Buzzing sounds when moving windows around
First post, by revolstar
OK, quick question: is it normal that I hear buzzing in my speakers and headphones whenever I move windows around under Windows 98? Out of curiosity I've used PS2Rate Plus to change the mouse polling rate and indeed, the pitch of the buzzing changes with the polling rate. Is this indicative of some IRQ conflict? Dying caps perhaps? The setup is as follows: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Live!/GF FX5700/Voodoo2 12MB (as in my signature).
Win98 rig: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Audigy/GF FX5700/Voodoo2 12MB
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 1 of 28, by dionb
Most likely some badly shielded analog path in your PC is acting like an antenna, picking up USB or PS/2 signals.
Do you have front panel audio hooked up? Try disconnecting it. Also check that all inputs are muted in the mixer. Are you exclusively using the SBLive or also onboard audio?
Reply 2 of 28, by revolstar
dionb wrote on 2024-11-08, 10:38:
No fornt panel, onboard audio disabled in BIOS, DVD ROM audio routed to the analog CD In socket on the SB Live, all inputs otherwise muted in the Windows sound mixer. The mouse is a Cherry optical model running through a USB to PS/2 adapter.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 3 of 28, by st31276a
Does it only happen when you drag windows around and not when you only move the mouse around?
Could be marginal power quality causing modulation, as more power is drawn when moving stuff around on screen. The noise might even come from ground, as higher currents can shift the ground level around too.
Reply 4 of 28, by revolstar
st31276a wrote on 2024-11-08, 10:44:
It's only when I move the windows around, i.e. when I grab the title bar and drag it around, yes.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 5 of 28, by st31276a
My guess is it is the graphics card drawing power in bursts, every time a ps2 packet arrives some on screen work is done rather quickly, hence the changing of the note at changed ps2 rates.
Maybe worth a try to see if the noise is quieter if the sound card is in a farther away slot, also test onboard audio to see if problem is there too.
Might be a filtering issue, caps on power rails on motherboard.
Reply 6 of 28, by DaveDDS
It is a "interesting" problem .. a test might to be running something that does serious processing (like a performance test) which
should make the system draw a bit more power - see of the symptoms change with more power draw
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 7 of 28, by revolstar
Oddly enough, I can hear this buzz even if I select "Mute All" in the Windows sound mixer.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 8 of 28, by Shponglefan
revolstar wrote on 2024-11-08, 12:54:
Its not an audio signal. Its likely being carried by the ground.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 9 of 28, by BitWrangler
CRT? ..... 'coz that's the only time I had something similar, about 1997 in max res on a vlb system with GD-5429, and I'd get a buzz moving windows, dragging icons or scrolling, when the speakers or cord were too near the monitor... keeping everything 8" away it didn't happen.
Reply 10 of 28, by revolstar
BitWrangler wrote on 2024-11-08, 13:39:
CRT? .....
Indeed! A Flatron 774FT
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 11 of 28, by revolstar
OK, I've tried the AC97 on-board audio and there's no buzzing.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 12 of 28, by Oetker
Maybe it's due to your cd analog audio cable?
Reply 13 of 28, by Tiido
That's most probably a ground loop type problem and it can happen due to CD audio cable or PC speaker connection if present. Sometimes the problems leaks in from +12V line and is an indication of bad capacitors on the analog supply rails of the sound card.
Reply 14 of 28, by leonardo
revolstar wrote on 2024-11-08, 13:54:
Ironically it would have usually been the sound card integrated to the motherboard that would suffer things like loud hiss, buzzes, clicks and other interference from the other components inside your box.
Does swapping sound cards (or slots) make a difference? Maybe moving the card to another slot is enough to correct the problem.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 15 of 28, by MikeSG
Try a shielded audio cable
Reply 16 of 28, by wierd_w
Also, use an outlet tester to make sure the ground on the outlet is actually there.
'Floating' ground is *infamous* for causing this issue.
Reply 17 of 28, by revolstar
Thanks for the suggestions peeps. I've swapped the slots on the MoBo, removed the analog CD audio cable - the buzz is still there. I'm considering getting a different Sound Blaster.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 18 of 28, by dionb
Have you checked the earthing/grounding? If that's the cause, a different card won't make a difference. Would be a shame to throw money at the problem before being sure.
Reply 19 of 28, by revolstar
dionb wrote on 2024-11-09, 10:11:
Aye, I've checked the grounding points on the card, they seem ok.
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
