x part of it. If I could get everything working on this I would have one heck of a nice 9x/XP machine.
Reply 28647 of 31480, by vutt
Recapped and tested my GF3 Ti 200. Spread some Rubycon love...
It was first time over past 7 or so years in retro computing when Capacitor "hissed at me with blue smoke". I have to admit I stress tested it few years ago. Card is passive I assume Aldi branded PC-s back in days had good case ventilation. While it's low end GF3 it gets really hot even with default clocks including memory. Those Raspberry Pi heatsinks on memory chips is my mod.
Reply 28648 of 31480, by BitWrangler
Discovered something really amazing last night about some Trident TVGA 9000C cards, they can get a huge speed boost with "this one weird trick" Re: Lowend 486 ISA VGA Graphics Quick Test, Mostly Tridents plus Oak, ATI, Tseng ....
I'm gonna do more with that, but I'm still needing both hands to keep my jaw from dragging on the floor.
Edit: actually this is a false alarm, maybe, some weird config on my motherboard did it, but can't figure what exactly what that config was or what caused it.
Reply 28650 of 31480, by zuldan
Shponglefan wrote on 2024-11-02, 20:36:
Got a thermal camera. This is my life now.
Yeah they are fantastic. Couldn’t imagine my life without one. 🤣. It’s so fast finding shorts now. Also really interesting to see where the heat spots are on motherboards and video cards. Helps with new builds, targeting air flow or adding heat sinks.
Reply 28651 of 31480, by GuillermoXT
My 20-month-old son hit my second wireless mouse, which I use when I'm sitting on the couch and want to watch series, on the table several times, causing a microswitch in it to break. So I transplanted another microswitch from an already broken mouse. Now I always have to remember to put the mouse away when the little one is playing in the living room.😅
The attachment IMG_20241102_233201_054.jpg is no longer available
The attachment IMG_20241102_233219_364.jpg is no longer available
The attachment IMG_20241102_233241_532.jpg is no longer available
The attachment 20241103_002207.jpg is no longer available
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 28652 of 31480, by Horun
Fired up the old XP box to game and find it had issues. Froze at desktop. One of the game/file HD's decided to start to die, spent last few hours transferring files from bad hd to a good one. If you think it be an easy process, no is not.
Every time I tried copying a bad file it would lock up Explorer so would have to reboot and try again not grabbing that file 🤣. Crystal disk said a few weeks ago no issues.
FWIW: is a WD 2TB Black drive with 45,000+ hours going bad, so was sorta expected to being close to having an issue but have others at 60,000+ hours and still work (and Crystal disk says they are fine).
This was a "all of a sudden thing", my guess is the media on platter just got flakey...
Reply 28653 of 31480, by tauro
Horun wrote on 2024-11-03, 03:27:
Fired up the old XP box to game and find it had issues. Froze at desktop. One of the game/file HD's decided to start to die, spe […]
Ouch!
It's a good idea to make backups/snapshots of important systems.
I also had a 2TB WD Black die on me, but this was many years ago when NVME didn't exist and high capacity SSDs were really expensive. I wouldn't say they are the most reliable ones. Maybe they are prone to fail after many power cycles. And since WD introduced SMR... I prefer Seagate.
Reply 28654 of 31480, by 386SX
Yesterday I bought an old second hand Fujifilm S5600 digital camera which I wanted to buy in 2006. I had just bought the S5500 back in those times, I still have that working great. Too bad these cameras had some problems on the battery cover when after some times the plastic clips ended up usually broken. I have to study a circuit to use some 800mAh Li-on battery with a micro usb circuit for the charge or simply close the cover making a hole through the plastics.
Reply 28655 of 31480, by GuillermoXT
About 20 years ago I've had the same problem with an old HDD and since Explorer refused to copy on various files I used a little program called "unstoppable copier" and it worked although kept stuck on some files for a few minutes.
My Retrosystems:
Reply 28656 of 31480, by dominusprog
Replaced this power switch with a new one.
The attachment IMG_20241102_211825.jpg is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 28657 of 31480, by Horun
GuillermoXT wrote on 2024-11-03, 10:36:
Wished had something like that Friday as today drive is near totally dead. Explorer shows main Dirs but no more files can be copied , Crystal Disk now shows "no information" and all entries blank.
Luckily had copied most important stuff to a few thumb drives a few months ago. Down side: Had a bunch game ISO's from my own game cd's that could not recover...
Reply 28658 of 31480, by RandomStranger
Visited the monthly vintage market. Haven't posted much about it in recent months. So accept a dog merchant as an apology.
The attachment IMG_20241103_091407.jpg is no longer available
Anyway, it was a good walk. Sunny, but a bit chilly. There were some nice vintage electronics. I almost bought a PSP, but it didn't turn on so I didn't risk it. Maybe I should have a power bank with various cables with me for these sort of places. Still picked up some stuff other than the home made food stuff I usually buy.
The attachment IMG_20241103_171635.jpg is no longer available
2GB DDR2 RAM
4GB DDR3 laptop RAM
A remote control for my Elitebook. Surprisingly the battery still had charge.
A used Athlon XP 2100+ with unused fan, still has the factory paste and the Athlon XP case sticker.
A fan that I thought will be an old stock AC F12, but it has a molex powered different brand fan inside. Still looks brand new so I don't mind that much.
Reply 28659 of 31480, by GuillermoXT
Horun wrote on 2024-11-03, 16:48:
I can see if I still have the program on my external hard drive, there are also other things on it from the win9x and Me times
My Retrosystems:
